distributor help needed #1434979
05/12/13 10:19 AM
05/12/13 10:19 AM
Lincoln NE
440forPOWER Offline OP
super gas
super gas
Lincoln NE
Hello, I bought a Mopar distributor from FBO. It was suppose to be setup for my combo. I bought it for a new 470 street combo. When I tried to start the car it had no spark. Threw the old distributor for the original 383 instant fire.
I realized the pickup gap was way off. So I set it and tried it again. It popped right off. But if I gave it any gas at all it loaded up and backfired through the exhaust. What could be causing this? Should I replace the pickup? Good thing I paid extra to have this setup for my combo. Thanks FBO
Re: distributor help needed [Re: 440forPOWER] #1434980
05/12/13 10:31 AM
05/12/13 10:31 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Could be the pick up or the phasing is out
Re: distributor help needed [Re: MR_P_BODY] #1434981
05/12/13 12:13 PM
05/12/13 12:13 PM
Ste-Sophie, Quebec, Canada
W
Wedgeman Offline
Wedgeman  Offline
W
I just had exactly the same problem with mine last week in my small block.....
turned out the reluctor under the rotor was in the slot for a big block.
There is a slot with lock pin for clockwise rotation(sb) and couter clockwise rotation (bb).
You want to check that out...
Just a guess from my experience
Dan
Re: distributor help needed [Re: 440forPOWER] #1434982
05/12/13 01:32 PM
05/12/13 01:32 PM
B.C. Canada
hankcrank Offline
hankcrank  Offline
B.C. Canada
If the dist. is not a locked in advance position style the mechanical advance might not be advancing. With the cap off grab the rotor and see if it will move counter clockwise and then return to it's original position. Just might need a little lube. Hope this helps good luck.
Re: distributor help needed [Re: hankcrank] #1434983
05/12/13 02:13 PM
05/12/13 02:13 PM
Overland Park, KS.
Joshs68 Offline
Joshs68  Offline
Overland Park, KS.
That sucks. I have an FBO in my 470 and it works great. Call them or send it back.
Re: distributor help needed [Re: Joshs68] #1434984
05/12/13 02:18 PM
05/12/13 02:18 PM
Lincoln NE
super gas
super gas
Lincoln NE
Hi Josh hows it going. I tried giving him a call and keep getting the run around. He also charged me for a msd pigtail that I never received. I was told not once but on 4 different occasions that it would be sent out. Never received it. Never see another dime from me.
Re: distributor help needed [Re: 440forPOWER] #1434985
05/12/13 03:02 PM
05/12/13 03:02 PM
Cleveland
sunroofgtx Offline
sunroofgtx  Offline
Cleveland
Give me a call. You can have a Firecore this week. Guarantee you will like it. Low deck? Plug and play into your Chrysler Electronic?
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
Re: distributor help needed [Re: MR_P_BODY] #1434986
05/13/13 11:38 AM
05/13/13 11:38 AM
Lincoln NE
super gas
super gas
Lincoln NE
Would having the polarity on the mag pickup reversed cause the backfire out of the exhaust and run like crap under load? Thanks
Re: distributor help needed [Re: 440forPOWER] #1434987
05/13/13 12:09 PM
05/13/13 12:09 PM
San Diego
formula S Offline
formula S  Offline
San Diego
yes
Re: distributor help needed [Re: 440forPOWER] #1434988
05/13/13 12:12 PM
05/13/13 12:12 PM
MR_P_BODY Offline
MR_P_BODY  Offline
It can... its like changing the timing(it reads on
the other side of the relutor.. on the closing side
VS the opening side)
Re: distributor help needed [Re: MR_P_BODY] #1434989
05/13/13 02:18 PM
05/13/13 02:18 PM
Lincoln NE
super gas
super gas
Lincoln NE
OK, I'll have to check that out. I thought it would just change the timing a bit. But this just popped and backfired under any load. I noticed the colors of the wires coming off the mag pickup are reversed between the two distributors.
