Primer Question / Getting the scamp blasted #1429397
05/02/13 09:13 PM
05/02/13 09:13 PM
Pasco, WA
440mag Offline OP
440mag  Offline OP
Pasco, WA
Will have my car back from the blaster in a couple of days. Plan on painting it with a water based paint. What should I prime or seal it up with prior to completing the body work?
Re: Primer Question / Getting the scamp blasted [Re: 440mag] #1429398
05/02/13 11:00 PM
05/02/13 11:00 PM
Southeast PA
5wndwcpe Offline
5wndwcpe  Offline
Southeast PA
Hit it with 80 grit or st the very least, a red Scotchbrite pad, degrease and lay two coats of epoxy on it.
1968 GTX hardtop
1968 Sport Satellite Convertible 383/4spd
1933 Plymouth coupe
2002 Ram 2500 oil burner 4x4
2015 Grand Cherokee
2013 Challenger
1957 Chrysler Saratoga
Man...I need a bigger freakin' garage.
Re: Primer Question / Getting the scamp blasted [Re: 440mag] #1429399
05/02/13 11:52 PM
05/02/13 11:52 PM
Jacksonville Florida
elitecustombody Offline
Few coats of epoxy primer . Why use waterborne junk ?
Re: Primer Question / Getting the scamp blasted [Re: elitecustombody] #1429400
05/03/13 12:01 AM
05/03/13 12:01 AM
Pasco, WA
440mag Offline OP
440mag  Offline OP
Pasco, WA
Thanks for the replies.
Using the waterborne because it looks to be working well. I can spray it myself without an air supplied respirator.
Re: Primer Question / Getting the scamp blasted [Re: 5wndwcpe] #1429401
05/03/13 09:02 AM
05/03/13 09:02 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Don't touch it after blasting. It sure don't need to scotchbrited or even sanded after blasted. You will just make it worse if you try to do anything besides painting it after blasting.
Blow it off and cover it with epoxy primer.
Re: Primer Question / Getting the scamp blasted [Re: Challenger 1] #1429402
05/03/13 10:38 AM
05/03/13 10:38 AM
NORTHERN CA
HUSTLESTUFF Offline
HUSTLESTUFF  Offline
NORTHERN CA
I agree with Challenger. I will add buy some new white gloves to move it around. I like NorthStar epoxy. Dilute it 1:1:1.25
"Were in it to win it. Anything less will end up being..... A whole lot of fun doing!!" UNLAWFL
RIP UN
Re: Primer Question / Getting the scamp blasted [Re: HUSTLESTUFF] #1429403
05/03/13 05:37 PM
05/03/13 05:37 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I would prime it with whatever is recommended by the manufacturer of your topcoats - those guys are the experts !!!
I'm liking the waterborne idea - if you can spare the bucks, invest in a turbine system as the waterborne needs immaculately dry air. The nice thing about the turbine systems is they supply the volumes and pressures required by the gun - no farting around or guessing.
Hit the whole car with cleaners and degreasers - I GUARANTY you "someone" will have touched the bare metal with bare hands!
Re: Primer Question / Getting the scamp blasted [Re: Stanton] #1429404
05/03/13 10:47 PM
05/03/13 10:47 PM
SE Wisconsin, USA
RP's R/T's Offline
RP's R/T's  Offline
SE Wisconsin, USA
What do you do to prep the surface before priming if the metal was chemically stripped (aka Acid Dipped)?
Re: Primer Question / Getting the scamp blasted [Re: RP's R/T's] #1429405
05/03/13 11:24 PM
05/03/13 11:24 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Regardless of how the metal was stripped the process before priming is the same ... you want to get rid of any oil, wax or grease that will prevent adhesion. And touching the metal with clean bare hands still leaves a mark!
Re: Primer Question / Getting the scamp blasted [Re: Stanton] #1429406
05/04/13 09:41 AM
05/04/13 09:41 AM
Missouri
Challenger Offline
Challenger  Offline
Missouri
First of all one question. What material was used for the blasting?
Re: Primer Question / Getting the scamp blasted [Re: 440mag] #1429407
05/04/13 01:11 PM
05/04/13 01:11 PM
Seattle, WA.
E
edp Offline
edp  Offline
E
Seattle, WA.
regardless of H2O paint you'll need a respirator. are you doing a base / clear application or is it a single stage paint? Lots of clears are still solvent based so you'll still need very good ventilation along with a respirator, doesn't have to be supplied air if you have adequate air flow.
Dawn dish soap works really well as a first stage washing & cleaner, after that wipe down with a wax a grease remover then shoot epoxy which BTW is solvent based - at least what I've used and as a positive it doesn't have Isocyanates.
Re: Primer Question / Getting the scamp blasted [Re: edp] #1429408
05/05/13 12:22 PM
05/05/13 12:22 PM
Pasco, WA
440mag Offline OP
440mag  Offline OP
Pasco, WA
The car is being blasted with star blast, dried air.
I plan to paint it with base coat clear coat.
Bought a box of solvent proof gloves.
Not to sure about washing a blasted car. Thought I would blow it off 100 times then degrease an tack it down before priming it. ???
Re: Primer Question / Getting the scamp blasted [Re: 440mag] #1429409
05/05/13 12:49 PM
05/05/13 12:49 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
I blast them then epoxy or etch prime the same day. I just blow off all the sand, usually when on the rotisserie so I can spin it to get all the sand. But no matter how hard you try, so sand will still show up when priming. I don't wipe them off with anything, just blast then prime.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: Primer Question / Getting the scamp blasted [Re: Silver70] #1429410
05/05/13 01:00 PM
05/05/13 01:00 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I've heard of doing that too. In fact, a lot of the blasters up here do the epoxy prime as part of the job. Although it makes me wonder if they're hiding something underneath.
Re: Primer Question / Getting the scamp blasted [Re: Stanton] #1429411
05/05/13 03:09 PM
05/05/13 03:09 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
If it's not blasted clean, it will rust again eventually. If I can't do it right away, I use polycarbide wheels on an angle grinder to get nice clean metal then prime after.
Re: Primer Question / Getting the scamp blasted [Re: Silver70] #1429412
05/05/13 06:02 PM
05/05/13 06:02 PM
Seattle, WA.
E
edp Offline
edp  Offline
E
Seattle, WA.
washing it after blasting is additional insurance, if your worried about flash rust that can occur just from humidity, if it does hit it with 80 grit on a DA and get rid of it.
After blasting there can be contaminant on/in the metal-it needs to be scrubbed off, dawn works well because it doesn't have abunch of other things in it, scents, etc.....& it leaves no residue if rinced properly.
I've painted many parts with epoxy after just a dawn scrub, no epoxy failures. Wax & grease removers won't get everything , the cleaner the part you start with the less W & G work necessary.
If you do a lot of DA sanding for paint removal that can force residues into the metal - don't worry about the water rusting a hole in the car just make sure it clean prior to any paint. All in the prep....
Re: Primer Question / Getting the scamp blasted [Re: edp] #1429413
05/05/13 08:45 PM
05/05/13 08:45 PM
Missouri
Challenger Offline
Challenger  Offline
Missouri
This. All my stuff gets cleaned with dawn soap and water. Get it cleaned, waterboure wax and grease remover and 2 coats of epoxy. Question for those of you that sodablast cars, How do you neutralize the soda before painting? The answer to that question is you wash it with water/soap and do it a couple of times. YES SOAP/WATER.
Re: Primer Question / Getting the scamp blasted [Re: Challenger] #1429414
05/05/13 11:58 PM
05/05/13 11:58 PM
Pasco, WA
440mag Offline OP
440mag  Offline OP
Pasco, WA
So there is no problem using dawn soap and water. A clean bucket of hot soapy water and rinse it off with a hose? Just like a normal wash except I use Dawn soap?
Hoe long do you wait to paint after washing?
Re: Primer Question / Getting the scamp blasted [Re: 440mag] #1429415
05/06/13 12:26 AM
05/06/13 12:26 AM
Canada
demon Offline
demon  Offline
Canada
If it was blasted with brand new clean media, it is ready to prime with epoxy, although I like to sand the surfaces to remove most of the texture that blasting leaves and any little flecks of paint etc that were not 100% removed and then use a final wipe. If recycled media was used you better use a wax and grease remover. I don't let anyone touch my sandblasted or bare metal parts. Always wear latex gloves or you will have rusty fingerprints show up years later under the paint. I've seen it.
Do not use self etching primer on blasted metal. The textured finish will retain the acid and cause problems later too. Same goes for metal prep. Never use metal prep acid on blasted metal. It is only to etch smooth metal.
I don't like tack tags very much either. They can cause fisheyes. If you insist on tacking it use a brand new Quality blue base/clear tack cloth and not one of the cheap ones.
Beautiful 72 Charger by the way! Love the 72 Rallyes!
Re: Primer Question / Getting the scamp blasted [Re: demon] #1429416
05/06/13 05:01 PM
05/06/13 05:01 PM
Pasco, WA
440mag Offline OP
440mag  Offline OP
Pasco, WA
Thanks for the help and suggestions. Pick up the car in the morning.
