cooling system stop leak recommendation, pls? #1434574
05/11/13 02:08 PM
05/11/13 02:08 PM
Louisiana
rnch Offline OP
rnch  Offline OP
Louisiana
My '85 Ram (318, 120K) must be "burning" a small amount of anti-freeze, about 12 ounces every 300 miles.
I say this because: All new heater & radiator hoses, new pressure cap, no obvious leaks in around the engine/hoses/radiator. The exhaust pipe is often "wet" inside and the ground under the tail pipe tip shows fluid build up when idled in one place for an extended period of time. The overflow tank goes down about 2 inches every 300 miles.
No evidence of antifreeze on the oil dipstick, never overheats, even with the A/C on and in stop & go traffic.
Can someone here please recommend a stop leak that will slow/fix this slow leak...but NOT stop up the radiator/colling system and make it overheat?
Or should I just continue to keep an eye on the overflow tank level and keep adding antifreeze/water? Perhaps this is not worth doing anything about??
Thanks!
Re: cooling system stop leak recommendation, pls? [Re: rnch] #1434575
05/11/13 03:02 PM
05/11/13 03:02 PM
N
NITROUSN Online content
NITROUSN  Online Content
N
Bars leak tablets. Gm uses them. They work real well. Dont use the liquid bars leak or silver seal.
Re: cooling system stop leak recommendation, pls? [Re: rnch] #1434576
05/11/13 03:03 PM
05/11/13 03:03 PM
N
N
Here is a link with the part number. web page
Re: cooling system stop leak recommendation, pls? [Re: NITROUSN] #1434577
05/11/13 04:03 PM
05/11/13 04:03 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Thanx for that, I have a similar problem and was going to ask this same question.
I have mechanical Aptitude.
I can screw up anything.
Re: cooling system stop leak recommendation, pls? [Re: bboogieart] #1434578
05/11/13 05:50 PM
05/11/13 05:50 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Find the problem and fix it !! Dont try to cover it up with somekind of a band aid. Sounds like a head gasket is going bad ..
I am truckless..
Re: cooling system stop leak recommendation, pls? [Re: rnch] #1434579
05/11/13 05:56 PM
05/11/13 05:56 PM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
coarse ground black pepper also works. it slips into places where there is seepage, then it swells, stopping the leak. seriously.
Re: cooling system stop leak recommendation, pls? [Re: 340SHORTY] #1434580
05/12/13 06:01 PM
05/12/13 06:01 PM
Louisiana
rnch Offline OP
rnch  Offline OP
Louisiana
In a Perfect World, perhaps. But for a "back up vehicle" that I won't even put 3K a year on.......
Re: cooling system stop leak recommendation, pls? [Re: rnch] #1434581
05/12/13 06:32 PM
05/12/13 06:32 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
There should be some water at your tailpipe. Most all vehicles spit moisture at the tailpipe. Hence the exhaust Rusting at all the low spots.
As for it being a backup vehicle I second fixing it right. You'll kick yourself in the Azz when you have to price it do to other vehicle needing repairs and it blows a head gasket or something else
Re: cooling system stop leak recommendation, pls? [Re: 76dodgeboy] #1434582
05/12/13 06:36 PM
05/12/13 06:36 PM
Louisiana
rnch Offline OP
rnch  Offline OP
Louisiana
I'm still not totally convinced it has a blown head gasket. It NEVER overheats, even when stuck in stop-n-go traffic with the A/C on full blast, idles so smooth I can count each cylinder firing, a recent spark plug change showed NO variance from plug to plug on color or deposits build ups.
Still, the anti-freeze is going somewhere......
Re: cooling system stop leak recommendation, pls? [Re: rnch] #1434583
05/12/13 07:45 PM
05/12/13 07:45 PM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
go to the parts store, and get a uv dye kit, with a blacklight pen. add the dye, run the car, then get out and find the leak. if it is leaking into the combustion chambers, it will still fluoresce at the tailpipe, and be visible with the light. the kit costs like 15-50 bucks, depending on how fancy you go. can be used in oil, a/c and water stuff, to find almost any leaks.
FIND YOUR LEAK
Re: cooling system stop leak recommendation, pls? [Re: Golden-Arm] #1434584
05/12/13 08:08 PM
05/12/13 08:08 PM
Louisiana
rnch Offline OP
rnch  Offline OP
Louisiana
FIND YOUR LEAK
Excellent idea and product! Gotta settle this in my own mind before any repairs (stop gap or pernament) are done; I can use this tool on multiple cars of mine.
Re: cooling system stop leak recommendation, pls? [Re: rnch] #1434585
05/12/13 09:01 PM
05/12/13 09:01 PM
Maine
jerseybud Offline
jerseybud  Offline
Maine
1. I agree about the pellets. I have used them in 1/4s or 1/8s, not whole ones
2. Check your timing chain cover and water pump weep hole. They love to leak and be sneaky about it, and can be temperature dependent (ie leaks when warm not hot, T-stat not open, but never any other time, etc)
Re: cooling system stop leak recommendation, pls? [Re: rnch] #1434586
05/12/13 10:00 PM
05/12/13 10:00 PM
tennessee
P
pushbutton Offline
pushbutton  Offline
P
tennessee
Look real close around the thermostat housing,it could have a slight leak that engine heat is drying up.
Re: cooling system stop leak recommendation, pls? [Re: pushbutton] #1434587
05/12/13 11:47 PM
05/12/13 11:47 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Blown head gasket doesn't always cause it to overheat. It can be going into your oil pan. It could leak just about anywhere and as stated heat could be drying it rite up.
I didn't know they had the dye for coolant systems. Good to know
Re: cooling system stop leak recommendation, pls? [Re: rnch] #1434588
05/13/13 07:05 PM
05/13/13 07:05 PM
beedees Offline
beedees  Offline
Taste the water @ the tailpipe, if it's not sweet-drop a tablet in it.
Re: cooling system stop leak recommendation, pls? [Re: beedees] #1434589
05/13/13 08:57 PM
05/13/13 08:57 PM
Lehigh Acres, Florida
rickstershemi Offline
and don't burn your lips on the tailpipe
