Re: Top of fender "oil canning" fix? (with video)
[Re: JerseyJoe]
#1432051
05/08/13 12:08 AM
05/08/13 12:08 AM
Posts: 18,157 Mass
DAYCLONA
Mass
If your skilled at heat shrinking go for it, otherwise you may make it worse, other alternatives are a shrinking hammer/ pic/dolly, or remove the fender, remove any undercoating from the affected underside and gently glass bead/sandblast the underside of the top skin, sandbasting a panel raises the surface, by blasting the backside you'll basically collapse the the outer skin surface, making it concave as you desire...I've used all these techniques to perform bodywork, as well as fabricate reproduction/custom alloy parts
[Re: JerseyJoe]
#1432053
05/09/13 12:52 AM
05/09/13 12:52 AM
Posts: 62 Montana
BeeTX
Montana
I'd think you could make it worse with sandblasting pretty easily. I've been trying to fix a spot on a hood like yours, without much luck so far. Have you ever looked at Metalmeet.com? Here's a section of their forum on shrinking techniques. You could ask there too. Fun to look through some of the metal work on there, amazing stuff. Little hard to find things at first, LOT of forum categories.
[Re: BulletBob]
#1432055
05/09/13 01:43 AM
05/09/13 01:43 AM
Posts: 1,305 Lakewood, Colorado
herkamer
Lakewood, Colorado
Learned in autobody school:
Oxyacetylene torch, swirl from outside to the center. You can almost watch it tighten up. Perhaps get a junkyard panel, dent it up and practice a few times before doing on something of value.
Matt 69 Dart Swinger 340 83 W350, Megasquirted with 46RH Old news: 72 Demon street/race mobile Latest: 70 Duster backhalf car and even more
[Re: herkamer]
#1432056
05/09/13 01:59 AM
05/09/13 01:59 AM
Posts: 6,048 Back home in PA
BulletBob
Back home in PA
I've done it for 35 years or so now & I find a panel the same thickness & do a test just like stated above either blasting or heat with water & towel Most of all it takes patience
[Re: BulletBob]
#1432057
05/09/13 12:46 PM
05/09/13 12:46 PM
Posts: 12,235 Looking for a way out of Middl...
IMGTX
This is my method. Remember it will shrink more when it cools down so don't try to get it perfect while it's hot. I did this the first time. Looked perfect until it cooled down and then it was shrunk too much. LOL
Make sure there are no other problems first like a dent elsewhere on the fender covered in mud you don't see or a bent inner fender.
Shrink it a little at a time.
[Re: IMGTX]
#1432058
05/10/13 01:47 PM
05/10/13 01:47 PM
Posts: 13,878 Willow Grove PA
71sat440
Willow Grove PA
[Re: IMGTX]
#1432059
05/10/13 02:07 PM
05/10/13 02:07 PM
Posts: 3,831 N.E. Ohio
6bblFLASH
N.E. Ohio
As stated,maked sure it isn`t "bound" or compressed. I would first try using a block of wood and a pretty heavy hammer,, from inside the fender at the corners beside the "can" try spreading the corners away from each other. DO IT GENTLY to see if it makes any difference at all. By spreading the panel it will use up the stretch that is causing the buckle. You can take a buckle out of anything by stretching it
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas 9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ! 2013 StickShift Challenge Winner@ Mopar Nationals!
