Hardest tool I ever had to find #1431178
05/06/13 10:27 AM
05/06/13 10:27 AM
South-Central (Sebring), FL
Commando1 Offline OP
Even Googlizing the crap out of it a thousand different ways produced almost zero results.
It's a ball joint adapter tool C-4034.
I can't even find a picture of it except a crude illustration in the FSM.
Do I even really need it?
Re: Hardest tool I ever had to find [Re: Commando1] #1431179
05/06/13 10:29 AM
05/06/13 10:29 AM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
All FL people have SPECIAL NEEDS ......especially ones in the HEATland area ....
WHAT do the people at Miller tool have to say ?
Re: Hardest tool I ever had to find [Re: dOoC] #1431180
05/06/13 11:10 AM
05/06/13 11:10 AM
md
mopars4ever Offline
mopars4ever  Offline
md
don`t know if they have it but you can try here http://www.etoolcart.com/search.aspx?find=ball+joint+adapter+tool
Re: Hardest tool I ever had to find [Re: mopars4ever] #1431181
05/06/13 11:54 AM
05/06/13 11:54 AM
Andrewh Offline
Andrewh  Offline
Re: Hardest tool I ever had to find [Re: Andrewh] #1431182
05/06/13 12:24 PM
05/06/13 12:24 PM
it is the ball joint socket.
http://www.google.com/search?q=ball+join...ved=0CAcQ_AUoAQ
Thanks. So it's a 2-9/64ths deep socket (which you need for the lower ball joint) as opposed to the C-3561 2-9/64ths standard socket (used on the upper ball joint). Yes?
Nobody has the deep socket. They all show the standard socket.
Re: Hardest tool I ever had to find [Re: dOoC] #1431183
05/06/13 12:25 PM
05/06/13 12:25 PM
They say shaddup, Doc.
Re: Hardest tool I ever had to find [Re: Commando1] #1431184
05/06/13 12:27 PM
05/06/13 12:27 PM
Atlanta Indiana
Dave Watt Offline
Dave Watt  Offline
Atlanta Indiana
Some of the older ball joints had more of a dome shape on top, thus the reason for a deep well socket. Otherwise the standard depth socket will work on most.
Re: Hardest tool I ever had to find [Re: Dave Watt] #1431185
05/06/13 12:29 PM
05/06/13 12:29 PM
So 1976 OEM's should be.............?
Re: Hardest tool I ever had to find [Re: Commando1] #1431186
05/06/13 12:33 PM
05/06/13 12:33 PM
Andrewh Offline
Andrewh  Offline
sorry, maybe I am confused.
the number you gave was to remove and replace the upper ball joint.
I am unaware of any lower ball joint threaded into the lower control arm, but have only worked on a few mopars so could be mistaken.
three sizes exist for the uppper,
small for early a
med for pretty much every car otherwise
and large for trucks.
I have seen the shallow version sold for as cheap as 12 bucks.
I own the deeper version from snapon but that ran like 90 bucks with the 3/4 to 1/2 adapter.
if you are looking for a lower ball joint socket, I have never seen one.
Re: Hardest tool I ever had to find [Re: Andrewh] #1431187
05/06/13 12:47 PM
05/06/13 12:47 PM
No, you're good. As usual, it's me.
Since I have Press-in lower ball joints, it's a moot point about a socket for the lowers. Yes?
Or am I still out in far left field?
Re: Hardest tool I ever had to find [Re: Commando1] #1431188
05/06/13 01:03 PM
05/06/13 01:03 PM
Andrewh Offline
Andrewh  Offline
no sockets for pressed in correct.
Re: Hardest tool I ever had to find [Re: Andrewh] #1431189
05/06/13 01:35 PM
05/06/13 01:35 PM
I'm learnin.........
Thanks.
Re: Hardest tool I ever had to find [Re: Commando1] #1431190
05/06/13 02:39 PM
05/06/13 02:39 PM
The Netherlands
BigBlockMopar Offline
The Netherlands
When tools become idiotly priced (or it takes a week to be delivered, in my case) it can sometimes by smart to just make your own.
Here's a LCA balljoint-tool I drew up and had lasercut locally up for my '60 NewYorker, which has threaded balljoints.
After the cutting I welded everything together and was able to change the balljoints...
Re: Hardest tool I ever had to find [Re: Commando1] #1431191
05/06/13 03:02 PM
05/06/13 03:02 PM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
Lower ball joints bolt in.....no press or any special tool required.
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: Hardest tool I ever had to find [Re: HemiRick] #1431192
05/06/13 03:20 PM
05/06/13 03:20 PM
Andrewh Offline
Andrewh  Offline
again, benifit of the doubt.
76 what?
Re: Hardest tool I ever had to find [Re: Andrewh] #1431193
05/06/13 05:48 PM
05/06/13 05:48 PM
76 what?
76 New yorker.
From the FSM:
"Lower Ball Joints.
Installation:
(1) Press in new ball joint into lower control arm using assembled Tool C-4212.
(2) Place a new seal over ball joint with Adaptor Tool C-4034 and press retainer portion of seal down on ball joint housing until it is securely locked in position."
Re: Hardest tool I ever had to find [Re: Commando1] #1431194
05/06/13 05:56 PM
05/06/13 05:56 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
76 what?
76 New yorker.
From the FSM:
"Lower Ball Joints.
Installation:
Looks like it's just a SLEEVE that is open on one end and closed , except for a centering hole on the other end used to push the seal in place and clearing the ball joint.
You could probably use a piece of PVC or pipe of the appropriate size and the seal into place ????
Re: Hardest tool I ever had to find [Re: JohnRR] #1431195
05/06/13 06:54 PM
05/06/13 06:54 PM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
I have that C-4212 ball joint press tool, and will have to see if that Adapter tool, C-4034 is with it.
Don't know what good it will do you though, if i have it.
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: Hardest tool I ever had to find [Re: hemi71x] #1431196
05/07/13 10:31 AM
05/07/13 10:31 AM
You can tell me more about it and I could make one?
Re: Hardest tool I ever had to find [Re: Commando1] #1431197
05/07/13 12:24 PM
05/07/13 12:24 PM
md
mopars4ever Offline
mopars4ever  Offline
md
