Page 2 of 3 1 2 3
Re: Mr Six Pack Attack going on Dyno... Results are in!!!! [Re: cudabin] #1448030
06/07/13 07:26 AM
06/07/13 07:26 AM
Prospect, PA
BSB67 Online content
BSB67  Online Content
Prospect, PA
If anyone is interested, I can post the dyno sheets tommorow??
Cheers,
Arnie
You bet.
Re: Mr Six Pack Attack going on Dyno... Results are in!!!! [Re: cudabin] #1448031
06/07/13 07:59 AM
06/07/13 07:59 AM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
""Air fuel ratio at peak TQ was 13.3 and at peak HP it was 14.1""
These leaner A/F numbers are interesting, thank you for posting.
Re: Mr Six Pack Attack going on Dyno... Results are in!!!! [Re: YO7_A66] #1448032
06/07/13 08:27 AM
06/07/13 08:27 AM
oberlin, Ohio
Rapid340 Offline
Rapid340  Offline
oberlin, Ohio
Nice results Arnie.
I noticed the electric water pump drive. Were you able to make any pulls with the pump driven by the crank?
1971 Factory Appearing Duster 340 11.000 @ 122 mph
Re: Mr Six Pack Attack going on Dyno... Results are in!!!! [Re: Rapid340] #1448033
06/07/13 10:54 AM
06/07/13 10:54 AM
STERLING VA
FOOLISH_PLEASURE Offline
STERLING VA
How do I get one of those cams
Re: Mr Six Pack Attack going on Dyno... Results are in!!!! [Re: FOOLISH_PLEASURE] #1448034
06/07/13 11:10 AM
06/07/13 11:10 AM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
How much (or little) porting was done to the intake and heads?
I was dead on with the torque curve, just thought/expected it would pull a bit (~20)more HP up top....especially with a six pack.
I've seen 520 lb-ft/460+ hp results on stockish 440 builds using an OOTB Crower 271HDP cam, ported intake and just a 2.14 valve with some short side tweaks. I did use '915 (closed chamber 67 castings) heads though. That was on a stock bottom end with just shortened pressed pins (saves about 50 grams a slug) and 'flipped' 2355 TRW slugs.
WIZE
In Car:
Re: Mr Six Pack Attack going on Dyno... Results are in!!!! [Re: Streetwize] #1448035
06/07/13 11:25 AM
06/07/13 11:25 AM
Saskatchewan, Canada
cudabin Offline OP
cudabin  Offline OP
Obviously not enough porting...
since the Mr 6 pack cam has basically stock lift (corrected for the stock ratio not really giving 1.5)I did not open up the ports, just some "pocket porting" bowl work and valve job with back cut valves to try and improve low and mid lift flow. I know that the 9.5 compression also cost some HP, but i really wanted a street driver.
Intake flow @28
.100 = 75.3
.200 = 150.6
.300 = 200.6
.400 = 229.6
.500 = 238.3
.600 = 240.4
I think some 1.6 rockers would really wake it up, but then again it should spin the tires OK now with the Super Track pack 4.10 gears and the 4 speed.
Cheers,
Arnie
67 Cuda 8.48@ 158.7 mph 1.18 60' 2,600 DA(so far...) 70 Super Bee 440 Six Pack 4-speed. 13.2 @ 104 Stock exhaust/Street tires.
Re: Mr Six Pack Attack going on Dyno... Results are in!!!! [Re: cudabin] #1448036
06/07/13 11:43 AM
06/07/13 11:43 AM
cudabin Offline OP
cudabin  Offline OP
Dyno sheet #1
7734037-DOC060713.pdf (819 downloads)
Re: Mr Six Pack Attack going on Dyno... Results are in!!!! [Re: cudabin] #1448037
06/07/13 11:45 AM
06/07/13 11:45 AM
cudabin Offline OP
cudabin  Offline OP
Dyno sheet #2 Air/Fuel
7734039-Airfuel.pdf (278 downloads)
Re: Mr Six Pack Attack going on Dyno... Results are in!!!! [Re: cudabin] #1448038
06/07/13 11:45 AM
06/07/13 11:45 AM
cudabin Offline OP
cudabin  Offline OP
Dyno sheet #3 HP/TQ Graph.
7734040-HPTQGraph.pdf (447 downloads)
Re: Mr Six Pack Attack going on Dyno... Results are in!!!! [Re: FOOLISH_PLEASURE] #1448039
06/07/13 11:50 AM
06/07/13 11:50 AM
cudabin Offline OP
cudabin  Offline OP
Just call Bob Karakashian, Mr Six Pack himself at (daytime after 10:00 am) 734-421-9090
He is really great to talk to and know his six packs...
Cheers,
Arnie
Re: Mr Six Pack Attack going on Dyno... Results are in!!!! [Re: cudabin] #1448040
06/07/13 12:55 PM
06/07/13 12:55 PM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
Looks too lean up high. How come it wasn't corrected??? power may not have fallen off as much up there.
JAKES AUTOMOTIVE
Re: Mr Six Pack Attack going on Dyno... Results are in!!!! [Re: JAKE68] #1448041
06/07/13 01:08 PM
06/07/13 01:08 PM
ny
greenmcode Offline
greenmcode  Offline
ny
You didn't play with the timing? I know those cams like
more timing.. I run mine 40* total..
1969 A12 R.R. 11.61 117.96 F.A.S.T. STOCK STROKE..
Re: Mr Six Pack Attack going on Dyno... Results are in!!!! [Re: greenmcode] #1448042
06/07/13 01:53 PM
06/07/13 01:53 PM
cudabin Offline OP
cudabin  Offline OP
We started at 32 degrees then 34 degrees, then 37 and the plugs looked happy there...
Perhaps on the dyno where we can control the engine temp it may have pulled harder at 38-39, but in the real world in my Super Bee cruising around on a hot summer day, 37 will be less prone to detonation on 91 octane pump gas.
If i decide to take it to the track some day for a test and tune, i will bring some race gas to mix in, and try more timing. Bob K also mentioned he runs up to 40 degrees, but he runs race gas.
Re: Mr Six Pack Attack going on Dyno... Results are in!!!! [Re: cudabin] #1448043
06/07/13 02:43 PM
06/07/13 02:43 PM
Arnie did you guys try making the outboard carbs richer on the dyno? My best set of carbs had .097 orifices on the passenger sides and .094 on the driver side with Holley 64 jets inthe center carb. and a 4.5 power valve with a .060 PVRC in the meterring block The BSFC stayed under .42 with that jetting, the AFR would run between 13.3 and 13.6 at WOT. I treid jetting the outboards up by .004 on both isdes and the car slowed down .2 ET and 2 MPH in the 1/4
Re: Mr Six Pack Attack going on Dyno... Results are in!!!! [Re: Cab_Burge] #1448044
06/07/13 03:33 PM
06/07/13 03:33 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
I'm impressed, I know the Bob K cammed engines run hard, but I figured they had spent so much time tuning them that they were making alot of under the curve power. 54 horsepower is quite a gain. And those flow numbers really aren't that much more than stock 906s, sometimes someone's "pocket ported heads" flow 270 cfm which I figured was the case here.
You said its a cast iron intake, I assume a cast iron six pack setup?
Re: Mr Six Pack Attack going on Dyno... Results are in!!!! [Re: JAKE68] #1448045
06/07/13 06:54 PM
06/07/13 06:54 PM
cudabin Offline OP
cudabin  Offline OP
We tried more jet and it lost power on the low and mid range... This jetting made the most average HP and TQ from 3,000 rpm to 6,000 rpm which is where this street car will be driven. It is a balance thing.
Also since this was dynoed with manifolds but no mufflers, the full exhaust will change the jetting requiremnts a bit and hotter temps from the cast manifold under the hood will also richen up the mixture.
Re: Mr Six Pack Attack going on Dyno... Results are in!!!! [Re: Cab_Burge] #1448046
06/07/13 06:58 PM
06/07/13 06:58 PM
cudabin Offline OP
cudabin  Offline OP
Cab, this had 66 jets in the center and the idle a/F mixture was awesome, and 82 passenger side, 84 drivers side Holley jets in the end carbs.
6.5 power valve was fine as the Mr six pack cam had 19 in vaccum at idle...
This motor was happy with slightly leaner A/F in the higher RPM range!
Re: Mr Six Pack Attack going on Dyno... Results are in!!!! [Re: GTX MATT] #1448047
06/07/13 07:06 PM
06/07/13 07:06 PM
cudabin Offline OP
cudabin  Offline OP
GTX matt, Yes it is a cast iron Six pack manifold.
Keep in mind everyones flow bench reads different which is why they don't race flow benches...
Prior to the latest clean up in the bowls and new valve job my heads only flowed:
Intake:
.100 = 62.5
.200 = 121.8
.300 = 171.4
.400 = 204.8
.500 = 213.2
.600 = 221.6
So they gained close to 30 cfm at .200 and .300 lift, which is what I was after.
I am going to have to take this to the track later this summer and see what it ET's...
Cheers,
Arnie
Re: Mr Six Pack Attack going on Dyno... Results are in!!!! [Re: Rapid340] #1448048
06/07/13 08:58 PM
06/07/13 08:58 PM
cudabin Offline OP
cudabin  Offline OP
Nice results Arnie.
rapid 340, no i did not set up the pulleys and belts, but the MP alum water pump (in the cast iron housing) will probably steal 6-8 hp ??
Arnie
Re: Mr Six Pack Attack going on Dyno... Results are in!!!! [Re: cudabin] #1448049
06/07/13 10:29 PM
06/07/13 10:29 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Nice numbers Arnie
So does that Mr. SixPack cam have a mellow, stockish sleeper type idle?
Page 2 of 3 1 2 3
