TBI setup swap #1438602
05/19/13 02:04 AM
05/19/13 02:04 AM
Sturgis S.D.
tripleblackcuda Offline OP
Sturgis S.D.
I have a 1975 Dodge Kary van with a 360 and an automatic trans. I just bought a 89 Ramcharger with a 360. What would it intail to put the TBI set-up on the van? Also, how hard is it to do?
Re: TBI setup swap [Re: tripleblackcuda] #1438603
05/19/13 02:10 AM
05/19/13 02:10 AM
libby mt
lifted85 Offline
lifted85  Offline
libby mt
well ya would need the intake, tbi an some wiring to be done of course lol.. never have done it my self but know it's a big thing to some.. I think ya have to change your fuel pump to??? might be wrong
drive fast, drive hard, DRIVE MOPAR
Re: TBI setup swap [Re: lifted85] #1438604
05/20/13 11:49 AM
05/20/13 11:49 AM
Lakewood, Colorado
herkamer Offline
herkamer  Offline
Lakewood, Colorado
It's a challenge. To get the TBI working on my W350, I scavenged all the parts I needed and formulated a plan to make it happen. Since I went Megasquirt it was a little bit different than swapping factory parts. I started with a used Holley ProJection 2bbl kit, and built the wiring harness with the extras I needed. You will need a high pressure fuel pump and likely a return line for excess. I used a TBI tank that was a direct fit. I would suspect a van tank would swap with minimal fabrication. If you have the patience, it shouldn't be terribly difficult. Plan on spending some time to get it working correctly.
Matt
69 Dart Swinger 340
83 W350, Megasquirted with 46RH
Old news: 72 Demon street/race mobile
Latest: 70 Duster backhalf car
and even more
