coil bracket 440 performer rpm #1424292
04/23/13 03:25 PM
04/23/13 03:25 PM
indy
70moparmike Offline OP
indy
running a performer rpm on a 69 gtx. need to know what you guy's use for a coil bracket? don't think stock will work with air grabber drop air cleaner? and also what throttle cable do you run, length? mine is to short now, i think. thanks moparts
Re: coil bracket 440 performer rpm [Re: 70moparmike] #1424293
04/23/13 03:54 PM
04/23/13 03:54 PM
scratchnfotraction Offline
AndyF/AREngineering makes a nic one for the RPM intake that mounts it standing up in the gap/valley area at front of intake.
I have a RPM on my 88-440 truck and used the stock 4-V throttle/kickdown bracket and 3 piece linkage from a 78 truck.
I had to raise the clamp for the throttle cable on mine but other than that stock bracket worked for TV linkage.
AndyF makes a tall throttle bracket for the RPM intake also. looks stock but much taller at the throttle cable clamp. works with stock 3-piece linkage.
Re: coil bracket 440 performer rpm [Re: scratchnfotraction] #1424294
04/23/13 07:53 PM
04/23/13 07:53 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I bought a Ford-style bracket off Feebay for mine; attaches with 1 bolt - plenty secure - and it's far enough away from the Holley carb that bowl R&I is no problem.
Re: coil bracket 440 performer rpm [Re: scratchnfotraction] #1424295
04/24/13 12:18 AM
04/24/13 12:18 AM
heres another from ARE for a horozontal mount.
Re: coil bracket 440 performer rpm [Re: scratchnfotraction] #1424296
04/24/13 08:41 AM
04/24/13 08:41 AM
indy
indy
the stand up one is to tall for the drop air cleaner, but the rear mount looks perfect, thanks. now about the throttle cable? three peice linkage? i only have a cable? thanks
Re: coil bracket 440 performer rpm [Re: 70moparmike] #1424297
04/24/13 09:20 AM
04/24/13 09:20 AM
New York
R/T1968R/T Offline
R/T1968R/T  Offline
New York
Right up front!
Re: coil bracket 440 performer rpm [Re: 70moparmike] #1424298
04/24/13 09:28 AM
04/24/13 09:28 AM
the bouchillon has a cut to fit throttle cable for mopar.
3-piece linkage is for auto trans kickdown. which mounts on the throttle cable intake bracket.
do you have a manual trans?
Re: coil bracket 440 performer rpm [Re: scratchnfotraction] #1424299
04/24/13 01:04 PM
04/24/13 01:04 PM
Minnesota
72blubird Offline
72blubird  Offline
Minnesota
Here is the way mine is mounted you can see it fits under my stock air cleaner. It uses an offset flat remount piece that mounts to intake holes.
What was I thinking....
Re: coil bracket 440 performer rpm [Re: 70moparmike] #1424300
04/24/13 02:45 PM
04/24/13 02:45 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
here is what I did, so I can pull the carb fuel bowls without the coil in the way.
Re: coil bracket 440 performer rpm [Re: 451Mopar] #1424301
04/24/13 02:48 PM
04/24/13 02:48 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Also, the return spring and bracket, and the throttle cable bracket are from Andy F.
Re: coil bracket 440 performer rpm [Re: 451Mopar] #1424302
04/24/13 04:43 PM
04/24/13 04:43 PM
St. Croix, US Virgin Islands
David_in_St_Croi Offline
I mounted ours on the top of the right side inner fender. Less clutter over the top of the engine, keeps the coil a little cooler. Ran the wires along the top of the inner fender using little white plastic pieces that use a cable tie to hold the wires and a # 6 or 8 machine screw through the top of the inner fender. While the engine is out I am hoping to find the time to rebuild the harness and eliminate some stuff and run the alternator wires the same route so the only wires over the top of the engine are the distributor pickup wires. The move into the house we just completed (they are never complete of course) is sucking up all the time though.
We have a low deck so can't help you on the cable length. For what it is worth the one I used to replace the one that broke one night at the track is 24" I got from Mancini (jury rigged something at the track of course). The 24" I am sure would work just fine on a 440, they are not that much taller. For a bracket just made our own from a piece of aluminium to use the stock holder down bit, see attached. Of course, since we are going to a tunnel ram the bracket will be redesigned anyway.
Oh, car is a 70 RR
https://www.facebook.com/THENEWCDRA
Proud member of the liberal scientific elite
Re: coil bracket 440 performer rpm [Re: David_in_St_Croi] #1424303
04/24/13 05:06 PM
04/24/13 05:06 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
I went to the hardware store and found a clamp that was meant for a pole on a chain link fence. I slipped a piece of vinyl tubing over the plated clamp, slid the coil into the clamp and bolted it to the inner fender of my '64 Polara. Simple, cheap and actually looked good. The picture is too big to submit and the Polara now lives in a Chicago suburb.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
