Re: 68-69 RR instrument clusters?
[Re: sthemi]
#144200
11/09/08 09:47 PM
11/09/08 09:47 PM
Posts: 169 Maine
itali83
Maine
I think the roadrunner should have more MPH listed. I can't remember off the top of my head how many MPH's they are, but think the base models had slower speedo's.
'68 Roadrunner Built 440/727 4:10 filled 8 3/4 in the process of a ground up restification
[Re: cdp]
#144202
11/09/08 10:28 PM
11/09/08 10:28 PM
Posts: 21,505 N.E. OHIO, USA
A12
N.E. OHIO, USA
Any difference? I have access to a really nice original out of a 68 sattelite. I was thinking of saving a few bucks and used the 68 in my 69 RR. i wasn't sure if there is any difference between the 2 years.
None that I can think of except some small (graphic) lines in the tach/clock/no clock/no tach area. The GTX had the 150 mph speedo, RR's to 120 mph like the Satellite, Belvedere.
MikeR
[Re: ademon]
#144204
11/25/08 12:58 AM
11/25/08 12:58 AM
Posts: 6,679 Va. Beach, Va
69superbee383
Va. Beach, Va
The 69 and 69 temp gauges are different. The 68 operating range is narrower with the start of the range farther over than in 69.
77 Macho Power Wagon LWB factory 440
70 Coronet 440 N code 3 speed
[Re: 69superbee383]
#144205
11/25/08 09:53 PM
11/25/08 09:53 PM
A12
N.E. OHIO, USA
The 68 (corrected) and 69 temp gauges are different. The 68 operating range is narrower with the start of the range farther over than in 69.
under the "learn something new everyday" I just found this Chrysler (Dodge) bulletin but don't know if it also pertains to Plymouth '69 temp gauges "early and late '69"
MikeR
[Re: gtx6970]
#144208
11/26/08 11:12 AM
11/26/08 11:12 AM
why do some have lettering on the cluster lense for the headlight, wipers, etc and some dont?
