68-69 RR instrument clusters? #144198
11/01/08 10:13 AM
11/01/08 10:13 AM
MO
cdp Offline OP
cdp  Offline OP
MO
Any difference? I have access to a really nice original out of a 68 sattelite. I was thinking of saving a few bucks and used the 68 in my 69 RR. i wasn't sure if there is any difference between the 2 years.
Re: 68-69 RR instrument clusters? [Re: cdp] #144199
11/01/08 10:54 AM
11/01/08 10:54 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
It's been a while, but I remember something about the high beam indicator being different , maybe in 1970.
Re: 68-69 RR instrument clusters? [Re: sthemi] #144200
11/09/08 09:47 PM
11/09/08 09:47 PM
Maine
itali83 Offline
itali83  Offline
Maine
I think the roadrunner should have more MPH listed. I can't remember off the top of my head how many MPH's they are, but think the base models had slower speedo's.
'68 Roadrunner Built 440/727 4:10 filled 8 3/4 in the process of a ground up restification
Re: 68-69 RR instrument clusters? [Re: itali83] #144201
11/09/08 10:27 PM
11/09/08 10:27 PM
Upstate NY
Big_John Offline
Big_John  Offline
Upstate NY
68 and 69 are the same.
BTW, Roadrunners had 120MPH speedos. GTX had 150MPH
Re: 68-69 RR instrument clusters? [Re: cdp] #144202
11/09/08 10:28 PM
11/09/08 10:28 PM
N.E. OHIO, USA
A12 Online content
A12  Online Content
N.E. OHIO, USA
None that I can think of except some small (graphic) lines in the tach/clock/no clock/no tach area. The GTX had the 150 mph speedo, RR's to 120 mph like the Satellite, Belvedere.
MikeR
Re: 68-69 RR instrument clusters? [Re: A12] #144203
11/09/08 11:43 PM
11/09/08 11:43 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
68 here
Re: 68-69 RR instrument clusters? [Re: ademon] #144204
11/25/08 12:58 AM
11/25/08 12:58 AM
Va. Beach, Va
69superbee383 Offline
Va. Beach, Va
The 69 and 69 temp gauges are different. The 68 operating range is narrower with the start of the range farther over than in 69.
77 Macho Power Wagon LWB factory 440 70 Coronet 440 N code 3 speed
Re: 68-69 RR instrument clusters? [Re: 69superbee383] #144205
11/25/08 09:53 PM
11/25/08 09:53 PM
N.E. OHIO, USA
A12 Online content
A12  Online Content
N.E. OHIO, USA
The 68 (corrected) and 69 temp gauges are different. The 68 operating range is narrower with the start of the range farther over than in 69.
under the "learn something new everyday" I just found this Chrysler (Dodge) bulletin but don't know if it also pertains to Plymouth '69 temp gauges "early and late '69"
MikeR
Re: 68-69 RR instrument clusters? [Re: A12] #144206
11/26/08 10:33 AM
11/26/08 10:33 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
nice bulletin, my gauge jives with my temp probe ! This bulletin should be saved in the tech section
Re: 68-69 RR instrument clusters? [Re: ademon] #144207
11/26/08 10:54 AM
11/26/08 10:54 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
I seem to think the the 68 temp gauge has been found in some early 69 clusters though.
There was a post about this a few years back.
Re: 68-69 RR instrument clusters? [Re: gtx6970] #144208
11/26/08 11:12 AM
11/26/08 11:12 AM
why do some have lettering on the cluster lense for the headlight, wipers, etc and some dont?
