Progress for today.Day two add'ed #1434847
05/11/13 10:48 PM
05/11/13 10:48 PM
Mt.Vernon ,Ohio
VernMotor Offline OP
Mt.Vernon ,Ohio
This morning I put the girdle-windage tray- pick up and pan on .. I was late to start taking pics
All the non shiny stuff done bell housing bolts-torque converter bolts-headers-mufflers-starter-steering column-motor mount bolts-some wiring.alt-water pump and drive.oil pressure line.
cute little mufflers
Re: Progress for today. [Re: VernMotor] #1434848
05/11/13 11:03 PM
05/11/13 11:03 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I had an issue with that timing chain cover on my car years ago before I switched over to a billit one. The cam button was deflecting the cover and letting the cam thrust forward making my timing jump. Some guys reinforced their cover on the inside and maybe you did. If not and you still have the intake off see if the cover is deflecting as you GENTLY pry the cam forward. Other than that it looks GREAT and you will be hitting the track soon.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Progress for today. [Re: pittsburghracer] #1434849
05/11/13 11:09 PM
05/11/13 11:09 PM
Mt.Vernon ,Ohio
Mt.Vernon ,Ohio
I don't run a cam button on this combo. timing is good. I never seen a mark on the inside of the cover in 800 runs. I did have to put a collar on the Drist-shaft. to keep the timing from moving around.
Re: Progress for today. [Re: pittsburghracer] #1434850
05/11/13 11:09 PM
05/11/13 11:09 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
I see the boss was out in the garage also,,,,,thats why you got so much done today.
Re: Progress for today. [Re: dartman366] #1434851
05/11/13 11:10 PM
05/11/13 11:10 PM
Mt.Vernon ,Ohio
Mt.Vernon ,Ohio
You got that chit right..she had her whip out !
Re: Progress for today. [Re: VernMotor] #1434852
05/11/13 11:14 PM
05/11/13 11:14 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
Re: Progress for today. [Re: dartman366] #1434853
05/12/13 08:33 AM
05/12/13 08:33 AM
tboomer Online work
tboomer  Online Work
Looks good,Vern!
Re: Progress for today. [Re: tboomer] #1434854
05/12/13 11:19 AM
05/12/13 11:19 AM
GO BUCKS !!!!!!!
3
340RICK Offline
340RICK  Offline
GO BUCKS !!!!!!!
Lookin good Jamie, I liked the men working sign on the wall
Re: Progress for today. [Re: VernMotor] #1434855
05/12/13 12:24 PM
05/12/13 12:24 PM
mi
RATPATROL Offline
RATPATROL  Offline
mi
what type of head gaskets are those, they don't look like felpro, and i'm looking for a new composite gasket to try. thanks.
Re: Progress for today. [Re: 340RICK] #1434856
05/12/13 12:30 PM
05/12/13 12:30 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
Looks to me like sign should read..."Woman working...man taking pictures".
If you like drag racing, support your local track.
Re: Progress for today. [Re: VernMotor] #1434857
05/12/13 03:06 PM
05/12/13 03:06 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Looks good Jamie... I see your running a motor mount...
do you run rubber on the drivers side also or is it
a solid
Re: Progress for today. [Re: VernMotor] #1434858
05/12/13 03:45 PM
05/12/13 03:45 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
Thanks for the pics,as long as you make progress sometimes that is all we can do.
Re: Progress for today. [Re: RATPATROL] #1434859
05/12/13 06:21 PM
05/12/13 06:21 PM
Mt.Vernon ,Ohio
Mt.Vernon ,Ohio
http://www.summitracing.com/parts/fel-17059
Re: Progress for today. [Re: MR_P_BODY] #1434860
05/12/13 06:22 PM
05/12/13 06:22 PM
Mt.Vernon ,Ohio
Mt.Vernon ,Ohio
a solid
They are both solid..
Re: Progress for today. [Re: VernMotor] #1434861
05/12/13 08:07 PM
05/12/13 08:07 PM
Mt.Vernon ,Ohio
Mt.Vernon ,Ohio
I add'ed day two to the first post
Re: Progress for today. [Re: VernMotor] #1434862
05/12/13 08:30 PM
05/12/13 08:30 PM
Renton Washington
Triple Threat Offline
Renton Washington
Coming right along
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
