Re: Hood/Deck-Lid/Qtr Ext (Moulding/Trim Foam Washers?)
[Re: moparmojo]
#1422158
04/23/13 09:11 PM
04/23/13 09:11 PM
Posts: 216 SE PA
Born2Run
SE PA
These are from an NOS deck lid molding and NOS 1/4 molding I have for my 71 Challenger. The deck lid molding uses these clips on the two end holes only. The 1/4 moldings use (3) clips. Try Jim at http://www.detroitmuscletechnologies.com/ - he made me some of the black foam washers/seals. Rich
[Re: Born2Run]
#1422159
04/23/13 10:22 PM
04/23/13 10:22 PM
Posts: 401 California, USA
filmsurgeon
California, USA
Rich
Thanks. I've bought some of Jim's (DMT) stuff very recently. I'll contact him and see if there's anything he can do. Thanks for the NOS photos also.
[Re: Born2Run]
#1422160
04/23/13 11:27 PM
04/23/13 11:27 PM
Posts: 12,432 Warren, MI
71TA
Warren, MI
Rich
I have the tools for both these now (thanks). The whitish material - a guy sent me the washers on the studs of 70-71 Duster taillight bezels. Same material. This whitish, rubbery material is also used on the cuda fender gill studs. I found a GOOD functional equivalent material for this stuff; gum rubber sheets.
On that stud above with the whiteish seal, can you tell me how thick that is? Gum rubber comes in 1/16 and 1/8 but I can get 3/32" made.
The white ones Joe needs are easy. How many? Where are they used? ID? OD? Thickness (1/16", 3/32", 1/8"?)
[Re: 71TA]
#1422161
04/24/13 08:36 AM
04/24/13 08:36 AM
Posts: 216 SE PA
Born2Run
SE PA
Hi Jim I'll measure the whitish washer/seal tonight when I get home. I should be able to get an approximate ID, OD and thickness. Rich
[Re: 71TA]
#1422164
04/25/13 03:11 AM
04/25/13 03:11 AM
filmsurgeon
California, USA
I have the tools for both these now (thanks). The whitish material - a guy sent me the washers on the studs of 70-71 Duster taillight bezels. Same material. This whitish, rubbery material is also used on the cuda fender gill studs. I found a GOOD functional equivalent material for this stuff; gum rubber sheets. On that stud above with the whiteish seal, can you tell me how thick that is? Gum rubber comes in 1/16 and 1/8 but I can get 3/32" made. The white ones Joe needs are easy. How many? Where are they used? ID? OD? Thickness (1/16", 3/32", 1/8"?)
Glad to know I'll be able to get these from you Jim.
I would have taken caliper measurements of the ones that came off my car, but they are so far from being close to what would have been their original shape. I did not find the thicker black foam washers/seals when I removed the 1/4 trim pieces. I'll definitely need both. The hood trim uses (8) clips; the deck-lid trim uses (2) clips; and the two 1/4 trim pieces use a total of (6) clips. So, I'll need at least (10) thin white foam washers/seals, and at least (6) thicker black foam washers/seals. Thanks to all for the help.
[Re: 71TA]
#1422166
05/03/13 02:01 AM
05/03/13 02:01 AM
filmsurgeon
California, USA
I'll put that together as a set and probably add it to my Challenger gasket set.
I'll get you a set for compiling the info.
What is the OD/ID again of the thin white ones? I'm gonna assume like .187" or .250" thick. Like you said probably more of an anti rattle then a seal.
Thank you Jim.
Thin white washers= ID = ~0.160" OD = ~0.460" 0.105-0.110"
