727 tail shafts #1421901
04/18/13 06:19 PM
04/18/13 06:19 PM
Milwaukee WI
R_Blaha Offline OP
R_Blaha  Offline OP
Milwaukee WI
Is the tail shaft the same on a 727 big block to small block? How easy can this be changed in the car? I'm replacing my tranny mount in my 70 cuda and the tranny mount on the tail shaft is messed up.
LOOKING FOR THE 68 GTS IN THE AVATAR SPOT
1969 Dodge Superbee post coupe 383
1969 Dodge Superbee hardtop 472 hemi
1989 Mustang GT
1993 mustang lx 5.0
2004 screaming yellow cobra
2013 CVO Roadglide
Re: 727 tail shafts [Re: R_Blaha] #1421902
04/18/13 06:26 PM
04/18/13 06:26 PM
okla.
sam64 Offline
sam64  Offline
okla.
should be,just know that there is a snap ring that is under the little plate with 2 screws that has to be spread open to remove housing.
Re: 727 tail shafts [Re: R_Blaha] #1421903
04/18/13 07:39 PM
04/18/13 07:39 PM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
The trans mount locations are all the same ... but there IS a diff as far as other stuff ...like OEM shifter tabs and damper mounts.
