Page 2 of 3 1 2 3
Re: 440 Stroker Build Questions [Re: gregsdart] #1434179
05/12/13 01:38 PM
05/12/13 01:38 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
I would go with the 4.25 stoker kit.
Here is a link to my motor build 511ci build
Re: 440 Stroker Build Questions [Re: Defbob] #1434180
05/12/13 08:35 PM
05/12/13 08:35 PM
Missouri
Challenger Offline
Challenger  Offline
Missouri
I don't think those alky cranks have the flywheel ring on the back of the crank to center the flywheel? But I could be wrong!
Re: 440 Stroker Build Questions [Re: Challenger] #1434181
05/12/13 09:10 PM
05/12/13 09:10 PM
jonestown,pa
dmking Offline
dmking  Offline
jonestown,pa
is this 76 block at least the one with the thicker mains and wider bore supports?
just watch what amount you want from the 440 block in the end
i split mine up through the middle 3 mains on a 73 block. i am using a thicker 76 but this is the last 440 based block i build. i got lucky it did not destroy anything parts wise.
on my a body i had to remove the stock engine mount on driver side with the external oil pickup.
if you are starting from scratch build a 400 low deck stroker.
Re: 440 Stroker Build Questions [Re: Defbob] #1434182
05/12/13 09:29 PM
05/12/13 09:29 PM
FL
74-440Charger Offline
FL
Congrats on a nice build. I am curious about the headers you used and how you got them to clear the head studs, it looks like they will hit.
Re: 440 Stroker Build Questions [Re: 74-440Charger] #1434183
05/12/13 10:20 PM
05/12/13 10:20 PM
Jarrettsville, MD
tywebb2 Offline OP
super gas
tywebb2  Offline OP
super gas
Jarrettsville, MD
Why would you go with a stroked 400 over a 440? I thought there was no replacement for displacement? I have the 440 block now..... what is the advantage of the 400?
'72 440 Cuda
11.673 @ 115.91 w/1.663 60'
Re: 440 Stroker Build Questions [Re: tywebb2] #1434184
05/12/13 10:46 PM
05/12/13 10:46 PM
IN
ahy Offline
ahy  Offline
IN
Rule of thumb, the stock block starts getting iffy around 600 HP without extra effort like girdles and block fill. Low decks have their + and -. The shorter bores are stiffer which is a plus. On the minus side, a stroker needs a shorter rod, short piston (low compression height) or both.
With Eddy heads, you will be under 600 HP unless its a max effort, fully ported big cam build.
For what you are doing the RB should be fine. The longer rod/taller piston can help it last longer.
Re: 440 Stroker Build Questions [Re: tywebb2] #1434185
05/13/13 12:11 AM
05/13/13 12:11 AM
The stock bore size on the 400 is 4.342, correct? As already said the 400 blocks are a lot stouter(thicker) in the main webs than the same year 440 blocks are so it is a better peice to start with My current 400 block with a 4.25 stroke crank in it(11.29 to 1 comp. ratio, 505 C.I.) has made 687 HP at 6300 RPM with a set of Eddy RPM CNC ported by Jeff at MCH with a Mopar 4500 M1 intake and a Holley 1050 CFM Dominator on it Better heads and more compression would make more power My 518 motor made 727 HP with a set of Indy SR max wedge ports and the same carb. as this one ran on Oregon pump gas
Re: 440 Stroker Build Questions [Re: Cab_Burge] #1434186
05/13/13 12:35 AM
05/13/13 12:35 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
The 440 block will work fine up to 600 hp or a bit more. I used the 440 in case I want to run a crossram intake one day. I never dynoed mine but I would guess about 600 hp to push my 3700 lb 63 to 10.70's at almost 125 mph thru the pipes on 92 pump. Ron
Re: 440 Stroker Build Questions [Re: 383man] #1434187
05/13/13 12:59 AM
05/13/13 12:59 AM
Jarrettsville, MD
tywebb2 Offline OP
super gas
tywebb2  Offline OP
super gas
Jarrettsville, MD
600 hp is more than enough for my cuda. Running best of 11.673 now and would like to be able to run low 11's without breaking a sweat while keeping it streetable. I have caltracs with mono leafs so hopefully I can get the extra torque to the ground? Will an 8.75" rear hold up though?
How many hp would you estimate my current 440 is making? It .030 over, stock crank, stock rods, trw six pax pistons (not zero decked), 9.9:1 compression, ootb eddy 84cc heads, rpm intake, comp pro mag rockers, 850 mighty demon, msd 6al, 2" primaries to 3.5" collector with 3" exhaust, 509 hyd cam.
'72 440 Cuda
Re: 440 Stroker Build Questions [Re: tywebb2] #1434188
05/13/13 01:13 AM
05/13/13 01:13 AM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
guessing on 3700 with driver ? 474 hp ie wallace calculator .
Re: 440 Stroker Build Questions [Re: tywebb2] #1434189
05/13/13 01:34 AM
05/13/13 01:34 AM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
I was kinda leaning towards the 4.25. Would it be bad if I didn't port the eddy heads?
yes
Re: 440 Stroker Build Questions [Re: 74-440Charger] #1434190
05/13/13 07:47 AM
05/13/13 07:47 AM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
I the car has some old Hooker Super Comp 1-7/8" headers and they cleared the studs with no problem. Motor needs 2" or 2-1/8" headers.
Re: 440 Stroker Build Questions [Re: tywebb2] #1434191
05/13/13 10:40 AM
05/13/13 10:40 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
What's in your motor for parts doesn't help HP calculation , your MPH is in your sig 115 and change , what does the car weigh with you in it ?
Re: 440 Stroker Build Questions [Re: JohnRR] #1434192
05/13/13 01:42 PM
05/13/13 01:42 PM
Jarrettsville, MD
tywebb2 Offline OP
super gas
tywebb2  Offline OP
super gas
Jarrettsville, MD
It has been many years since I weighed the car but it is a full interior car with alum heads, prostar wheels, and caltracs. Can't think of any other areas where I would have shaved considerable weigh off. I weigh 150 so I am guessing the car with me in it is around 3600lbs.
'72 440 Cuda
Re: 440 Stroker Build Questions [Re: tywebb2] #1434193
05/13/13 02:46 PM
05/13/13 02:46 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
Vfn dash, vfn pro nose, vfn trunklid, glass rear bumper
Re: 440 Stroker Build Questions [Re: tywebb2] #1434194
05/13/13 03:53 PM
05/13/13 03:53 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
OK, here's the dissenting opinion about to rear it's ugly (and balding) head: If all you want is low 11s (per your above statement), you don't need to build a stroker. A stronger stock-stroke 440 will get you there, plus your current 4.10 gear & 28" tire combination will be well suited to the shorter-stroke combination's RPM range on the track.
IMO, you should...
- port the E heads
- run a fairly aggressive solid flat-tappet cam
- run a good single-plane intake (not sure what you have now)
- build for about 10.5 CR to stay safe on 93-octane pump fuel
A 440 in that HP range would probably be just as happy (maybe happier) w/ 1-7/8" headers. But since I think you said you already have 2", run what you got.
You may need to change converters, but that depends on how your current one works w/ the new engine. The biggest hit on performance will be if the 10" doesn't let you 60-ft. as well as something a little looser.
FWIW, this is both opinion and fact-based from the results I've seen on my own builds.
Re: 440 Stroker Build Questions [Re: BradH] #1434195
05/13/13 05:21 PM
05/13/13 05:21 PM
JohnRR Offline
JohnRR  Offline
IMO, you should...
- port the E heads
He seemed set of going with a stroker and the thinking now is bigger is better ...
Re: 440 Stroker Build Questions [Re: JohnRR] #1434196
05/13/13 06:51 PM
05/13/13 06:51 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
either motor will do it,the stroker easier. if starting from scratch the stroker is a no brainer.personally thinking running low 11's high 10's shouldn,t be a problem .
my 440 has run 10.99 pb and will normally run around 11.1@120mph,this is at around 3720lbs(68 Satellite).
no high end gear but well sorted.
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: 440 Stroker Build Questions [Re: tex013] #1434197
05/13/13 08:16 PM
05/13/13 08:16 PM
Jarrettsville, MD
tywebb2 Offline OP
super gas
tywebb2  Offline OP
super gas
Jarrettsville, MD
I hate to say it but the thought also crossed my mind after reading 600hp is the limit, etc. with the 440 block. Could a stroker be overkill for my application and just open up other cans of worm? I'm curious....what hp is my 8 3/4 rear good too? I have no interest in upgrading to a dana.
The major issue I have with my engine now is the TRW pistons. The valve notches are too small for the Eddy valves and I am at the limit of my valve clearance and my compression is a bit low (9.9:1) with pistons down in hole (bad quench height).
Would it make more sense just to swap out the stock rods with H-beams and get a new set of pistons....then possibly CNC porting the heads? Would I still need to zero deck the block or could I buy pistons off the shelf that would put me where I need to be out of the box? Then with my piston-to-valve clearance opened up I could go with a different cam.
I put the numbers in a hp calculator and it came back at 519hp if my weight figure is correct. How much do you think I would pick-up (hp and et) getting the proper quench height, 10.5:1 compression, better cam, cnc ported eddy heads?
Re: 440 Stroker Build Questions [Re: tywebb2] #1434198
05/13/13 08:49 PM
05/13/13 08:49 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
The block will be safe at 600hp. If you get a stroker kit, you will end up with a larger motor that will bring the rpm range of the power band down, helping the block live a longer life as a side effect. The stroker kits have lighter pistons that will help the motor rev quicker and free up a few ponies as well.
Page 2 of 3 1 2 3
