70 Cigar Lighter Shell & Clamp #1434824
05/11/13 10:17 PM
05/11/13 10:17 PM
Dry Heat AZ
AAR#2 Offline OP
AAR#2  Offline OP
Dry Heat AZ
I just picked up a shell and clamp for my 70 'Cuda PN2932727 or so it should be, and after disassembly and cleaning I decided to test it . . . but with the barrel shown at the right of the photo (seems to be an isolator of sorts), I cant seem to get continuity . . . no matter the scenario, lighter in or just jumping from the stud to the retainer inside the shell.
So I check with a buddy who has several 'Cudas (one since new) and he says his don't have that on the back of the shell. So now I unscrew the thingy on the right, and with the lighter depressed )like I want to light one up, I get continuity.
So what is this thing and who uses it??
Re: 70 Cigar Lighter Shell & Clamp [Re: AAR#2] #1434825
05/11/13 10:18 PM
05/11/13 10:18 PM
Dry Heat AZ
AAR#2 Offline OP
AAR#2  Offline OP
Dry Heat AZ
another shot
Re: 70 Cigar Lighter Shell & Clamp [Re: AAR#2] #1434826
05/12/13 12:50 PM
05/12/13 12:50 PM
Dry Heat AZ
AAR#2 Offline OP
AAR#2  Offline OP
Dry Heat AZ
OK, since I posted this thing, heres the answer in the event someone else see's this . . . apparently its a 50-60's Ford resettable breaker for a lighter . . . Poking around e-bay helped me to find this;
http://www.ebay.com/itm/54-55-56-57-58-5...d81&vxp=mtr
http://www.ebay.com/itm/FEW14429A-1952-6...2c9&vxp=mtr
So now my question is changing to questions on the shell and clamp;
Pictures from an original 70 'Cuda as well as dimensions and finish would be appreciated.
Thanks for the help
Re: 70 Cigar Lighter Shell & Clamp [Re: AAR#2] #1434827
05/15/13 11:09 AM
05/15/13 11:09 AM
Dry Heat AZ
AAR#2 Offline OP
AAR#2  Offline OP
Dry Heat AZ
Anyone ?
Picture of original shell and clamp?
Finish? Phosphate ? Bright zinc?
Couple dimensions?
Re: 70 Cigar Lighter Shell & Clamp [Re: AAR#2] #1434828
05/16/13 07:53 AM
05/16/13 07:53 AM
CT
1932chrysler Offline
CT
All the car company's used a fuse like that at one time or another
1932 Chrysler CI Sedan
1956 Pontiac Catalina Sedan
All Makes & Models Are Special
Re: 70 Cigar Lighter Shell & Clamp [Re: AAR#2] #1434829
05/17/13 06:14 PM
05/17/13 06:14 PM
Minneapolis, MN
hemi70se Offline
hemi70se  Offline
Minneapolis, MN
By the way, that Knurled knob is incorrect, should be smooth on a 1970
Re: 70 Cigar Lighter Shell & Clamp [Re: hemi70se] #1434830
05/18/13 10:33 AM
05/18/13 10:33 AM
Dry Heat AZ
AAR#2 Offline OP
AAR#2  Offline OP
Dry Heat AZ
Others have made similar statements, but believe the knurled knob may have been used in certain models, perhaps different suppliers, considering there is but one PN for knobs in 1970 & 71 (2290188) with cases of both smooth and knurled being found in original owner cars, I'd be cautious to make a definitive statement like "that knurled knob is incorrect." We are talking Mopar after all.
That said, I plan to continue to search for a smooth one in great condition as I believe it was more prevalent, and generally accepted as the norm.
