Code on Broadcast Sheet Question ...
#1420959
04/16/13 10:03 PM
04/16/13 10:03 PM
Posts: 238 Florida, US
72ls5fla
Florida, US
Hey,
I had Galen decode the TAG and BC Sheet for my car.
What does J55 : "Undercoating with hood insulation pad" mean? My car is a N96 car, so how would it have the pad?
Also - does the under coating mean the entire bottom of the car was treated or just inside the wheel wells (F & R) ?
Thanks in advance
Bil
Got me a NEW Project 1970 GTX 440+6, 4 spd, 4.10 Dana and N96 FE5 (top/bottom) and black bucket interior. Original transmission and Dana - Engine is a service replacement block.
Body has all stamped #s + VIN/TRIM tag and door sticker. Been hunting like all hell to find the Build Sheet.
garage find, only had 41,850 miles on ODO.
Re: Code on Broadcast Sheet Question ...
[Re: 6bblgt]
#1420962
04/16/13 10:18 PM
04/16/13 10:18 PM
72ls5fla
Florida, US
thanks for the info .... really appreciate it.
Bill
[Re: 72ls5fla]
#1420963
04/16/13 10:38 PM
04/16/13 10:38 PM
72ls5fla
Florida, US
dan --
i'm assuming the under coating was applied after body paint. Is this correct?
also - where all the hard lines (gas/brake/emergency cables) in place prior to under coating?
thanks in advance ,,
Bill
[Re: 72ls5fla]
#1420965
04/16/13 11:44 PM
04/16/13 11:44 PM
Posts: 29,652 Hamtramck, PA
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
Yes & no.
Full undercoat as an option, yes, after body paint.
Undercoating was also referred to as sound deadner when used;
In the rear quarters (trunk area) pre-paint, same for inside the door skins.
Wheel well sound deadner was applied after paint.
[Re: Alaskan_TA]
#1420966
04/16/13 11:53 PM
04/16/13 11:53 PM
Posts: 17,516 Las Vegas, NV
6bblgt
Las Vegas, NV
Which was done before the door was a door & before the 1/4 was part of the unibody.
[Re: Alaskan_TA]
#1420967
04/16/13 11:56 PM
04/16/13 11:56 PM
72ls5fla
Florida, US
thank you (both) for the clarification.
I am going to have an opportunity to get the car up on a rotisserie. Car was in an accident and will be having significant work done to it. Idiot kid ran a stop sign and it creamed the entire front clip .. BADLY ..
I figure it might be a good time to do the underside correctly. Right now it is dip tank gray with blue overspray on it...
Bill
[Re: Alaskan_TA]
#1420969
04/17/13 12:28 AM
04/17/13 12:28 AM
72ls5fla
Florida, US
yep ........ Got a real mess on my hands.. Thankfully Grundy (Phil Indem Comp) is my insurer and I have a stated value policy with a high ass value. So I am gonna be good - and not get it totaled. But it is going to come damn close to the 80% mark.. Just got the initial estimate from the adjuster - it went back to them for further refinement. not even close. missing around 18K and all this and not even at the body/resto shop yet .... can't wait to see what they find and have to get a supplement for .... Bill
