Primer Question / Getting the scamp blasted
#1429397
05/02/13 09:13 PM
05/02/13 09:13 PM
Posts: 569 Pasco, WA
440mag
Pasco, WA
Will have my car back from the blaster in a couple of days. Plan on painting it with a water based paint. What should I prime or seal it up with prior to completing the body work?
Re: Primer Question / Getting the scamp blasted
[Re: 440mag]
#1429398
05/02/13 11:00 PM
05/02/13 11:00 PM
Posts: 1,528 Southeast PA
5wndwcpe
Southeast PA
Hit it with 80 grit or st the very least, a red Scotchbrite pad, degrease and lay two coats of epoxy on it.
1968 GTX hardtop 1968 Sport Satellite Convertible 383/4spd 1933 Plymouth coupe 2002 Ram 2500 oil burner 4x4 2015 Grand Cherokee 2013 Challenger 1957 Chrysler Saratoga
Man...I need a bigger freakin' garage.
[Re: 5wndwcpe]
#1429401
05/03/13 09:02 AM
05/03/13 09:02 AM
Challenger 1
Cincinnati, Ohio
Don't touch it after blasting. It sure don't need to scotchbrited or even sanded after blasted. You will just make it worse if you try to do anything besides painting it after blasting.
Blow it off and cover it with epoxy primer.
[Re: Challenger 1]
#1429402
05/03/13 10:38 AM
05/03/13 10:38 AM
Posts: 1,376 NORTHERN CA
HUSTLESTUFF
NORTHERN CA
I agree with Challenger. I will add buy some new white gloves to move it around. I like NorthStar epoxy. Dilute it 1:1:1.25
"Were in it to win it. Anything less will end up being..... A whole lot of fun doing!!" UNLAWFL RIP UN
[Re: 440mag]
#1429407
05/04/13 01:11 PM
05/04/13 01:11 PM
Posts: 252 Seattle, WA.
edp
Seattle, WA.
Thanks for the replies.
Using the waterborne because it looks to be working well. I can spray it myself without an air supplied respirator.
regardless of H2O paint you'll need a respirator. are you doing a base / clear application or is it a single stage paint? Lots of clears are still solvent based so you'll still need very good ventilation along with a respirator, doesn't have to be supplied air if you have adequate air flow.
Dawn dish soap works really well as a first stage washing & cleaner, after that wipe down with a wax a grease remover then shoot epoxy which BTW is solvent based - at least what I've used and as a positive it doesn't have Isocyanates.
[Re: 440mag]
#1429409
05/05/13 12:49 PM
05/05/13 12:49 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
I blast them then epoxy or etch prime the same day. I just blow off all the sand, usually when on the rotisserie so I can spin it to get all the sand. But no matter how hard you try, so sand will still show up when priming. I don't wipe them off with anything, just blast then prime.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
[Re: Stanton]
#1429411
05/05/13 03:09 PM
05/05/13 03:09 PM
Silver70
Rust Belt, SW PA
If it's not blasted clean, it will rust again eventually. If I can't do it right away, I use polycarbide wheels on an angle grinder to get nice clean metal then prime after.
[Re: Silver70]
#1429412
05/05/13 06:02 PM
05/05/13 06:02 PM
edp
Seattle, WA.
washing it after blasting is additional insurance, if your worried about flash rust that can occur just from humidity, if it does hit it with 80 grit on a DA and get rid of it. After blasting there can be contaminant on/in the metal-it needs to be scrubbed off, dawn works well because it doesn't have abunch of other things in it, scents, etc.....& it leaves no residue if rinced properly.
I've painted many parts with epoxy after just a dawn scrub, no epoxy failures. Wax & grease removers won't get everything , the cleaner the part you start with the less W & G work necessary.
If you do a lot of DA sanding for paint removal that can force residues into the metal - don't worry about the water rusting a hole in the car just make sure it clean prior to any paint. All in the prep....
[Re: edp]
#1429413
05/05/13 08:45 PM
05/05/13 08:45 PM
Posts: 221 Missouri
Challenger
Missouri
This. All my stuff gets cleaned with dawn soap and water. Get it cleaned, waterboure wax and grease remover and 2 coats of epoxy. Question for those of you that sodablast cars, How do you neutralize the soda before painting? The answer to that question is you wash it with water/soap and do it a couple of times. YES SOAP/WATER.
[Re: 440mag]
#1429415
05/06/13 12:26 AM
05/06/13 12:26 AM
Posts: 1,179 Canada
demon
Canada
If it was blasted with brand new clean media, it is ready to prime with epoxy, although I like to sand the surfaces to remove most of the texture that blasting leaves and any little flecks of paint etc that were not 100% removed and then use a final wipe. If recycled media was used you better use a wax and grease remover. I don't let anyone touch my sandblasted or bare metal parts. Always wear latex gloves or you will have rusty fingerprints show up years later under the paint. I've seen it. Do not use self etching primer on blasted metal. The textured finish will retain the acid and cause problems later too. Same goes for metal prep. Never use metal prep acid on blasted metal. It is only to etch smooth metal. I don't like tack tags very much either. They can cause fisheyes. If you insist on tacking it use a brand new Quality blue base/clear tack cloth and not one of the cheap ones.
Beautiful 72 Charger by the way! Love the 72 Rallyes!
