1971 Challenger Grill Help #1433983
05/10/13 12:13 PM
05/10/13 12:13 PM
Texas
K
Knappy Offline OP
Knappy  Offline OP
K
Texas
Does anyone have any pictures of the upper grill on a 1971
Challenger? I need to see where all the bolts go as well as where the
upper grill retainers go. What do the hold? The picture in the 71 body manuel is of a 1970 dash.
Steve
68 Coronet R/T Hemi
70 Challenger 440-6
70 Challenger R/T S/E 440-6
71 Challenger Convert.
70 Superbird 440-6
Re: 1971 Challenger Grill Help [Re: Knappy] #1433984
05/10/13 11:31 PM
05/10/13 11:31 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Re: 1971 Challenger Grill Help [Re: Knappy] #1433985
05/11/13 02:45 AM
05/11/13 02:45 AM
Puyallup, Wa.
Steve340 Offline
Steve340  Offline
Puyallup, Wa.
Dash or grill??
Re: 1971 Challenger Grill Help [Re: Steve340] #1433986
05/11/13 11:10 AM
05/11/13 11:10 AM
Texas
K
Knappy Offline OP
Knappy  Offline OP
K
Texas
The top of the grill in front of the hood latch assembly. The plate that goes on top of the grill. My car was in pieces and I am putting the grill and top plate back on. I bought a grill hardware kit from R/T Specialties and I do not know where the upper grill retainers go. The large plastic push-in retainers. I may be missing some parts. I have been looking for some pictures of the grill assembly but cannot find one.
68 Coronet R/T Hemi
70 Challenger 440-6
70 Superbird 440-6
Re: 1971 Challenger Grill Help [Re: Knappy] #1433987
05/11/13 02:28 PM
05/11/13 02:28 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
The grill slides over the metal latch plate then the plastic clips get pushed through the top of the grill into the metal plate.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: 1971 Challenger Grill Help [Re: Silver70] #1433988
05/11/13 07:19 PM
05/11/13 07:19 PM
WNY
slimert Offline
slimert  Offline
WNY
The top plate is installed first. With the bumper off, slide grill in, the top of grill lip fits over the top plate that gets the large head plastic push pins as stated previously. The back center grill bracket mounts to a vertical bracket (in front of the radiator) with 2 1/4"x 1" bolts. Last are 2 small plastic push pins at each end. Just be gentle, old plastic grills can crack easily. My pictures are too big, I can email them if you need pictures.
Re: 1971 Challenger Grill Help [Re: Knappy] #1433989
05/11/13 09:20 PM
05/11/13 09:20 PM
CT
1932chrysler Offline
CT
I have this photo hope it helps
1932 Chrysler CI Sedan
1956 Pontiac Catalina Sedan
All Makes & Models Are Special
Re: 1971 Challenger Grill Help [Re: 1932chrysler] #1433990
05/12/13 10:31 AM
05/12/13 10:31 AM
Texas
K
Knappy Offline OP
Knappy  Offline OP
K
Texas
No wonder I could not figure it out. I had the top of the grill below the plate. Now I can stop drinking and go back to work. Thanks for the help.
Steve
68 Coronet R/T Hemi
70 Challenger 440-6
70 Superbird 440-6
