Lickity Splits fire system saves it, Pictures fixed #1441126
05/23/13 10:49 PM
05/23/13 10:49 PM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
First thanks to Cold fire for a good system. Just finished the trans, new A&A drum to cure the 3rd gear slip. Went to start it ,fired once then POP. Flipped the upper half of the intake upside down and burned. Hit the fire bottle got out and hit it with a small puff from the garage extinguisher to make sure it was out. The lower intake needs to be welded. Everything cleaned up pretty good with help from my wife. I cant find all the little parts of the intake, so I think I'll pull the heads to check. Can't afford to wreck anymore pieces. I was all set to leave for the Memorial race at Mid Michigan and get my license. Could have been a lot worse.
Doug
Re: Lickity Splits fire system saves it [Re: dvw] #1441127
05/23/13 10:53 PM
05/23/13 10:53 PM
Wi.
old_racer Offline
old_racer  Offline
Wi.
Glad it didn't get worse! fast thinking on your part. picture didn't work.
Re: Lickity Splits fire system saves it [Re: dvw] #1441128
05/23/13 11:03 PM
05/23/13 11:03 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Bummer Doug.... glad it wasnt worse
Re: Lickity Splits fire system saves it [Re: old_racer] #1441129
05/23/13 11:03 PM
05/23/13 11:03 PM
MD
Kevins493 Offline
Kevins493  Offline
MD
Really glad it wasn't worse! Couldn't see the picture, how bad did it hurt the car? Send the new one to Bob George and have him fill in the floor and install blow off valves in it so that it doesn't happen again.
Re: Lickity Splits fire system saves it [Re: Kevins493] #1441130
05/23/13 11:13 PM
05/23/13 11:13 PM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
Think there wasn't some force,check the throttle cable.
Re: Lickity Splits fire system saves it [Re: dvw] #1441131
05/23/13 11:15 PM
05/23/13 11:15 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
WOW sorry to hear but it looks fixable.I hope from the cam to the carb everything else is ok!
Re: Lickity Splits fire system saves it [Re: dvw] #1441132
05/23/13 11:16 PM
05/23/13 11:16 PM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
And of coarse there's a fire nozzle in the interior as well.
Re: Lickity Splits fire system saves it [Re: dvw] #1441133
05/23/13 11:18 PM
05/23/13 11:18 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
thank god you got it out quick
Re: Lickity Splits fire system saves it [Re: dvw] #1441134
05/23/13 11:22 PM
05/23/13 11:22 PM
Aurora, Oh.
max_maniac Offline
max_maniac  Offline
Aurora, Oh.
Sorry to see that Doug. I know what thats like as I have had 2 of them blow up on me. One was at start up and the other was as I was driving through the pit area to go get teched in!!! Bob George put these blow off valves on my intake and I also put in the inserts in and have not had that issues since then. I know there are plenty of people who have never had an issue like that with these intakes but after having it happen to me twice I had to do something. The Wilson blow off valves also work very good!!!
Russ
Re: Lickity Splits fire system saves it [Re: max_maniac] #1441135
05/24/13 12:08 AM
05/24/13 12:08 AM
OHIO THE HEART OF IT ALL
64hemi330sedan Offline
YIKES!! this post is scaring the (bleep) out of me.i think mine needs to have those mod's done.
Re: Lickity Splits fire system saves it [Re: max_maniac] #1441136
05/24/13 01:12 AM
05/24/13 01:12 AM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
Before this happened to me I would have thought a mechanical issue or driver error. I always turn the pump off before shutting the engine off. Prime the carbs and then turn the pump off until it's running. I think I kicked the throttle 4 times total. The only thing that I see at all is the #7 plug is carbon fouled. Looks like it hasn't been firing, at least on this start up. I will build some type of blow off now.
Doug
Re: Lickity Splits fire system saves it [Re: dvw] #1441137
05/24/13 03:47 AM
05/24/13 03:47 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Glad you got it out before doing any further damage. Trust me I feel your pain....
Re: Lickity Splits fire system saves it [Re: Al_Alguire] #1441138
05/24/13 07:03 AM
05/24/13 07:03 AM
pa
572charger Offline
572charger  Offline
pa
ouch ! that sucks hope the rest of the engine is ok, now ya got me thinkin i just put the indy tunnel ram back on mine but i never had it do that ? must have somthing to do with the fuel in that big plenum ??? and a miss fire ??
606 hemi pump gas best 9.60 at 142mph on motor
05 hemi daytona 1500 go-mango 4wd quadcab
2007 hotrod mag pump gas drags runner up, roadkill nights dodge big tire winner 2018 2019 back to back
Re: Lickity Splits fire system saves it [Re: 572charger] #1441139
05/24/13 08:36 AM
05/24/13 08:36 AM
tboomer Offline
tboomer  Offline
Wow!! Doug...I am glad it wasn't any worse than that!! Good thinking on your part!
Re: Lickity Splits fire system saves it [Re: tboomer] #1441140
05/24/13 08:49 AM
05/24/13 08:49 AM
Walton's Mountain, Pa
Steve1118 Offline
Steve1118  Offline
That happened to son Kyle's car....we had a nice little fire going. Pulled all of the bolts out of the bottom, they redrilled and tapped them to a bigger size.
It does have pop off valves on it now! That was enough fun and excitement to fill an evening.
"Old age and treachery trumps youth and enthusiasm, every time!"
East Central Director / Chrysler Power Magazine
www.reasbeckracing.webs.com
Re: Lickity Splits fire system saves it [Re: tboomer] #1441141
05/24/13 08:56 AM
05/24/13 08:56 AM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
Hate to see that happen to such well put together car – the blow-off valves are a must with that intake – check your carbs now as the explosion usually takes out the part of the casting where the air mixture screws seat into – especially if they are edelbrocks as they are more prone to the problem than the carters.
The big bang probably started with the #7 plug being it was fouled – possibly your lash may have been slightly off or that valve was hanging a little being the engine was cold. It does not take much to set them off.
Re: Lickity Splits fire system saves it [Re: DoubleD] #1441142
05/24/13 09:07 AM
05/24/13 09:07 AM
COLUMBUS, OH
W
Whompin_Wedge Offline
W
COLUMBUS, OH
OUCH! Doug hate to see that man!
We have done it twice as well, Put on a set of those Wilson nitrous blow off valves and you wont have another problem.
Casey
Re: Lickity Splits fire system saves it [Re: Whompin_Wedge] #1441143
05/24/13 09:09 AM
05/24/13 09:09 AM
an8sec70cuda Offline
REALLY glad to see you saved it! That could have been catastrophic! Such a beautiful car, hope you get it fixed up soon.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Lickity Splits fire system saves it, Pictures fixed [Re: dvw] #1441144
05/24/13 09:22 AM
05/24/13 09:22 AM
mi
RATPATROL Offline
RATPATROL  Offline
mi
one more valve option, heres my speedtech valve fits nice between carbs, sad this happened hope fix goes well. bob.
Re: Lickity Splits fire system saves it, Pictures fixed [Re: RATPATROL] #1441145
05/24/13 10:12 AM
05/24/13 10:12 AM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
OH MY!
Sorry to see this Doug and hope the repair is as painless as possible
