Re: clutch pedal switch
[Re: cudablues]
#142296
10/27/08 02:02 PM
10/27/08 02:02 PM
Posts: 5,446 So Cal
Sinitro
So Cal
A couple of things.. The clutch pedal switch is a lever micro switch which is normally open and is closed when the pedal is engaged. When closed the switch grounds the starter control relay so the starter can turn over. These switches can be expensive.. You mite want to check with Wayne @ Brewers Performance, he has had these available. www.brewersperformance.com937-698-4259 Just my ...
[Re: cudablues]
#142299
10/27/08 04:15 PM
10/27/08 04:15 PM
Posts: 5,446 So Cal
Sinitro
So Cal
Holy ****,290.00.Maybe i can figure a way to rivet a pin back on.What if i dont hook it to the starter?
Remember.. We warned you that it was pricey..
A simple fix.. Just run a short jumper lead from the lower rite terminal of the starter relay to ground..
Note now it will start in any gear even when the clutch pedal is not depressed..
Actually I prefer this way and have been running the RoadRunner for years this way.
Just my ..
[Re: cudablues]
#142304
10/27/08 06:28 PM
10/27/08 06:28 PM
Posts: 200 BC, Canada
thrashingcows
BC, Canada
Is it just the tip that's broken off....I'd rivet a small "L" shaped piece to the main arm and go with it that way.
Brian
1984/93 W350 Cummins Crewcab, NV4500, 3.54's 1984 Ramcharger Sno-Commander 360/auto 68 Chrysler T/C Station Wagon 440/auto
The only reason people get lost in thought is because it's unfamiliar territory!!
[Re: cudablues]
#142306
10/27/08 08:24 PM
10/27/08 08:24 PM
Posts: 8,850 Central Coast, Calif.
Snoopy
Holy ****,290.00.Maybe i can figure a way to rivet a pin back on.What if i don't hook it to the starter?
That's a 70 only switch, although it will work on your car. I have seen the later model switches for a lot less on eBay. Usually NOS for below $100.
