Re: Best way to clean plastic splash shields, cowl screens
[Re: YYZ]
#1438253
05/18/13 12:41 PM
05/18/13 12:41 PM
Posts: 3,821 New State
kidmopar
New State
My .......... I've actually had decent luck letting them soak in a 'bath' of that "Purple" cleaner (under various brands) . Especially if it's had overspray on them from a previous 'quickee' paint job. I soak for couple days and go over with a soft brush ...
[Re: YYZ]
#1438255
05/18/13 01:00 PM
05/18/13 01:00 PM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
So just how caustic? Lye/sodium hydroxide caustic or? Suggested products?
I bought the stuff I use in B.C.Canada at a company called Magnus industries, it was many years ago and came in powdered form to be mixed with water. I think they sell it in liqyuid form now. Any machine shop should be able to get some for you. It works especially well to remove paint off of plastic.
As a backup keep in mind that Polyethylene/Polypropylene plastics (which is what those two items happen to be made from) is HIGHLY resistant to most acids and chemicals. in fact most of those chemicals are sold in containers made of PP/PE. So pretty much any chemical you use will be safe on those parts.
As an aside, if you are unsure of what type of plastc parts you are working with ALWAYS test a small spot first, all plastics are NOT created equal!
[Re: RSNOMO]
#1438258
05/18/13 06:37 PM
05/18/13 06:37 PM
Posts: 3,106 Ridgeland Wi
mopars_1
Ridgeland Wi
oven cleaner + scrubbing and then some sort of plastic or rubber dressing will make it look like new also
1971 Plymouth Duster 340 auto 1937 Plymouth PT50 1969 Dodge Dart Swinger 340 4 speed 2013 Ram laramie 2500 hemi 2008 Harley FLSTSB springer
