AMD 1968 Charger rear quarterpanels fitment?
#1428521
05/01/13 02:53 AM
05/01/13 02:53 AM
Posts: 2,489 Tracy, New Brunswick, Canada
magnumcharger
I was in a shop recently to view a very nice 1968 Charger that it being "upgraded" to Hemi R/T status. The owner was quite proud of his Charger, which he has had for over thirty years. The car recently underwent a very thorough panel replacement, with all new metal from AMD. His only complaint was that his bodyman obviously had difficulty installing the new rear quarters. And unfortunately, didn't mock up the fitment of the quarter panel "eyebrows" or "boomerangs" at the end of the quarters until after the car was already painted. And then, surprisingly, it was found that the contour of the top body line didn't match the eyebrows at all. Not to mention the chrome surrounding the tail lights didn't fit any more. This is the first I've seen this. I didn't take pictures, but I'm including this diagram for illustration. Has anybody else encountered this same problem?
Re: AMD 1968 Charger rear quarterpanels fitment?
[Re: gtx6970]
#1428523
05/01/13 08:55 AM
05/01/13 08:55 AM
Posts: 18,632 jersey shore
flypaper
I hate Texas
I hate Texas
jersey shore
the 69 coronet quarters i bought from AMD fit soo good to their wheelhouse, i bought a original pair of quarters for more money for the next car! i consider AMD as parts of last resort...
[Re: magnumcharger]
#1428524
05/01/13 10:01 AM
05/01/13 10:01 AM
Posts: 1,179 Canada
demon
Canada
If the guy installing the 1/4's didn't fit the 1/4 extensions, then that's his fault and nobody elses. I installed new AMD 1/4's on a 69 Charger and found they fit very nice. Even a brand new or NOS panel can be installed wrong by someone who isn't payng attention. You don't just snap new parts in place. It's not Lego.
[Re: magnumcharger]
#1428525
05/01/13 10:02 AM
05/01/13 10:02 AM
Posts: 3,060 Western New York
sixpackbee
Western New York
I just got done doing both quarters on a Daytona and had just the "normal" amount of massaging that usually occurs with most aftermarket parts. The extensions fit decently only requiring a little adjustment on the sides. No problems as you have illustrated. The only real PITA with the Charger AMD stuff were the valance corners. I had to work them pretty hard. I have a 69 Coronet coming in soon and will see how the AMD stuff is there as he has one NOS quarter for it. Will be a real good test.
1959 Bugeye Sprite 1967 Charger Black L code 1967 Coronet R/T Convert Green 440 auto bought from original owner 1968 Charger R/T Bronze 440 4 spd console AM/FM 1969 Super Bee WM21H B5 A40 D21 N96 1969 Barracuda Formula S 340 Convert pilot car 1969 Hemi Road Runner RM23J D32 Omaha orange 4.10 Dana N96 N85 1970 Super Bee WM23N FE5 V1X 3.91 axle package, N96 1970 Road Runner RM21N B3 V1X D13 1971 MG Midget 1971 Road Runner RM23H GW3, A57 1972 Road Runner RM23P FY1, D21
[Re: 68_661charger]
#1428528
05/02/13 12:52 AM
05/02/13 12:52 AM
Posts: 1,264 New York, USA
Chargerfan68
New York, USA
I have the same exact issue with the drivers qtr to endcap, but, the pass side lines up very close to the endcap. My drivers' qtr corner shape is off exactly the same way your drawing is.
I will modify and reshape it to fit the endcap, since that is a factory piece.
That sucks that the bodyman missed that before it was painted.
Good luck.
[Re: notforsale440]
#1428530
05/02/13 08:39 PM
05/02/13 08:39 PM
Posts: 18,160 Mass
DAYCLONA
Mass
the body man dropped the ball...........everything that is not mocked up and massaged for fit will bite you in the ass after paint.........its the attention to detail PRIOR TO PAINT that separates the pros from the smoes..........
EXACTLY.....couldn't agree more...
I Have NOS quarters on my 70 Charger, I had issues with the end caps, but a proper fitting/adjustments, time towards detail, verify all trim and components, glass, etc, etc are fitted before paint is the only way to go regardless of the components used, new/repro/NOS/used...doesn't matter, you drop the ball, or assume everything is "Hunky Dory", you'll be sorry later...
FWIW, I've hung several sets of AMD Charger and RoadRunner full qtrs,...no different than NOS or original used, In fact I prefer the AMD qtrs, metal is a lot thicker, .040 vs the factory .030
Mike
[Re: Chargerfan68]
#1428533
05/08/13 04:59 AM
05/08/13 04:59 AM
magnumcharger
Good luck.
Can you please post a picture of your quarter/endcap together BEFORE you fix it?
[Re: DAYCLONA]
#1428535
05/08/13 06:35 PM
05/08/13 06:35 PM
flypaper
I hate Texas
I hate Texas
jersey shore
Mike
not for a 69 coronet the sharpness of the lines on the amd panel is WRONG to the original quarter! the trunk gutter lip is off i know for FACT because i compared the 2 side by side! so much i'm half tempted to drill off the AMD garbage thats already installed! so put down your AMD trumpet!
[Re: DAYCLONA]
#1428537
05/09/13 05:14 PM
05/09/13 05:14 PM
Posts: 5,268 NY
70440+6bbl
NY
Mike
It may be thicker, but it sure bends a LOT easier...
[Re: flypaper]
#1428538
05/11/13 08:29 PM
05/11/13 08:29 PM
Posts: 84 NW Pennsylvania
areibel
NW Pennsylvania
The guy doing the work should be able to take care of small problems, or he shouldn't be doing the work! I watched a guy use one of the old standard "Canadian hand formed" quarter patch panels back about 1988, it turned out great. But he was good, and he had probably 4 times the hours into doing it vs. replacing with a full quarter. I put a set of '70 Coronet quarter skins on back in the 90's, they were crap but they did work.
NOS or good used sheetmetal is great if you can find it (and afford it), but I've seen dozens of cars done with AMD metal that looks as good as original when it's done. Maybe down there in Snookiland you're tripping over good sheetmetal, but it ain't like that around here. You've got a bad opnion of AMD, that's your right. But AMD or Goodmark are the only options for a lot of guys. And they're a lot better than what used to be available
[Re: areibel]
#1428539
05/11/13 08:59 PM
05/11/13 08:59 PM
flypaper
I hate Texas
I hate Texas
jersey shore
you just picked on the wrong guy here..
the guy doing the work was me and it was not a "small issue" when i called the amd install center they told me they never had any issuse with thier wheelhouses more the one time.. they would not let me return them at all. fast foward i discovered that the part was retooled.. busted... then i pushed harder and found out the molds were made made off a 4 dr wheelhouse so they never had a prayer of fitting.. when confronted AMD knew i caught them COLD with thier pants down and it took alot to get them to make good.
AMD sells you junk at top dollar and will lie about it when you have a problem... that is my main issue with them. if they didn't lie and jerk me around like i'm a idiot i might feel different.
btw it took me splicing 4 AMD wheelhouses together to make 2 that would fit properly.. i do not put together a mudmobile!..
i buy as much orig metal that i can find now, for more money then AMD is. just spent a fortune on 2 orig cut off quarters from texas the time i save installing,more then makes up for the cost i can also pick out your AMD mobile without much effort on my part!
all i will say is don't ASSUME that all of thier junk fits!
btw my siggy is a quote from another member here with AMD issuses so i know i'm not alone telling people AMD is as good as orig or nos is a joke
[Re: flypaper]
#1428540
05/11/13 09:21 PM
05/11/13 09:21 PM
areibel
NW Pennsylvania
I ain't picking on anyone, and I've read all about your AMD issues. Yeah, they effed up on that part, but they're the first one to do that? Come on! I know of more than one company that's done that. You sound like you know what you're doing, but dang near ever post that deals with AMD has you chiming in and complaining about them- OK, why not post your fixes instead of just whining? YOu talked about the 69 Coronet quarters, I know of two 68-69 Coronets in yards near me but you're not going to salvage any sheetmetal from them. Nothing from the door handles down, anyway! My buddy used AMD's, he had a good shop do it and it turned out great. My curent project is a 69 Charger. I can hunt around and maybe pay $2K (plus shipping) each for NOS ones that have been banging around for 40+ years or I can buy a pair of AMD- that's what I'm going to do. No one will be able to tell when I'm finished, I don't have the money to buy original and have it shipped here. A couple extra hours of work and another car that would have just sat and rotted will be on the road for less than half the total price of NOS or used original.
