I have 300 miles on the engine in my Duster and I have been chasing a oil leak , so I figured the rear main seal was done. I dropped the pan and pulled the rear cap and the bearing is toast? The Thrust bearing is fine? Any idea what would wipe out the rear bearing?
Switched to the dark side...
