Guys Who Get Lots of passes out of their equipment?? #1430096
05/04/13 01:44 PM
05/04/13 01:44 PM
Plant city fl
70Dart499 Offline OP
Plant city fl
To all of you bracket racers out there who get lots and lots of passes out of your motors and Trannys, what are your secrets? I know lots of guys who get hundreds of passes out of theirs, but I have never been so lucky, it seems the best I can do is about 100 passes on a motor. Maybe I have just been unlucky, but maybe there are some secrets? I'm putting together yet another motor, and I really don't want to be pulling it out after 100 passes.
1970 Dart Drag Car
Re: Guys Who Get Lots of passes out of their equipment?? [Re: 70Dart499] #1430097
05/04/13 01:58 PM
05/04/13 01:58 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Wow... 100 passes... I'd be pissed too... I have about
400 on the engine and its still fine but I dont make
a ton of power BUT the car is light... light is always
easier on equipment... my trans has been in there
about 9 seasons... still fine with a trans brake...
I am gonna freshen up 2 of my engine and the trans
because I'm gonna sell the car with both engines...
but I only run high 8s and it could run 8.50
Re: Guys Who Get Lots of passes out of their equipment?? [Re: 70Dart499] #1430098
05/04/13 02:14 PM
05/04/13 02:14 PM
Washington
skrews Offline
skrews  Offline
Washington
Don't make enough power to break anything. 2000+ runs on my 340/904 running 11.8-12.1 in a 3400# car 1.65 60".
Re: Guys Who Get Lots of passes out of their equipment?? [Re: skrews] #1430099
05/04/13 02:18 PM
05/04/13 02:18 PM
Guitar Jones Offline
I had a piece of crap MP 360 crate short block with W5's on it and a big flat tappet, beat the snot out of that thing for 15 years and was still a working engine when I pulled it to put my high dollar 408 in the car. That lasted 12 passes.
Stuff happens but if none of your engines lasted much more than 100 passes I'd be looking for another engine builder and/or machine shop.
Re: Guys Who Get Lots of passes out of their equipment?? [Re: skrews] #1430100
05/04/13 02:25 PM
05/04/13 02:25 PM
Plant city fl
Plant city fl
That's my plan for the new 340 that I'm putting in the car.
1970 Dart Drag Car
Re: Guys Who Get Lots of passes out of their equipment?? [Re: 70Dart499] #1430101
05/04/13 02:50 PM
05/04/13 02:50 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
no distance is to far for quality machine work
Re: Guys Who Get Lots of passes out of their equipment?? [Re: sixpackgut] #1430102
05/04/13 03:05 PM
05/04/13 03:05 PM
Q
Quicktree Offline
Quicktree  Offline
Q
and good parts
Re: Guys Who Get Lots of passes out of their equipment?? [Re: 70Dart499] #1430103
05/04/13 04:12 PM
05/04/13 04:12 PM
NC
440Jim Offline
440Jim  Offline
NC
Perhaps it would be better for us to focus on what problems you are finding around 100 passes.
High rpm needs better valve train... etc.
Re: Guys Who Get Lots of passes out of their equipment?? [Re: 440Jim] #1430104
05/04/13 04:16 PM
05/04/13 04:16 PM
What is failing
Re: Guys Who Get Lots of passes out of their equipment?? [Re: Cab_Burge] #1430105
05/04/13 04:46 PM
05/04/13 04:46 PM
Plant city fl
Plant city fl
It's been a variety of parts, and not all the motors have been Mopar some were small block fords that I used to run. I think it's been bad machine work mostly, parts were not what I was told they were in one of the small blocks. I guess I pretty much answered my own questions, I have lots of faith in the guy who is building the motor he has built a few for my father and they have been great, so I think this one will turn out ok.
1970 Dart Drag Car
Re: Guys Who Get Lots of passes out of their equipment?? [Re: 70Dart499] #1430106
05/04/13 07:20 PM
05/04/13 07:20 PM
Dandridge TN
Dabee Offline
Dabee  Offline
Dandridge TN
I have over 400 passes on the BB stroker and power gluide in Da Beast. Good machine work, big cubes, small cam, use quality parts, shift it at 6,000 rpm, change oil every 50 passes, and build a good solid transmission. It runs 6.40s in the eight and is still running strong.
Re: Guys Who Get Lots of passes out of their equipment?? [Re: 70Dart499] #1430107
05/04/13 07:43 PM
05/04/13 07:43 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I turn a fair amount of RPMs all the time(8200 rpm)
but I run good parts, good balance but I dont run the
big HP... dont need to in a light car... the valve train
in a SB is very important due to the RPMs
Re: Guys Who Get Lots of passes out of their equipment?? [Re: MR_P_BODY] #1430108
05/04/13 09:36 PM
05/04/13 09:36 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
It's the tuner!
Re: Guys Who Get Lots of passes out of their equipment?? [Re: 70Dart499] #1430109
05/04/13 11:57 PM
05/04/13 11:57 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
That would be me most years...Unless it has a hemi in it, then it seems I kill it every year for somthing stupid, but NOT this year! We have learned!
Honestly, it takes a little luck, and it usually does not happen the first year. Most end up pulling it apart, and fixing things. Over time, you sort it out, and it all comes togather. I have bracket cars with engines and tranmissions that have lasted +300 passes without any failures, but a little luck helps too.
We are on our third season on the 512 making 700hp on pump gas, and we hit 120 passes on it last year, but as I mentioned, we had a few close calls, and some luck. You learn what parts work, and what doesn't and try and be very watchful of things.
Re: Guys Who Get Lots of passes out of their equipment?? [Re: Dragula] #1430110
05/05/13 03:13 AM
05/05/13 03:13 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
More info might help people help you make it better...
FWIW I get a few hundred out of mine in the big tire car. It is making over 1050hp and is pretty much trouble free. Good parts, attention to detail and good maintenance go a LONG way.
Re: Guys Who Get Lots of passes out of their equipment?? [Re: Al_Alguire] #1430111
05/05/13 10:36 AM
05/05/13 10:36 AM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
attention to detail is always #1
good machinework,the right components for what you are doing and overbuuild everything,try to get a better chassie than your motor realy needs,with a good car you lessen the risk of hurting the engine since the car itself wont do anything unexpected you will know better what the engine is doing.
and i know this is not PC at all but look at some highend streetrace cars and you will learn alot about how to make your stuff reliable above and beyond.
Re: Guys Who Get Lots of passes out of their equipment?? [Re: Al_Alguire] #1430112
05/05/13 01:52 PM
05/05/13 01:52 PM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
Good parts, attention to detail and good MAINTENANCE go a LONG way.
A checkup is always preferable to an autopsy. Maintenance is the key to learning what is or isn't working. After they grenade themselves it's kind of hard to figure out what went wrong. And remember, it seems they will ALWAYS run their fastest right before they blow up.....seen that MANY times...
Re: Guys Who Get Lots of passes out of their equipment?? [Re: Sixpak] #1430113
05/05/13 03:01 PM
05/05/13 03:01 PM
St.Louis, Mo.
mokid Offline
mokid  Offline
St.Louis, Mo.
I have been thru alot of motors and builders, I just got my motor back from Jim Evans race engines, We broke a rod the end of last year, block damage sent to LSM, new Diamond pistons,went to Isky lifters, went to carrillos rod ( from Grodens), new ex-valves,had to have dry sump pump re-build on and on all said and done over $ 10,000.00 re-build I updated alot of parts and hopefully will stay together but I pulled motor/trans out every season to freshen up. Oh it's a R3 W8 motor
Re: Guys Who Get Lots of passes out of their equipment?? [Re: mokid] #1430114
05/05/13 03:32 PM
05/05/13 03:32 PM
Mississippi
Mr. T Offline
Mr. T  Offline
Mississippi
The 360 in my car has been raced for 17 years now. The only thing that has been replaced internally is the valve springs. It has a M.P. hydraulic cam, and the engine never sees more than 6,000 R.P.M.'s. Who says bracket racing has to be expensive?
Re: Guys Who Get Lots of passes out of their equipment?? [Re: Mr. T] #1430115
05/05/13 04:17 PM
05/05/13 04:17 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
Seems like only last week we were test driving that engine around Memphis. I must be getting old.
