64 Polara slick width #1434350
05/11/13 08:15 AM
05/11/13 08:15 AM
NEW JERSEY
dynamite Offline OP
dynamite  Offline OP
NEW JERSEY
Anyone know how wide a slick I can fit under a stock body 64 Dodge Polara ?? 8 3/4 rear..without using the spring kit....stock suspension ,,more for show than go...just want the widest tire to fit there..Yes I know I can measure it but the car is 100 miles away from here and I want to bring the tires and wheels with me..thanks
Re: 64 Polara slick width [Re: dynamite] #1434351
05/11/13 08:59 AM
05/11/13 08:59 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I was running M&H 30x 10.5 x 15s on my 65 B body.They are pretty much the same body.Rocky
Chrysler Firepower
Re: 64 Polara slick width [Re: therocks] #1434352
05/11/13 09:14 AM
05/11/13 09:14 AM
NEW JERSEY
dynamite Offline OP
dynamite  Offline OP
NEW JERSEY
Thanks Yankee lover..(me too)..were those slicks the max that would fit ??
Re: 64 Polara slick width [Re: dynamite] #1434353
05/11/13 10:27 AM
05/11/13 10:27 AM
Howell,MI
Moparpoor Offline
Moparpoor  Offline
Howell,MI
30 x10.5 would be max. Wheel tubs will fit larger tire width just the front of the spring limits it. You really need to look at the section width of the tire 13.5 would be max section width. Of course that varies with manufacturer and tire design!
Re: 64 Polara slick width [Re: Moparpoor] #1434354
05/11/13 10:41 AM
05/11/13 10:41 AM
Az
Crizila Offline
Crizila  Offline
Az
- the pic.
Fastest 300
Re: 64 Polara slick width [Re: Crizila] #1434355
05/11/13 10:59 AM
05/11/13 10:59 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Mine were close.I might have been able to go 11 but never measured.I run almost 11.5 Mickeys on the rear now.It has a wider 69 rear in it now.To get them fully under the car I need 6 1/2 BS on my wheels.Ill have to inboard the springs though.Rocky
Chrysler Firepower
Re: 64 Polara slick width [Re: therocks] #1434356
05/11/13 03:56 PM
05/11/13 03:56 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
I put 275/60R15 T/A Radials on 15x10 Americans under my Polara. I got the wheels and tires first, did the measuring then cut a Dana 60 to fit. I did not move the springs and had plenty of clearance. The pictures I have are too big to post, but if anyone needs one send me a PM and include your e-mail address.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: 64 Polara slick width [Re: Polarapete] #1434357
05/11/13 05:14 PM
05/11/13 05:14 PM
Ohio
Cincylance Offline
Cincylance  Offline
Ohio
I run 15x7 stock steel wheels with M&H 275/60/15 drag radials with a Dana 60 rearend. Stock everything, everything fits. Couldn't go much wider before the tires would rub the qtr panels. Car is a 64 Plymouth Fury.
Cincylance
