Re: Progress for today.
[Re: VernMotor]
#1434848
05/11/13 11:03 PM
05/11/13 11:03 PM
Posts: 20,197 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I had an issue with that timing chain cover on my car years ago before I switched over to a billit one. The cam button was deflecting the cover and letting the cam thrust forward making my timing jump. Some guys reinforced their cover on the inside and maybe you did. If not and you still have the intake off see if the cover is deflecting as you GENTLY pry the cam forward. Other than that it looks GREAT and you will be hitting the track soon.
[Re: pittsburghracer]
#1434850
05/11/13 11:09 PM
05/11/13 11:09 PM
dartman366
Mt. Vernon, Ohio
I see the boss was out in the garage also,,,,,thats why you got so much done today.
[Re: VernMotor]
#1434857
05/12/13 03:06 PM
05/12/13 03:06 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Looks good Jamie... I see your running a motor mount... do you run rubber on the drivers side also or is it a solid
[Re: MR_P_BODY]
#1434860
05/12/13 06:22 PM
05/12/13 06:22 PM
Posts: 7,348 Mt.Vernon ,Ohio
VernMotor
Mt.Vernon ,Ohio
They are both solid..
