A/F with different ratios of ethanol in the gas #1440411
05/22/13 10:38 AM
05/22/13 10:38 AM
Carson City, NV
babarracuda Offline OP
Carson City, NV
I run 91 pump gas. My meter reads 12.8 in high gear. I read somewhere that it should be a little richer like 12.3 or 12.4. Does anyone have a chart of the different ratios of ethnol in the gas and what should be wide open stoich? I hope Cab Burge chimes in
Re: A/F with different ratios of ethanol in the gas [Re: babarracuda] #1440412
05/22/13 10:47 AM
05/22/13 10:47 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
12.5 to 12.7....Even at 12.7 it might be a touch lean. I had my efi set at 12.9 from the previous non E10 fuel and couldn't figure out where all my power went. Dropped it to 12.6, and its back! This is for E10, E15 would need to be richer yet...
Re: A/F with different ratios of ethanol in the gas [Re: babarracuda] #1440413
05/22/13 10:54 AM
05/22/13 10:54 AM
MR_P_BODY Offline
MR_P_BODY  Offline
If your talking at WOT then you dont care what that
number is... go for the fastest MPH then once you find
that point write that number down... thats what you
can go back to if you change anything... cruise is
the hardest point to set... idle I dont even use a
A/F ratio number... just make it idle nice
Re: A/F with different ratios of ethanol in the gas [Re: MR_P_BODY] #1440414
05/22/13 11:03 AM
05/22/13 11:03 AM
Carson City, NV
Carson City, NV
I pretty much bunged up so reaching over the fender is hard. I'll change it to richer before I go next time and see if it runs faster. I like to go out a couple of times a year and play. At 71 with lots of surgeries and meds, racing is not realistic. I was at MATS this year and didn't look until the last run and it was 13.8 A/F. Think I could have run faster. I was shocked that I made 2 rounds. Just time trials from now on.
Re: A/F with different ratios of ethanol in the gas [Re: babarracuda] #1440415
05/22/13 11:16 AM
05/22/13 11:16 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I have a chart somewhere on this puter and I'll see
if I can find it... I know that a couple of others
have it also... but 13.8 is lean even with gas(by
about 1 point)
Re: A/F with different ratios of ethanol in the gas [Re: babarracuda] #1440416
05/22/13 11:18 AM
05/22/13 11:18 AM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
If you are at 13.8 on fuel with any ethanol content to speak of,you should pick up by richening the mixture
I would shoot for 12.5 for a power mixture to start with and tune from there. You make more power being slightly rich than you do being slightly lean.
Keith
Re: A/F with different ratios of ethanol in the gas [Re: MR_P_BODY] #1440417
05/22/13 12:30 PM
05/22/13 12:30 PM
Dragula Offline
Dragula  Offline
Yes. This would be at WOT, and a starting point...MPH will tell you what it really wants.
Mine I had set at 12.9 for a long time, and then realized why it had fallen off, and 12.6 seems to be what it wants now, it also liked 12.7, so both are in the range mine was happy. Obviously with pump crap, the E10 is not a true number either...
Re: A/F with different ratios of ethanol in the gas [Re: babarracuda] #1440418
05/22/13 01:12 PM
05/22/13 01:12 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
I was shocked too...that you made 2 rounds....ok..just kidding...lol
Tony
70 AARCuda Vitamin C
Re: A/F with different ratios of ethanol in the gas [Re: 70AARcuda] #1440419
05/22/13 01:55 PM
05/22/13 01:55 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
There is an article in the new Hot Rod about todays oxygenated fuels and there is a chart that lists max power rich for e10 at 12.0 and max power lean at 12.7.
Re: A/F with different ratios of ethanol in the gas [Re: justinp61] #1440420
05/22/13 02:47 PM
05/22/13 02:47 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
Here's a chart I use:
Re: A/F with different ratios of ethanol in the gas [Re: Mopar_Rich] #1440421
05/22/13 04:18 PM
05/22/13 04:18 PM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
The supercharged column is a little misleading as that isn't a lambda equivalent anymore, but that's decent for targets.
Re: A/F with different ratios of ethanol in the gas [Re: Blusmbl] #1440422
05/22/13 04:36 PM
05/22/13 04:36 PM
MR_P_BODY Offline
MR_P_BODY  Offline
ANY of them are just that... target numbers... EACH
ENGINE wants different... play to find out
Re: A/F with different ratios of ethanol in the gas [Re: MR_P_BODY] #1440423
05/22/13 04:44 PM
05/22/13 04:44 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
this is if your gauge is set to read on gasoline
The Basics of Air Fuel Ratio
What is lambda, and the difference between narrow band and wide band 02 sensors?
Contributed By: Enginebasics.com
Air Fuel Ratio Wideband Narrowband Gauge Sensor Bosch Tuning
One the most important aspects of the combustion motor is the air to fuel ratio in the cylinder. Like all things that explode, having the proper amount of combustible fuel to the amount of air to sustain the burn is important. Having lots of air but no fuel will cause the combustion to burn very rapidly and hot, while having lots of fuel, but no air will cause the mixture to burn very cool and slowly. Having an overly gross amount of either fuel or air will cause the combustion to not even occur at all.
What is Lambda?
Lambda is scale that relates the air to fuel ratio of ANY fuel. 1.0 is stoic for every fuel. (the chemically perfect ratio of air to fuel for a complete burn). However, stoic is different for every fuel. Some fuels may need 14.7 lbs of air some may need 6 lbs of air for a complete burn. Lambda 1.0 is always the perfect ratio for the fuel in use.
Some tuners argue that it is better to read air to fuel ratio’s in lambda since it will be accurate with any fuel. To be fair though, most aftermarket gauges will read lambda and convert that number to an a/f ratio for gasoline. If the user then knows the stoic, lean, and rich ratio’s for gasoline, he can apply those numbers to any fuel used and it won’t matter.
What I mean is that if you are running 14.7 (stoic) on a gasoline A/F gauge and you then convert to alcohol ( or E85 ), 14.7 will still be stoic on the gasoline gauge. This is because the gauge is going to read a stoic lambda reading of 1.0 for any fuel, and the gauge is going to output that number as 14.7 on you’re A/F gauge even though we know the true ratio for alcohol is 7.1-9.1.
Many times I have then seen people try and richen the cars tuning map to get down to that A/F value, not realizing that they are already at a stoic burn if the gauge set up for gasoline reads 14.7.
Re: A/F with different ratios of ethanol in the gas [Re: CSK] #1440424
05/22/13 04:52 PM
05/22/13 04:52 PM
Dragula Offline
Dragula  Offline
What is Lambda?
Please don't quote theory in the race section...I may shoot the messenger...
I don't ever want to hear or see that BS number again. We have had guys at the track soo hung up on the numbers they read about, they have killed their engines making it hit those numbers...Please use the other chart by Mopar Rich or some of the baseline starting points others have discussed. Testing at the track will get you where you need to be.
Re: A/F with different ratios of ethanol in the gas [Re: Dragula] #1440425
05/22/13 04:58 PM
05/22/13 04:58 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
1st off i was not saying to make it run at 14.7!!!!!!
if you read what it says,if your gauge is set up for gasoline & on gas it runs at 12.8.when running ethanol 12.8 would be correct,point is don't make your wide band that is set up for gas read 7.0 to 1
Re: A/F with different ratios of ethanol in the gas [Re: CSK] #1440426
05/22/13 05:01 PM
05/22/13 05:01 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I happen to like the standard GAS readings and I have
used Lambda but to me the gas reading is wider with
more increments of movement(but being I'm older and I
started on the gas readings)... both are just a value
to read the A/F ratio... but you need to know what
your reading.. IF you see single digit its a lambda
(as in a 1.0... instead if a 10.0 or greater)
Re: A/F with different ratios of ethanol in the gas [Re: Blusmbl] #1440427
05/22/13 05:44 PM
05/22/13 05:44 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
Yeah, I know, but it's just something I worked up. The Lambda numbers are fine for the NA variations.
Re: A/F with different ratios of ethanol in the gas [Re: Mopar_Rich] #1440428
05/23/13 02:38 PM
05/23/13 02:38 PM
Carson City, NV
Carson City, NV
Thanks guys! I found the chart in the latest issue of Hot Rod. I agree that it's only a referemce. Still have to play with mixtures
