Re: E-Brake Pedal Restoration Tips?
[Re: filmsurgeon]
#1422054
04/29/13 05:51 AM
04/29/13 05:51 AM
Posts: 401 California, USA
filmsurgeon
California, USA
I realized as I was working on this that there was no parking brake switch when I took the assembly out of the car (thanks previous owner). Does anyone know where I can get one, and where/how in the wiring harness is it connected? Thanks.
![](/ubbthreads/images/graemlins/popcrn.gif)
[Re: filmsurgeon]
#1422057
04/30/13 06:39 PM
04/30/13 06:39 PM
filmsurgeon
California, USA
Is there any difference between these two switches, other than what appears to be different part numbers? (Part description is above each photo). Thanks.
NOS MOPAR 1970-71 E/BODY HAND BRAKE SIGNAL LAMP SWITCH
![](http://i1337.photobucket.com/albums/o671/filmsurgeon/Misc/NOSMOPAR1970-71EBODYHANDBRAKESIGNALLAMPSWITCH_zpsad018b86.jpg)
NOS MOPAR PARKING BRAKE INDICATOR & DOOR JAMB LAMP SWITCH 1960 1961 1962
Anyone ??
[Re: gtx6970]
#1422061
02/01/14 02:06 PM
02/01/14 02:06 PM
Posts: 2,938 California
1970mopar
California
Only thing I would have done differently would be remove , straighten and have the release rod replated.
![](/ubbthreads/images/graemlins/iagree.gif)
The release rod needs to be straight as it travels thru the original plastic guide. (appears missing) Your rubber gromet will not last very long as the rod will tend to pull it out of the hole its in. ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: gtx6970]
#1422062
02/01/14 06:16 PM
02/01/14 06:16 PM
filmsurgeon
California, USA
Only thing I would have done differently would be remove , straighten and have the release rod replated. The release rod is very visible once installed
Thanks for the tip. I didn't realize mine was not correct. I really don't want to have to take out the assembly to do this, but I suppose I could try straightening the rod with it mounted in the car. Is the rod supposed to be straight (starting from the handle all the way back to where it attaches at the rear)? As you might be able to see in my photos, mine has a couple of bends in it (from the handle to where it goes through the grommet). I did spray silicon lubricant in the grommet hole, and the rod moves very smoothly through it without grabbing it. I had to replace the plastic one that was there because it was in really rough shape.
[Re: gtx6970]
#1422064
02/01/14 07:32 PM
02/01/14 07:32 PM
filmsurgeon
California, USA
I think I have a 1970 E body park brake assy . I'll dig it out tomorrow am and snap off a picture or 2
The one I posted above is 1968-69 B body
Thanks. I think I got the answer to my question. Here's a photo I had saved of someone else's assembly. The release rod has the same two bends that mine has. So I just need to try and straighten the portion starting from the grommet toward the back.
[Re: filmsurgeon]
#3093081
11/10/22 10:13 AM
11/10/22 10:13 AM
Posts: 30 Chandler AZ USA
AZMoparboy
Chandler AZ USA
Only thing I would have done differently would be remove , straighten and have the release rod replated. The release rod is very visible once installed Thanks for the tip. I didn't realize mine was not correct. I really don't want to have to take out the assembly to do this, but I suppose I could try straightening the rod with it mounted in the car. Is the rod supposed to be straight (starting from the handle all the way back to where it attaches at the rear)? As you might be able to see in my photos, mine has a couple of bends in it (from the handle to where it goes through the grommet). I did spray silicon lubricant in the grommet hole, and the rod moves very smoothly through it without grabbing it. I had to replace the plastic one that was there because it was in really rough shape. Hi, I know this thread is a few years old but it discusses exactly what I am attempting to restore. The parking brake release rod passes through a little plastic bushing and I am not understanding how this very rigid little plastic bushing is installed into the brake assembly. I bought this nice kit with the two springs and the bushing. The small bushing is very hard plastic and with the rod out of the way I just don’t understand how it is to be installed in the bushing hole without damaging the bushing or the bushing hole. Maybe it is so simple to install, that’s why I can’t figure it out. If anyone would give me a little advice, 😊 Azmoparboy
