Code on Broadcast Sheet Question ... #1420959
04/16/13 10:03 PM
04/16/13 10:03 PM
Florida, US
72ls5fla Offline OP
72ls5fla  Offline OP
Florida, US
Hey,
I had Galen decode the TAG and BC Sheet for my car.
What does J55 : "Undercoating with hood insulation pad" mean?
My car is a N96 car, so how would it have the pad?
Also -
does the under coating mean the entire bottom of the car was treated or just inside the wheel wells (F & R) ?
Thanks in advance
Bil
Got me a NEW Project
1970 GTX 440+6, 4 spd, 4.10 Dana and N96 FE5 (top/bottom) and black bucket interior.
Original transmission and Dana - Engine is a service replacement block.
Body has all stamped #s + VIN/TRIM tag and door sticker. Been hunting like all hell to find the Build Sheet.
garage find, only had 41,850 miles on ODO.
Re: Code on Broadcast Sheet Question ... [Re: 72ls5fla] #1420960
04/16/13 10:17 PM
04/16/13 10:17 PM
Las Vegas, NV
6bblgt Online work
6bblgt  Online Work
Las Vegas, NV
If J55 was ordered on a "fresh air hood" car, it did not receive the hood pad and the OPTION's price was still the same ($16.60 on a '70 Challenger).
The underside of the car was undercoated before K-frame/engine & rear axle/springs were attached to the body.
Re: Code on Broadcast Sheet Question ... [Re: 6bblgt] #1420961
04/16/13 10:18 PM
04/16/13 10:18 PM
Las Vegas, NV
6bblgt Online work
6bblgt  Online Work
Las Vegas, NV
ALL "street cars" had the 4 wheel wells undercoated - STANDARD.
Re: Code on Broadcast Sheet Question ... [Re: 6bblgt] #1420962
04/16/13 10:18 PM
04/16/13 10:18 PM
Florida, US
72ls5fla Offline OP
72ls5fla  Offline OP
Florida, US
thanks for the info ....
really appreciate it.
Bill
Re: Code on Broadcast Sheet Question ... [Re: 72ls5fla] #1420963
04/16/13 10:38 PM
04/16/13 10:38 PM
Florida, US
72ls5fla Offline OP
72ls5fla  Offline OP
Florida, US
dan --
i'm assuming the under coating was applied after body paint. Is this correct?
also - where all the hard lines (gas/brake/emergency cables) in place prior to under coating?
thanks in advance ,,
Bill
Re: Code on Broadcast Sheet Question ... [Re: 72ls5fla] #1420964
04/16/13 11:33 PM
04/16/13 11:33 PM
Las Vegas, NV
6bblgt Online work
6bblgt  Online Work
Las Vegas, NV
After paint, YES
Gas & brake lines - YES.
Parking brake: ? I'd guess the pedal & cable were there - coming out of the inner fender going to the crossmember, but the bottom-side cables wouldn't be installed yet - as the rear axle isn't there.
Re: Code on Broadcast Sheet Question ... [Re: 72ls5fla] #1420965
04/16/13 11:44 PM
04/16/13 11:44 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Yes & no.
Full undercoat as an option, yes, after body paint.
Undercoating was also referred to as sound deadner when used;
In the rear quarters (trunk area) pre-paint, same for inside the door skins.
Wheel well sound deadner was applied after paint.
Re: Code on Broadcast Sheet Question ... [Re: Alaskan_TA] #1420966
04/16/13 11:53 PM
04/16/13 11:53 PM
Las Vegas, NV
6bblgt Online work
6bblgt  Online Work
Las Vegas, NV
Which was done before the door was a door & before the 1/4 was part of the unibody.
Re: Code on Broadcast Sheet Question ... [Re: Alaskan_TA] #1420967
04/16/13 11:56 PM
04/16/13 11:56 PM
Florida, US
72ls5fla Offline OP
72ls5fla  Offline OP
Florida, US
thank you (both) for the clarification.
I am going to have an opportunity to get the car up on a rotisserie.
Car was in an accident and will be having significant work done to it.
Idiot kid ran a stop sign and it creamed the entire front clip .. BADLY ..
I figure it might be a good time to do the underside correctly.
Right now it is dip tank gray with blue overspray on it...
Bill
Re: Code on Broadcast Sheet Question ... [Re: 72ls5fla] #1420968
04/17/13 12:03 AM
04/17/13 12:03 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Is it the 1970 shaker Challenger?
Re: Code on Broadcast Sheet Question ... [Re: Alaskan_TA] #1420969
04/17/13 12:28 AM
04/17/13 12:28 AM
Florida, US
72ls5fla Offline OP
72ls5fla  Offline OP
Florida, US
yep ........
Got a real mess on my hands..
Thankfully Grundy (Phil Indem Comp) is my insurer and I have a stated value policy with a high ass value.
So I am gonna be good - and not get it totaled.
But it is going to come damn close to the 80% mark..
Just got the initial estimate from the adjuster - it went back to them for further refinement. not even close. missing around 18K
and all this and not even at the body/resto shop yet ....
can't wait to see what they find and have to get a supplement for ....
Bill
Re: Code on Broadcast Sheet Question ... [Re: 72ls5fla] #1420970
04/17/13 01:33 AM
04/17/13 01:33 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Hit me with the numbers in an email, 1970 N96 Challeners are pretty scarce. I can add yours to the count & give you a letter with a total of known cars if it will help at all?
Re: Code on Broadcast Sheet Question ... [Re: Alaskan_TA] #1420971
04/17/13 01:40 AM
04/17/13 01:40 AM
Florida, US
72ls5fla Offline OP
72ls5fla  Offline OP
Florida, US
barry
i emailed ya..
bill
