Hardest tool I ever had to find #1431178
05/06/13 10:27 AM
05/06/13 10:27 AM
South-Central (Sebring), FL
Commando1 Offline OP
Even Googlizing the crap out of it a thousand different ways produced almost zero results.
It's a ball joint adapter tool C-4034.
I can't even find a picture of it except a crude illustration in the FSM.
Do I even really need it?
Re: Hardest tool I ever had to find [Re: Commando1] #1431179
05/06/13 10:29 AM
05/06/13 10:29 AM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
All FL people have SPECIAL NEEDS ......especially ones in the HEATland area ....
WHAT do the people at Miller tool have to say ?
Re: Hardest tool I ever had to find [Re: dOc !] #1431180
05/06/13 11:10 AM
05/06/13 11:10 AM
md
mopars4ever Offline
mopars4ever  Offline
md
don`t know if they have it but you can try here http://www.etoolcart.com/search.aspx?find=ball+joint+adapter+tool
Re: Hardest tool I ever had to find [Re: mopars4ever] #1431181
05/06/13 11:54 AM
05/06/13 11:54 AM
Andrewh Offline
Andrewh  Offline
Re: Hardest tool I ever had to find [Re: Andrewh] #1431182
05/06/13 12:24 PM
05/06/13 12:24 PM
it is the ball joint socket.
http://www.google.com/search?q=ball+join...ved=0CAcQ_AUoAQ
Thanks. So it's a 2-9/64ths deep socket (which you need for the lower ball joint) as opposed to the C-3561 2-9/64ths standard socket (used on the upper ball joint). Yes?
Nobody has the deep socket. They all show the standard socket.
Re: Hardest tool I ever had to find [Re: dOc !] #1431183
05/06/13 12:25 PM
05/06/13 12:25 PM
They say shaddup, Doc.
Re: Hardest tool I ever had to find [Re: Commando1] #1431184
05/06/13 12:27 PM
05/06/13 12:27 PM
Atlanta Indiana
Dave Watt Offline
Dave Watt  Offline
Atlanta Indiana
Some of the older ball joints had more of a dome shape on top, thus the reason for a deep well socket. Otherwise the standard depth socket will work on most.
Re: Hardest tool I ever had to find [Re: Dave Watt] #1431185
05/06/13 12:29 PM
05/06/13 12:29 PM
So 1976 OEM's should be.............?
Re: Hardest tool I ever had to find [Re: Commando1] #1431186
05/06/13 12:33 PM
05/06/13 12:33 PM
Andrewh Offline
Andrewh  Offline
sorry, maybe I am confused.
the number you gave was to remove and replace the upper ball joint.
I am unaware of any lower ball joint threaded into the lower control arm, but have only worked on a few mopars so could be mistaken.
three sizes exist for the uppper,
small for early a
med for pretty much every car otherwise
and large for trucks.
I have seen the shallow version sold for as cheap as 12 bucks.
I own the deeper version from snapon but that ran like 90 bucks with the 3/4 to 1/2 adapter.
if you are looking for a lower ball joint socket, I have never seen one.
Re: Hardest tool I ever had to find [Re: Andrewh] #1431187
05/06/13 12:47 PM
05/06/13 12:47 PM
No, you're good. As usual, it's me.
Since I have Press-in lower ball joints, it's a moot point about a socket for the lowers. Yes?
Or am I still out in far left field?
Re: Hardest tool I ever had to find [Re: Commando1] #1431188
05/06/13 01:03 PM
05/06/13 01:03 PM
Andrewh Offline
Andrewh  Offline
no sockets for pressed in correct.
Re: Hardest tool I ever had to find [Re: Andrewh] #1431189
05/06/13 01:35 PM
05/06/13 01:35 PM
I'm learnin.........
Thanks.
Re: Hardest tool I ever had to find [Re: Commando1] #1431190
05/06/13 02:39 PM
05/06/13 02:39 PM
The Netherlands
BigBlockMopar Offline
The Netherlands
When tools become idiotly priced (or it takes a week to be delivered, in my case) it can sometimes by smart to just make your own.
Here's a LCA balljoint-tool I drew up and had lasercut locally up for my '60 NewYorker, which has threaded balljoints.
After the cutting I welded everything together and was able to change the balljoints...
Re: Hardest tool I ever had to find [Re: Commando1] #1431191
05/06/13 03:02 PM
05/06/13 03:02 PM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
Lower ball joints bolt in.....no press or any special tool required.
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: Hardest tool I ever had to find [Re: HemiRick] #1431192
05/06/13 03:20 PM
05/06/13 03:20 PM
Andrewh Offline
Andrewh  Offline
again, benifit of the doubt.
76 what?
Re: Hardest tool I ever had to find [Re: Andrewh] #1431193
05/06/13 05:48 PM
05/06/13 05:48 PM
76 what?
76 New yorker.
From the FSM:
"Lower Ball Joints.
Installation:
(1) Press in new ball joint into lower control arm using assembled Tool C-4212.
(2) Place a new seal over ball joint with Adaptor Tool C-4034 and press retainer portion of seal down on ball joint housing until it is securely locked in position."
Re: Hardest tool I ever had to find [Re: Commando1] #1431194
05/06/13 05:56 PM
05/06/13 05:56 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
76 what?
76 New yorker.
From the FSM:
"Lower Ball Joints.
Installation:
Looks like it's just a SLEEVE that is open on one end and closed , except for a centering hole on the other end used to push the seal in place and clearing the ball joint.
You could probably use a piece of PVC or pipe of the appropriate size and the seal into place ????
Re: Hardest tool I ever had to find [Re: JohnRR] #1431195
05/06/13 06:54 PM
05/06/13 06:54 PM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
I have that C-4212 ball joint press tool, and will have to see if that Adapter tool, C-4034 is with it.
Don't know what good it will do you though, if i have it.
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: Hardest tool I ever had to find [Re: hemi71x] #1431196
05/07/13 10:31 AM
05/07/13 10:31 AM
You can tell me more about it and I could make one?
Re: Hardest tool I ever had to find [Re: Commando1] #1431197
05/07/13 12:24 PM
05/07/13 12:24 PM
md
mopars4ever Offline
mopars4ever  Offline
md
