Page 2 of 5 1 2 3 4 5
Re: 1941 Dodge truck project [Re: Flipper1938] #1443111
10/13/13 01:41 AM
10/13/13 01:41 AM
Escondido, CA. Ron Podsiadly,...
Mopar Ron Offline
Mopar Ron  Offline
I gave up on trying to find a cheap stand alone efi set-up for a dodge and crossed over to the dark side. I bougth a 5.3 LS motor/trans/ecm and harness/gas tank/driveshaft for $900.
That's sad to hear
Re: 1941 Dodge truck project [Re: Mopar Ron] #1443112
10/13/13 07:53 AM
10/13/13 07:53 AM
moparx Online content
moparx  Online Content
That's sad to hear
i remember not too long ago an article that used the gm ls harness and sensors to fire a 5.7 hemi. too bad you couldn't go that route.....
Re: 1941 Dodge truck project [Re: moparx] #1443113
10/13/13 10:12 AM
10/13/13 10:12 AM
Kentucky
Flipper1938 Offline OP
Kentucky
That's sad to hear
Where was that? I can unload my motor in a heartbeat.
Re: 1941 Dodge truck project [Re: moparx] #1443114
10/13/13 11:58 AM
10/13/13 11:58 AM
Kentucky
Kentucky
Is this it? http://nutterracingengines.com/hemitronix/hemitronix.pdf
...far from simple/easy to copy. Chrysler uses a different tooth count on the reluctor wheel than GM does. If you buy the kit to make the hemi think it is a LS motor...it is $2500
Re: 1941 Dodge truck project [Re: moparx] #1443115
10/13/13 04:48 PM
10/13/13 04:48 PM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
That's sad to hear
mega squirt has adaptable kits
1966 barracuda prostreeter super charged 340(SOLD)
1940 dodge coupe 241 hemi street rod
2014 ram express hemi 4x4 dailey driver
2015 cherokee
2013 R/T classic
Re: 1941 Dodge truck project [Re: Mopar Ron] #1443116
10/13/13 04:51 PM
10/13/13 04:51 PM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
That's sad to hear
people buy chevy for the same reason people shop at walmart,,,,its cheap junk and every one else is doing it,,IMO lol
2015 cherokee
2013 R/T classic
Re: 1941 Dodge truck project [Re: Flipper1938] #1443117
10/13/13 09:56 PM
10/13/13 09:56 PM
yes, that was the article i remember, but wow ! i didn't know it cost that much ! sure blows the "cheap" and "affordable" factors away !!!!!
Re: 1941 Dodge truck project [Re: Flipper1938] #1443118
10/13/13 11:49 PM
10/13/13 11:49 PM
Mopar Ron Offline
Mopar Ron  Offline
Richard which mopar engine were you going to use, 5.2 magnum or were you planing on a 5.7 hemi?.
there is a guy here on moparts (wldtm) that will set you up with a harness for a 5.2,
and hot wire has the hemi one for $995.
I hate that price too but is is only a few hundred more than the LS ones they sell.
Re: 1941 Dodge truck project [Re: Mopar Ron] #1443119
10/14/13 12:37 AM
10/14/13 12:37 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
if you are doing a 5.7 modern hemi pre 2009vvt...MSD has a unit that can be used to fire the ignition of a 5.7 or used to run the factory injection, i do not know if it will do both at the same time,,, they also have a wiring harness compatable with there HEMI box,if i remember correctly cost for the wiring harness was around 200 and the controller 485 depending where u buy it,,
2015 cherokee
2013 R/T classic
Re: 1941 Dodge truck project [Re: fstfish66] #1443120
10/14/13 10:10 AM
10/14/13 10:10 AM
Joplin, MO USA
Robbins Offline
Robbins  Offline
Joplin, MO USA
Please....put a mopar motor in it.
Moparlee
Re: 1941 Dodge truck project [Re: fstfish66] #1443121
10/14/13 10:16 AM
10/14/13 10:16 AM
Near Reading PA USA
pinkduster Offline
pinkduster  Offline
Near Reading PA USA
Chevy in a Dodge.
Re: 1941 Dodge truck project [Re: Mopar Ron] #1443122
10/14/13 08:18 PM
10/14/13 08:18 PM
Kentucky
Kentucky
The 5.7 hemi was the one I tried researching. From what I read it was a pain to make it work without using the steering column that came with the engine (I want to use the old steering wheel and column for looks). Making the trans work sounded like a pain too (ABS required?).
With the LS, the harness is free and programing to run the engine and trans without the original car is $75
I never tried looking for what it took to swap a 4.7, 5.2, or 5.9
Re: 1941 Dodge truck project [Re: Flipper1938] #1443123
10/28/13 10:43 PM
10/28/13 10:43 PM
N.Wilkesboro,NC
DusterKrazy Offline
DusterKrazy  Offline
N.Wilkesboro,NC
Sell the gm stuff and put in a 12v Cummins
They do come in Dodge trucks anyways. Good luck with the project regardless.
My '41 has a 318/904. Bolted right onto the stock frame.
Re: 1941 Dodge truck project [Re: Flipper1938] #1443124
11/03/13 10:56 PM
11/03/13 10:56 PM
Kentucky
Kentucky
edit: chevy motor pics removed
I'm gonna have to cut a lot of spring. I don't think it moved any when I put the motor on the frame.
IMG_6293 by Flipper_1938, on Flickr
Re: 1941 Dodge truck project [Re: Flipper1938] #1443125
11/03/13 11:58 PM
11/03/13 11:58 PM
Mopar Ron Offline
Mopar Ron  Offline
I've got to stop looking at this thread,
it make me so sad seeing this
happen
Re: 1941 Dodge truck project [Re: Mopar Ron] #1443126
11/04/13 09:35 AM
11/04/13 09:35 AM
Kentucky
Kentucky
happen
The way I see it, I'm still saving a badly hacked up Dodge truck. If somebody wants to undo the chevy motor part sometime down the road...they can.
Re: 1941 Dodge truck project [Re: Flipper1938] #1443127
11/04/13 08:46 PM
11/04/13 08:46 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
Chevy in a Mopar
Re: 1941 Dodge truck project [Re: Flipper1938] #1443128
11/04/13 10:37 PM
11/04/13 10:37 PM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
happen
Scrap the Dakota frame too, the S10 is narrower and easier to get the Chevy motor in.
Re: 1941 Dodge truck project [Re: moparpollack] #1443129
11/05/13 10:05 AM
11/05/13 10:05 AM
Kentucky
Kentucky
...and the Dodge body....
Re: 1941 Dodge truck project [Re: Flipper1938] #1443130
11/05/13 11:19 PM
11/05/13 11:19 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
If you're going to scrap the Dodge, I will take it off your hands. I'll even take it on that Dakota frame. I got some Mopar stuff laying around here I'd be happy to fix it up with.
It would make a nice yard mate (don't have garage space) to my 48 Plymouth coupe. Gene
