Re: Slow me down!?!?
[Re: hankcrank]
#1429212
05/03/13 08:20 PM
05/03/13 08:20 PM
Posts: 1,596 BX, CT, FL.
B1KILLER
BX, CT, FL.
I have posted this pic a few times now. It is a cheap way of slowing you car down without changing your throttle cable position.With this little spacer the more holes between the cable and the carb lever the slower you will go.
I have done this to go from low 9's to high 12's, and everything in between
[Re: babarracuda]
#1429214
05/04/13 01:06 PM
05/04/13 01:06 PM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
My If you take out a bunch of throttle it will make it very hard to fender race because you got nothing at the top end. It's much better to find the brake pedal later to tighten it up at the stripe.
"Just a Bracket car dressed up like a streetcar"
