Best way to clean plastic splash shields, cowl screens #1438250
05/18/13 11:00 AM
05/18/13 11:00 AM
Toronto (YYZ) Ontario
YYZ Offline OP
YYZ  Offline OP
What is the best method and cleaning materials to return the black plastic splash shields (headlight, fender, frame) and cowl screens to a like-new appearance?
Without resorting to armor-all or other plastic dressings or dyes...
Thanks in advance
Re: Best way to clean plastic splash shields, cowl screens [Re: YYZ] #1438251
05/18/13 11:05 AM
05/18/13 11:05 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
When talking about ABS or Polyethylene parts a soak in warm caustic soda soloution works well to clean them. To bring back the original lustre after it becomes dull or discolored from age/UV degredation, etc. there's is no way to do that, once the plasticizers in the material have changed or degraded it's not reversable. An application of topical dressing is the answer, and it will likely have to be reapplied from time to time to keep it that way depending on the environment the car is in.
Re: Best way to clean plastic splash shields, cowl screens [Re: ScottSmith_Harms] #1438252
05/18/13 12:05 PM
05/18/13 12:05 PM
YYZ Offline OP
YYZ  Offline OP
So just how caustic? Lye/sodium hydroxide caustic or? Suggested products?
The black plastic is still quite pliable and appears to have good depth of colour. However, some of the pieces have residual undercoating and/or overspray which I'd like to remove without resorting to scraping or blasting, which replaces one set of problems with another
Re: Best way to clean plastic splash shields, cowl screens [Re: YYZ] #1438253
05/18/13 12:41 PM
05/18/13 12:41 PM
New State
kidmopar Offline
kidmopar  Offline
New State
My ..........
I've actually had decent luck letting them soak in a 'bath' of that "Purple" cleaner (under
various brands) . Especially if it's had overspray on them from a previous 'quickee'
paint job. I soak for couple days and go over with a soft brush ...
Re: Best way to clean plastic splash shields, cowl screens [Re: YYZ] #1438254
05/18/13 12:47 PM
05/18/13 12:47 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
My cowl screens had some over spray on them from a previous repaint. I soaked them in old brake fluid to remove the paint. They were slightly discolored so I misted some trim black on them. Not OE but they look good. They are in a dimly lit area so you can't tell there's paint on them.
After power washing the undercoating off the splash shields, they were in good shape. They will get sprayed with more undercoating so I didn't go crazy with them.
Re: Best way to clean plastic splash shields, cowl screens [Re: YYZ] #1438255
05/18/13 01:00 PM
05/18/13 01:00 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
I bought the stuff I use in B.C.Canada at a company called Magnus industries, it was many years ago and came in powdered form to be mixed with water. I think they sell it in liqyuid form now. Any machine shop should be able to get some for you. It works especially well to remove paint off of plastic.
As a backup keep in mind that Polyethylene/Polypropylene plastics (which is what those two items happen to be made from) is HIGHLY resistant to most acids and chemicals. in fact most of those chemicals are sold in containers made of PP/PE. So pretty much any chemical you use will be safe on those parts.
As an aside, if you are unsure of what type of plastc parts you are working with ALWAYS test a small spot first, all plastics are NOT created equal!
Re: Best way to clean plastic splash shields, cowl screens [Re: ScottSmith_Harms] #1438256
05/18/13 03:16 PM
05/18/13 03:16 PM
Southern by Choice
Shoozy Offline
I have a foot fetish
Shoozy  Offline
Southern by Choice
Remember that an easily available sodium hydroxide solution is drain cleaner (Drano).
Old, tired, and sometimes broke down. Me, not my car...
Re: Best way to clean plastic splash shields, cowl screens [Re: YYZ] #1438257
05/18/13 03:48 PM
05/18/13 03:48 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Did mine with Simple Green, and swabbed-em with silicone...
Re: Best way to clean plastic splash shields, cowl screens [Re: RSNOMO] #1438258
05/18/13 06:37 PM
05/18/13 06:37 PM
Ridgeland Wi
mopars_1 Offline
mopars_1  Offline
Ridgeland Wi
oven cleaner + scrubbing and then some sort of plastic or rubber dressing will make it look like new also
1971 Plymouth Duster 340 auto
1937 Plymouth PT50
1969 Dodge Dart Swinger 340 4 speed
2013 Ram laramie 2500 hemi
2008 Harley FLSTSB springer
Re: Best way to clean plastic splash shields, cowl screens [Re: mopars_1] #1438259
05/19/13 08:03 AM
05/19/13 08:03 AM
YYZ Offline OP
YYZ  Offline OP
I used some oven cleaner as I had some on hand - it has worked out very well
Thanks all for the suggestions
