Re: 440 Stroker Build Questions
[Re: 74-440Charger]
#1434183
05/12/13 10:20 PM
05/12/13 10:20 PM
Posts: 1,221 Jarrettsville, MD
tywebb2
super gas
super gas
Jarrettsville, MD
Why would you go with a stroked 400 over a 440? I thought there was no replacement for displacement? I have the 440 block now..... what is the advantage of the 400?
'72 440 Cuda 11.673 @ 115.91 w/1.663 60'
[Re: 383man]
#1434187
05/13/13 12:59 AM
05/13/13 12:59 AM
tywebb2
super gas
super gas
Jarrettsville, MD
600 hp is more than enough for my cuda. Running best of 11.673 now and would like to be able to run low 11's without breaking a sweat while keeping it streetable. I have caltracs with mono leafs so hopefully I can get the extra torque to the ground? Will an 8.75" rear hold up though?
How many hp would you estimate my current 440 is making? It .030 over, stock crank, stock rods, trw six pax pistons (not zero decked), 9.9:1 compression, ootb eddy 84cc heads, rpm intake, comp pro mag rockers, 850 mighty demon, msd 6al, 2" primaries to 3.5" collector with 3" exhaust, 509 hyd cam.
[Re: tywebb2]
#1434188
05/13/13 01:13 AM
05/13/13 01:13 AM
Posts: 2,859 Pattison Texas
CSK
Pattison Texas
guessing on 3700 with driver ? 474 hp ie wallace calculator .
[Re: 74-440Charger]
#1434190
05/13/13 07:47 AM
05/13/13 07:47 AM
Posts: 3,619 Norwich CT USA
Defbob
Norwich CT USA
Congrats on a nice build. I am curious about the headers you used and how you got them to clear the head studs, it looks like they will hit.
I the car has some old Hooker Super Comp 1-7/8" headers and they cleared the studs with no problem. Motor needs 2" or 2-1/8" headers.
[Re: tywebb2]
#1434191
05/13/13 10:40 AM
05/13/13 10:40 AM
Posts: 75,005 U.S.S.A.
JohnRR
U.S.S.A.
What's in your motor for parts doesn't help HP calculation , your MPH is in your sig 115 and change , what does the car weigh with you in it ?
[Re: JohnRR]
#1434192
05/13/13 01:42 PM
05/13/13 01:42 PM
tywebb2
super gas
super gas
Jarrettsville, MD
It has been many years since I weighed the car but it is a full interior car with alum heads, prostar wheels, and caltracs. Can't think of any other areas where I would have shaved considerable weigh off. I weigh 150 so I am guessing the car with me in it is around 3600lbs.
[Re: BradH]
#1434195
05/13/13 05:21 PM
05/13/13 05:21 PM
JohnRR
U.S.S.A.
OK, here's the dissenting opinion about to rear it's ugly (and balding) head: If all you want is low 11s (per your above statement), you don't need to build a stroker. A stronger stock-stroke 440 will get you there, plus your current 4.10 gear & 28" tire combination will be well suited to the shorter-stroke combination's RPM range on the track.
IMO, you should... - port the E heads - run a fairly aggressive solid flat-tappet cam - run a good single-plane intake (not sure what you have now) - build for about 10.5 CR to stay safe on 93-octane pump fuel
A 440 in that HP range would probably be just as happy (maybe happier) w/ 1-7/8" headers. But since I think you said you already have 2", run what you got.
You may need to change converters, but that depends on how your current one works w/ the new engine. The biggest hit on performance will be if the 10" doesn't let you 60-ft. as well as something a little looser.
FWIW, this is both opinion and fact-based from the results I've seen on my own builds.
He seemed set of going with a stroker and the thinking now is bigger is better ...
[Re: JohnRR]
#1434196
05/13/13 06:51 PM
05/13/13 06:51 PM
Posts: 2,463 Sydney,Australia
tex013
Sydney,Australia
either motor will do it,the stroker easier. if starting from scratch the stroker is a no brainer.personally thinking running low 11's high 10's shouldn,t be a problem . my 440 has run 10.99 pb and will normally run around 11.1@120mph,this is at around 3720lbs(68 Satellite). no high end gear but well sorted. Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: tex013]
#1434197
05/13/13 08:16 PM
05/13/13 08:16 PM
tywebb2
super gas
super gas
Jarrettsville, MD
I hate to say it but the thought also crossed my mind after reading 600hp is the limit, etc. with the 440 block. Could a stroker be overkill for my application and just open up other cans of worm? I'm curious....what hp is my 8 3/4 rear good too? I have no interest in upgrading to a dana.
The major issue I have with my engine now is the TRW pistons. The valve notches are too small for the Eddy valves and I am at the limit of my valve clearance and my compression is a bit low (9.9:1) with pistons down in hole (bad quench height).
Would it make more sense just to swap out the stock rods with H-beams and get a new set of pistons....then possibly CNC porting the heads? Would I still need to zero deck the block or could I buy pistons off the shelf that would put me where I need to be out of the box? Then with my piston-to-valve clearance opened up I could go with a different cam.
I put the numbers in a hp calculator and it came back at 519hp if my weight figure is correct. How much do you think I would pick-up (hp and et) getting the proper quench height, 10.5:1 compression, better cam, cnc ported eddy heads?
