Hardest tool I ever had to find
#1431178
05/06/13 10:27 AM
05/06/13 10:27 AM
Posts: 9,336 South-Central (Sebring), FL
Commando1
Even Googlizing the crap out of it a thousand different ways produced almost zero results. It's a ball joint adapter tool C-4034. I can't even find a picture of it except a crude illustration in the FSM. Do I even really need it?
Re: Hardest tool I ever had to find
[Re: dOc !]
#1431180
05/06/13 11:10 AM
05/06/13 11:10 AM
Posts: 13,613 md
mopars4ever
md
[Re: mopars4ever]
#1431181
05/06/13 11:54 AM
05/06/13 11:54 AM
Andrewh
[Re: Dave Watt]
#1431185
05/06/13 12:29 PM
05/06/13 12:29 PM
Commando1
Some of the older ball joints had more of a dome shape on top, thus the reason for a deep well socket. Otherwise the standard depth socket will work on most.
So 1976 OEM's should be.............?
[Re: Commando1]
#1431191
05/06/13 03:02 PM
05/06/13 03:02 PM
Posts: 4,848 Memphis
HemiRick
Memphis
Lower ball joints bolt in.....no press or any special tool required.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: HemiRick]
#1431192
05/06/13 03:20 PM
05/06/13 03:20 PM
Andrewh
again, benifit of the doubt.
76 what?
[Re: Andrewh]
#1431193
05/06/13 05:48 PM
05/06/13 05:48 PM
Commando1
76 what?
76 New yorker.
From the FSM:
"Lower Ball Joints. Installation: (1) Press in new ball joint into lower control arm using assembled Tool C-4212. (2) Place a new seal over ball joint with Adaptor Tool C-4034 and press retainer portion of seal down on ball joint housing until it is securely locked in position."
[Re: Commando1]
#1431194
05/06/13 05:56 PM
05/06/13 05:56 PM
Posts: 75,092 A Banana Republic near you.
JohnRR
76 what?
76 New yorker.
From the FSM:
Looks like it's just a SLEEVE that is open on one end and closed , except for a centering hole on the other end used to push the seal in place and clearing the ball joint.
You could probably use a piece of PVC or pipe of the appropriate size and the seal into place ????
[Re: Commando1]
#1431197
05/07/13 12:24 PM
05/07/13 12:24 PM
Posts: 13,613 md
mopars4ever
md
