70 CUDA ROAD LAMP SWITCH #1447286
06/04/13 01:41 AM
06/04/13 01:41 AM
I DA HOE
3
3406pac Offline OP
3406pac  Offline OP
I DA HOE
WHERE DO I FIND A ROAD LAMP SWITCH FOR A 70 CUDA?
YO OFFERS ONE BUT $270?
AND BEA IS $200.
THANKS
AAR cuda 71 rag challenger
Re: 70 CUDA ROAD LAMP SWITCH [Re: 3406pac] #1447287
06/04/13 05:14 PM
06/04/13 05:14 PM
I DA HOE
3
3406pac Offline OP
3406pac  Offline OP
I DA HOE
What is the difference between a 70 & 71 fog lamp switch?
Re: 70 CUDA ROAD LAMP SWITCH [Re: 3406pac] #1447288
06/05/13 12:22 AM
06/05/13 12:22 AM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
the plug...one has more wires
Re: 70 CUDA ROAD LAMP SWITCH [Re: AARCONV] #1447289
06/06/13 11:21 AM
06/06/13 11:21 AM
Western,NY
JEJJ Offline
JEJJ  Offline
Western,NY
1970 have 2 wires (1 plug), 1971 have 3 wires (1 plug). This was due to the quad headlight system used in 1971. On 1971 models if you had the roadlamps turned on, and you went to turn on your high beams, the roadlamps would shut off, turning back on when you turned off your high beams..... if I recall correctly.
Re: 70 CUDA ROAD LAMP SWITCH [Re: 3406pac] #1447290
06/06/13 11:42 AM
06/06/13 11:42 AM
Pittsburgh, PA
Slotts Offline
Slotts  Offline
Pittsburgh, PA
Here is an original 71 3488447 road lamp switch in the upper left corner and an original 70 2947772 road lamp switch that I restore and offer. Also, the relays used are different. A 70 uses a 2889916 relay and the 71 uses a 3513557.
