How would you fix this? #1423085
04/21/13 01:37 PM
04/21/13 01:37 PM
CentralVA.
BBCoronet Offline OP
CentralVA.
Want to get started on my 69 RR and the worst part of the car is out back......trunk floor and rails are shot.....I have a clean trunk floor/rails/inner wheelhouses from a 70 Coronet. Should I leave this all together or install piece by piece?
Re: How would you fix this? [Re: BBCoronet] #1423086
04/21/13 01:44 PM
04/21/13 01:44 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Install it as an assembly, it's all square & securely welded, why drill out all those welds just to put new welds back in the same spots?
Re: How would you fix this? [Re: 1_WILD_RT] #1423087
04/21/13 01:48 PM
04/21/13 01:48 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
I also agree, replace as large a section at one time as possible. The first thing I'd be thinking about is being sure that the replacement parts are 100% rust free via blasting or dipping (the areas between the seams and pinch welds would be the highest concern). Then getting every last bit of the old/original rusted parts off of your car leaving nothing behind. Be sure to use temporarily welded in supports to keep the good areas properly aligned while doing major section and frame removals.
Re: How would you fix this? [Re: ScottSmith_Harms] #1423088
04/21/13 11:34 PM
04/21/13 11:34 PM
CentralVA.
CentralVA.
Would the rear cross member be the same between the Coronet & RR? The "Junkyard Dog" thread in Members Projects did the one piece swap....Good info and pix there!
Re: How would you fix this? [Re: BBCoronet] #1423089
04/22/13 01:25 AM
04/22/13 01:25 AM
jersey shore
flypaper Offline
I hate Texas
flypaper  Offline
I hate Texas
jersey shore
the stuff will all interchange and fit better then the repo metal will.
there might be some minor differances between the 2
you will have to eyeball it up to know for sure
what your are up against.
one important thing to note is
the rear spring shackle mounting point is different from dodge to plymouth.
one is further towards back then the other
the differance is made up with a differant front spring hanger.
that is stuff to be aware of so
you can line up the rear springs properly
when you put it all back together.
Re: How would you fix this? [Re: BBCoronet] #1423090
04/22/13 10:25 AM
04/22/13 10:25 AM
pa.
dan9 Offline
dan9  Offline
pa.
Also aren't wheelhouses different between Dodge and Plymouth? I think wheelbase is different but i don't know where the difference is.
Re: How would you fix this? [Re: dan9] #1423091
04/22/13 06:36 PM
04/22/13 06:36 PM
CentralVA.
CentralVA.
By looking at AMD parts; The outer wheelhouses are different/ Inners Wheelhouses, frame rails and trunk floor are the same.
Re: How would you fix this? [Re: BBCoronet] #1423092
04/23/13 04:30 PM
04/23/13 04:30 PM
Bellevue,Mich.
Dodge33 Offline
Dodge33  Offline
Bellevue,Mich.
The only difference in the rear framerails, if I'm remembering right, the 70 rear rail's, on the right rear framerail there is an oval hole, on the inside and outside. Most 69 rail's do not have these hole's in them. You can weld them up, if need be. Beside's that,
they are 100% the same. Just like BBcoronet said, all is the same, except for the outer wheelhouse's.
Re: How would you fix this? [Re: BBCoronet] #1423093
04/23/13 04:46 PM
04/23/13 04:46 PM
Washington State
70_FY1_N96_BEEP Offline
Washington State
Wheelbase lengths are different between Dodge and Plymouth. Found that out with my drive shaft. Study and ask questions.
Re: How would you fix this? [Re: 70_FY1_N96_BEEP] #1423094
04/23/13 10:04 PM
04/23/13 10:04 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
That is in the spring hanger which is a bolt on piece...
Re: How would you fix this? [Re: 1_WILD_RT] #1423095
04/23/13 10:10 PM
04/23/13 10:10 PM
jersey shore
flypaper Offline
I hate Texas
flypaper  Offline
I hate Texas
jersey shore
where the rear spring shackle mounts is different also
and that is not a bolt on piece.
Re: How would you fix this? [Re: flypaper] #1423096
04/23/13 11:38 PM
04/23/13 11:38 PM
CentralVA.
CentralVA.
Anyone have the frame specs on 69 Ply. B body and a 70 Dodge B body?? I guess I could measure everything before getting started but frame specs would be nice.........
Re: How would you fix this? [Re: BBCoronet] #1423097
04/23/13 11:54 PM
04/23/13 11:54 PM
jersey shore
flypaper Offline
I hate Texas
flypaper  Offline
I hate Texas
jersey shore
the rear frame rails have identical dimensions.
the differance between the 2 is a support
that comes off of the rear frame rail.
it is where the rear spring shackle mounts to.
compare the area where that rear shackle mounts to
on both your rails
and the differance will be obvious to you!
