Lickity Splits fire system saves it, Pictures fixed
#1441126
05/23/13 10:49 PM
05/23/13 10:49 PM
Posts: 9,871 MI, usa
dvw
MI, usa
First thanks to Cold fire for a good system. Just finished the trans, new A&A drum to cure the 3rd gear slip. Went to start it ,fired once then POP. Flipped the upper half of the intake upside down and burned. Hit the fire bottle got out and hit it with a small puff from the garage extinguisher to make sure it was out. The lower intake needs to be welded. Everything cleaned up pretty good with help from my wife. I cant find all the little parts of the intake, so I think I'll pull the heads to check. Can't afford to wreck anymore pieces. I was all set to leave for the Memorial race at Mid Michigan and get my license. Could have been a lot worse. Doug
Re: Lickity Splits fire system saves it
[Re: dvw]
#1441137
05/24/13 03:47 AM
05/24/13 03:47 AM
Posts: 19,382 Las Vegas
Al_Alguire
Las Vegas
Glad you got it out before doing any further damage. Trust me I feel your pain....
[Re: Al_Alguire]
#1441138
05/24/13 07:03 AM
05/24/13 07:03 AM
Posts: 1,629 pa
572charger
pa
ouch ! that sucks hope the rest of the engine is ok, now ya got me thinkin i just put the indy tunnel ram back on mine but i never had it do that ? must have somthing to do with the fuel in that big plenum ??? and a miss fire ??
606 hemi pump gas best 9.60 at 142mph on motor 05 hemi daytona 1500 go-mango 4wd quadcab 2007 hotrod mag pump gas drags runner up, roadkill nights dodge big tire winner 2018 2019 back to back
[Re: tboomer]
#1441140
05/24/13 08:49 AM
05/24/13 08:49 AM
Posts: 2,763 Walton's Mountain, Pa
Steve1118
That happened to son Kyle's car....we had a nice little fire going. Pulled all of the bolts out of the bottom, they redrilled and tapped them to a bigger size.
It does have pop off valves on it now! That was enough fun and excitement to fill an evening.
"Old age and treachery trumps youth and enthusiasm, every time!" East Central Director / Chrysler Power Magazine www.reasbeckracing.webs.com
[Re: Whompin_Wedge]
#1441143
05/24/13 09:09 AM
05/24/13 09:09 AM
Posts: 13,385 Marion, South Carolina [><]
an8sec70cuda
REALLY glad to see you saved it! That could have been catastrophic! Such a beautiful car, hope you get it fixed up soon.
