360 Rear Bearing Failure?
#1447944
06/05/13 04:43 PM
06/05/13 04:43 PM
Posts: 1,123 Seaford Delaware
JSR1485
Seaford Delaware
I have 300 miles on the engine in my Duster and I have been chasing a oil leak , so I figured the rear main seal was done. I dropped the pan and pulled the rear cap and the bearing is toast? The Thrust bearing is fine? Any idea what would wipe out the rear bearing?
Switched to the dark side...
Re: 360 Rear Bearing Failure?
[Re: Challenger 1]
#1447947
06/05/13 07:04 PM
06/05/13 07:04 PM
JSR1485
Seaford Delaware
I have a stick in the car and there was no vibration at all, the other bearings look fine. The rear is down to copper and I have run only Brad Penn oil.
[Re: Challenger 1]
#1447949
06/05/13 07:38 PM
06/05/13 07:38 PM
JSR1485
Seaford Delaware
Could be! I will find out after I pull the motor I guess. It seems the rear part of the bearing is worse then the front part.
