Top of fender "oil canning" fix? (with video) #1432050
05/07/13 11:01 PM
05/07/13 11:01 PM
South Jersey
JerseyJoe Offline OP
South Jersey
Click here for video
My Charger's fender has a high spot that I could use some advice to fix. It pops back up after pushing down to match the rest of the contour. Do I need to heat and shrink this or is there another way to go about it?
Re: Top of fender "oil canning" fix? (with video) [Re: JerseyJoe] #1432051
05/08/13 12:08 AM
05/08/13 12:08 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
If your skilled at heat shrinking go for it, otherwise you may make it worse, other alternatives are a shrinking hammer/ pic/dolly, or remove the fender, remove any undercoating from the affected underside and gently glass bead/sandblast the underside of the top skin, sandbasting a panel raises the surface, by blasting the backside you'll basically collapse the the outer skin surface, making it concave as you desire...I've used all these techniques to perform bodywork, as well as fabricate reproduction/custom alloy parts
Re: Top of fender "oil canning" fix? (with video) [Re: DAYCLONA] #1432052
05/08/13 10:42 AM
05/08/13 10:42 AM
South Jersey
South Jersey
Thanks, Dayclona. I didn't think of sandblasting. I have access to all three methods, but I am a little nervous about using the torch on such a visible spot. I appreciate the tip.
Re: Top of fender "oil canning" fix? (with video) [Re: JerseyJoe] #1432053
05/09/13 12:52 AM
05/09/13 12:52 AM
Montana
BeeTX Offline
BeeTX  Offline
Montana
I'd think you could make it worse with sandblasting pretty easily. I've been trying to fix a spot on a hood like yours, without much luck so far. Have you ever looked at Metalmeet.com? Here's a section of their forum on shrinking techniques. You could ask there too. Fun to look through some of the metal work on there, amazing stuff. Little hard to find things at first, LOT of forum categories.
Re: Top of fender "oil canning" fix? (with video) [Re: BeeTX] #1432054
05/09/13 01:24 AM
05/09/13 01:24 AM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
I have done all three ways that Dayclona has stated & the pick hammer dolly/2X4 isn't hard to do if you want to load it with mud
I'd either heat it or blast it
Re: Top of fender "oil canning" fix? (with video) [Re: BulletBob] #1432055
05/09/13 01:43 AM
05/09/13 01:43 AM
Lakewood, Colorado
herkamer Offline
herkamer  Offline
Lakewood, Colorado
Learned in autobody school:
Oxyacetylene torch, swirl from outside to the center. You can almost watch it tighten up. Perhaps get a junkyard panel, dent it up and practice a few times before doing on something of value.
Matt
69 Dart Swinger 340
83 W350, Megasquirted with 46RH
Old news: 72 Demon street/race mobile
Latest: 70 Duster backhalf car
and even more
Re: Top of fender "oil canning" fix? (with video) [Re: herkamer] #1432056
05/09/13 01:59 AM
05/09/13 01:59 AM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
I've done it for 35 years or so now & I find a panel the same thickness & do a test just like stated above either blasting or heat with water & towel
Most of all it takes patience
Re: Top of fender "oil canning" fix? (with video) [Re: BulletBob] #1432057
05/09/13 12:46 PM
05/09/13 12:46 PM
IMGTX Offline
IMGTX  Offline
This is my method. Remember it will shrink more when it cools down so don't try to get it perfect while it's hot. I did this the first time. Looked perfect until it cooled down and then it was shrunk too much. LOL
Make sure there are no other problems first like a dent elsewhere on the fender covered in mud you don't see or a bent inner fender.
Shrink it a little at a time.
Re: Top of fender "oil canning" fix? (with video) [Re: IMGTX] #1432058
05/10/13 01:47 PM
05/10/13 01:47 PM
Willow Grove PA
71sat440 Offline
71sat440  Offline
Willow Grove PA
Re: Top of fender "oil canning" fix? (with video) [Re: IMGTX] #1432059
05/10/13 02:07 PM
05/10/13 02:07 PM
N.E. Ohio
6bblFLASH Online content
6bblFLASH  Online Content
N.E. Ohio
As stated,maked sure it isn`t "bound" or compressed.
I would first try using a block of wood and a pretty heavy hammer,, from inside the fender at the corners beside the "can" try spreading the corners away from each other. DO IT GENTLY to see if it makes any difference at all.
By spreading the panel it will use up the stretch that is causing the buckle.
You can take a buckle out of anything by stretching it
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas
9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ!
2013 StickShift Challenge Winner@ Mopar Nationals!
Re: Top of fender "oil canning" fix? (with video) [Re: JerseyJoe] #1432060
05/17/13 11:59 AM
05/17/13 11:59 AM
South Jersey
South Jersey
I'll be darned, blasting the underside worked like a charm. Still have to work it a little with the hammer, but it's very close to where I need it to be for a thin coat of filler.
Thanks everybody for the input.
