Re: leaf elimination on d100 truck
[Re: amxautox]
#1430918
05/05/13 10:13 PM
05/05/13 10:13 PM
Posts: 26 US
BBD150
US
[Re: BBD150]
#1430919
05/05/13 10:17 PM
05/05/13 10:17 PM
Posts: 96,666 On The Boat, On The Lake, Wa. ...
amxautox
Still Retired. Still Posting on Moparts. A Lot.
then it would be better to ask this in the drag race forum instead of the Handling Forum. it would be a little bit different set up.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
[Re: amxautox]
#1430920
05/06/13 02:21 AM
05/06/13 02:21 AM
Posts: 625 Oakville, Wa
HOTMOPR
Oakville, Wa
for a truck that will see limited drag action I would go with a ladder bar set up. Ladders bars are much easier to install plus set up is easier and theu are cheaper. You wont need the infinite adjustment of a 4 link setup. However if you see yourself getting more serious with drag racing then the 4 link might be a better option..
67 Barracuda, 470" B, Glide, FuelTech FT600, Precision, Ptc, QA1, Calvert, Smith racecraft, Afco, Dana 60. 275 radials
[Re: tubtar]
#1430924
05/06/13 07:03 AM
05/06/13 07:03 AM
Posts: 6,392 nielsville, minn.
quickd100
nielsville, minn.
The step ups on the frame won't allow for the stock bed floor if you do it right. You could weld brackets to the stock rails maybe , but you want that stuff to be rock solid and you'd be surprised at how much they will twist. There is a fellow from southern Mn. who posts here and I can't swear to his handle , but it is D-100 ish in nature.......he has a well done Hemi in his and has probably had every problem you will face.
I don't know if you're refering to me, I live about 100 miles south of the northern border with Canada. I built a 4-link for my D-100 and like it, much nicer ride on the street. I'm still sorting a few things out but I think it's getting close. My main problem has been dealing with weak links, I first built it when I was making 650hp. I'm now at 850+, trying to build everything strong enough but at the same time keep the weight down to a minumum has been a challenge. Dave ![](/ubbthreads/images/graemlins/hammer.gif)
[Re: quickd100]
#1430926
05/06/13 10:41 AM
05/06/13 10:41 AM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
Yeah I was........sorry. I could have sworn Nielsville was down Winona / Caledonia way. I seem to remember a thread where you were twisting the frame rails and how you addressed it.
[Re: BBD150]
#1430927
05/06/13 11:17 AM
05/06/13 11:17 AM
Posts: 52,972 Romeo MI
MR_P_BODY
i want to eliminate the leaf springs on a short bed d100. i plan on doing a 4 link with coil overs to replace them. any suggestions on which 4 link i should be looking at. the rear end is a d60. i plan on racing it but it will mostly be driven on the street.
I would want to see what the distance is from the back of the cab to the center line of the axle... that would tell me alot and what I would use and do... also what the balance point is on the truck... if you knew a couple of these numbers its easier to figure out... I buy the S&W brackets and make my own bars for almost every 4-link I install ![](/ubbthreads/images/graemlins/wave.gif)
[Re: MR_P_BODY]
#1430928
05/06/13 01:44 PM
05/06/13 01:44 PM
Posts: 12,418 Taxes & Virus's R-US, NY
Dragula
They are very front heavy, and also, I believe he would need to put the frame up thru the bed. That is somthing I was able to avoid on mine....
![](http://i427.photobucket.com/albums/pp357/cudahalr/78Dodge_D100/DSC00043-1.jpg)
![](http://i427.photobucket.com/albums/pp357/cudahalr/78Dodge_D100/DSC07675.jpg)
[Re: Dragula]
#1430929
05/06/13 02:50 PM
05/06/13 02:50 PM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
I am building a Ramcharger for bracket racing and am keeping it simple. I am using the original leafs with clamps on the front segment, spooled Dana 60 mounted above the springs. At the moment I have front mounts at the rear with longer shackles, but I am going to use rollers mounted to a square tube crossmember that will also serve as the anchor point for the rear tubes of the roll cage. Finally, I will be using a homemade copy of the "CalTrac" system.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
[Re: Polarapete]
#1430931
05/06/13 08:02 PM
05/06/13 08:02 PM
quickd100
nielsville, minn.
Finally....I found a man crazier than me. My factory leaf springs worked wonderful until I went to a 528 Hemi. I tryed the caltracks and shocks and just couldn't get them to work. I called Calvert racing hoping they could make up a set of leaf springs for me. They said they couldn't help me so I fabbed up a 4-link. I bought a copy of Billy Shoppes, 'Just Suspensions' it was a tremendous help. Dave
[Re: TrxR]
#1430934
05/07/13 07:06 AM
05/07/13 07:06 AM
quickd100
nielsville, minn.
quickd100: do you have any pics of the 4 link under your truck?
Sorry, I don't have anything current and the shop is plugged with equipment right now and I can't get remotely close to the hoist to get any pics. Dave
