Re: Mr Six Pack Attack going on Dyno... Results are in!!!!
[Re: cudabin]
#1448030
06/07/13 07:26 AM
06/07/13 07:26 AM
Posts: 4,313 Prospect, PA
BSB67
Prospect, PA
If anyone is interested, I can post the dyno sheets tommorow??
Cheers,
Arnie
You bet.
[Re: cudabin]
#1448031
06/07/13 07:59 AM
06/07/13 07:59 AM
Posts: 5,443 Indiana
YO7_A66
Indiana
""Air fuel ratio at peak TQ was 13.3 and at peak HP it was 14.1"" These leaner A/F numbers are interesting, thank you for posting.
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
[Re: YO7_A66]
#1448032
06/07/13 08:27 AM
06/07/13 08:27 AM
Posts: 2,091 oberlin, Ohio
Rapid340
oberlin, Ohio
Nice results Arnie.
I noticed the electric water pump drive. Were you able to make any pulls with the pump driven by the crank?
1971 Factory Appearing Duster 340 11.000 @ 122 mph
[Re: Streetwize]
#1448035
06/07/13 11:25 AM
06/07/13 11:25 AM
Posts: 903 Saskatchewan, Canada
cudabin
Obviously not enough porting... since the Mr 6 pack cam has basically stock lift (corrected for the stock ratio not really giving 1.5)I did not open up the ports, just some "pocket porting" bowl work and valve job with back cut valves to try and improve low and mid lift flow. I know that the 9.5 compression also cost some HP, but i really wanted a street driver. Intake flow @28 .100 = 75.3 .200 = 150.6 .300 = 200.6 .400 = 229.6 .500 = 238.3 .600 = 240.4 I think some 1.6 rockers would really wake it up, but then again it should spin the tires OK now with the Super Track pack 4.10 gears and the 4 speed. Cheers, Arnie
67 Cuda 8.48@ 158.7 mph 1.18 60' 2,600 DA(so far...)
70 Super Bee 440 Six Pack 4-speed. 13.2 @ 104 Stock exhaust/Street tires.
[Re: cudabin]
#1448038
06/07/13 11:45 AM
06/07/13 11:45 AM
cudabin
Dyno sheet #3 HP/TQ Graph.
[Re: cudabin]
#1448040
06/07/13 12:55 PM
06/07/13 12:55 PM
Posts: 1,495 Shelby mi.
JAKE68
Shelby mi.
Dyno sheet #2 Air/Fuel
Looks too lean up high. How come it wasn't corrected??? power may not have fallen off as much up there.
JAKES AUTOMOTIVE
[Re: JAKE68]
#1448041
06/07/13 01:08 PM
06/07/13 01:08 PM
Posts: 518 ny
greenmcode
ny
You didn't play with the timing? I know those cams like more timing.. I run mine 40* total..
1969 A12 R.R. 11.61 117.96 F.A.S.T. STOCK STROKE..
[Re: Cab_Burge]
#1448044
06/07/13 03:33 PM
06/07/13 03:33 PM
Posts: 5,161 CT
GTX MATT
CT
I'm impressed, I know the Bob K cammed engines run hard, but I figured they had spent so much time tuning them that they were making alot of under the curve power. 54 horsepower is quite a gain. And those flow numbers really aren't that much more than stock 906s, sometimes someone's "pocket ported heads" flow 270 cfm which I figured was the case here.
You said its a cast iron intake, I assume a cast iron six pack setup?
[Re: GTX MATT]
#1448047
06/07/13 07:06 PM
06/07/13 07:06 PM
cudabin
GTX matt, Yes it is a cast iron Six pack manifold.
Keep in mind everyones flow bench reads different which is why they don't race flow benches...
Prior to the latest clean up in the bowls and new valve job my heads only flowed:
Intake: .100 = 62.5 .200 = 121.8 .300 = 171.4 .400 = 204.8 .500 = 213.2 .600 = 221.6
So they gained close to 30 cfm at .200 and .300 lift, which is what I was after.
I am going to have to take this to the track later this summer and see what it ET's...
Cheers,
Arnie
