Larger than stock SB oil pump pick up? #1431539
05/07/13 02:34 AM
05/07/13 02:34 AM
Gainesville,FL
goldmember Offline OP
Gainesville,FL
I am looking to use a larger than stock SB oil pick up. What creative stuff have you resorted to? the stock pump doesn't look like it would like to be drilled and tapped much larger. Bottom cover setup? Show me some ideas. Thanks
Re: Larger than stock SB oil pump pick up? [Re: goldmember] #1431540
05/07/13 03:59 AM
05/07/13 03:59 AM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
I got one with my pan ( Stef's ) , but I think Kevco has a bottom plate pick up available now.
That would be the cheapest if you're buying.
Re: Larger than stock SB oil pump pick up? [Re: tubtar] #1431541
05/07/13 10:38 AM
05/07/13 10:38 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Kevco does have them. It's the style that takes place of the "plate" on the pump. Kevco shelves a circle track pickup to fit to the right side of their kickout pan. I had them make me a center sump pickup. Nice pans too!
Re: Larger than stock SB oil pump pick up? [Re: J_BODY] #1431542
05/07/13 12:35 PM
05/07/13 12:35 PM
Renton Washington
Triple Threat Offline
Renton Washington
Jay,
What pan did you end up with? and would it work on a stock front end?
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Larger than stock SB oil pump pick up? [Re: Triple Threat] #1431543
05/07/13 11:40 PM
05/07/13 11:40 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Jay,
I got Kevco's aluminum M405 pan which is a rear sump. I just had them "notch" the front sump back 3.5" to clear my steering rack. They do list some mopar "K" pans that fit stock chassis. Quality appears nice and it's been nice talking with people that seem to care. I'm assuming they're a smaller operation.
Re: Larger than stock SB oil pump pick up? [Re: J_BODY] #1431544
05/08/13 10:28 PM
05/08/13 10:28 PM
Las Vegas, NV
dodgeboy11 Offline
dodgeboy11  Offline
Las Vegas, NV
I'm thinking the cover plate style is the only real option. I have a Canton, rear sump, road race pan and the pickup they sent me is this style.
