Re: 2.76 or 2.94 for turbo car?
[Re: SLOW67]
#1429232
05/02/13 04:15 PM
05/02/13 04:15 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Finally getting back around to working on my Valiant and I'm planning on changing gears sets soon since my old handy work has made my 3.55 whine I want a better gear for cruising and I have considered a 2.76 but with the 28" tires when I'm at the track I'm alittle worried about making my 60' worse than it already is. Would you go with a 2.94 or a 2.76? I plan on doing drag week next year when my 360 is in the car so I need a good highway gear that won't sacrifice too much at the track. It will also be getting a powerglide more than likley this winter with a transbrake so I should be able to spool pretty good off the line.
I dont think your gonna see any difference of those 2 gears... Scott on here with the 62 4 door with the turbo has a 2.76 in his car now but I dont recall what his 60' is and I dont know what pressure he leaves at... all I know is its still set up pretty low(if I recall he maxes out at 10psi)
[Re: RADAMX]
#1429241
05/03/13 03:56 PM
05/03/13 03:56 PM
Posts: 2,256 IL
furious70
IL
3.23's and a 28" tire is ~3000rpm @70mph with a street converter for reference.
70 Sport Fury 68 Charger 69 Coronet 72 RR
[Re: AlexP]
#1429247
05/03/13 10:29 PM
05/03/13 10:29 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
Has anyone here run 2.76-3.23 with a cent supercharger?
Alex, it depends on your set-up. Turbo works different. The S/C is going to be "on" as soon as you hit it and will build boost until you lift. You might even want 3.55's. If you run a 2.76 w/ a stick It might be a dog out of the hole. You won't have any boost until the engine is under load. So when you bring the rpm's up to say 5k you will be at 0 boost then drop the hammer, the 2.76's will drop the rpms too low I think to create decent boost His turbo and the auto will load up the convert and bring up the boost before launch.
