Engine Dolly/Cart Needed for Big Block #1420897
04/16/13 04:58 PM
04/16/13 04:58 PM
Macomb, MI
V
vinnyd76 Offline OP
vinnyd76  Offline OP
V
Macomb, MI
Anyone have any recommendations on those low profile engine carts? I have a matching numbers 440 engine that I do not want to put back in my father's 1970 Dodge Coronet R/T, so I would like to store it safe on a cart to move with ease and not take up much room.
Re: Engine Dolly/Cart Needed for Big Block [Re: vinnyd76] #1420898
04/16/13 05:37 PM
04/16/13 05:37 PM
Washington State
70Duster440 Offline
70Duster440  Offline
Washington State
I have pre-fab steel ones but I've also made a couple with 2x6 lumber and casters. Fit the pan rail.
Re: Engine Dolly/Cart Needed for Big Block [Re: vinnyd76] #1420899
04/16/13 05:39 PM
04/16/13 05:39 PM
Washington State
70Duster440 Offline
70Duster440  Offline
Washington State
...and yes, it's strong enough.
Re: Engine Dolly/Cart Needed for Big Block [Re: vinnyd76] #1420900
04/16/13 05:57 PM
04/16/13 05:57 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I have 3 really slick dolly's that cost 125+ dollars each.They are used in a race car trailer that travels all over the US. So they had to be sturdy and hold expensive hemis.
Wood furniture dollys work fine also.
And then I have some bread dolly's that they haul bread on when it get's delivered to restaurants. They put the plastic trays in this metal frame to roll around buns and bread.
It works really well for next to nothing if you can find some old one's laying around behind restaurants usually out by the dumpster.
I have had this one for a long time and it has held up, the wood on it is seasoned. Takes years to get the wood to this point, well oiled.
Turn the 2X8on the ends and you could easily build a box to set your engine in...for free!
How do you like my homemade squeegee? I made everything years ago before I could afford to buy it.
Re: Engine Dolly/Cart Needed for Big Block [Re: 70Duster440] #1420901
04/16/13 06:24 PM
04/16/13 06:24 PM
Cincinnati, Ohio
Cincinnati, Ohio
Nice job, ain't nothing wrong with that other than you got to get some oil or paint on that wood. Your choice!!
Re: Engine Dolly/Cart Needed for Big Block [Re: vinnyd76] #1420902
04/16/13 06:43 PM
04/16/13 06:43 PM
Warren, MI
71TA Offline
71TA  Offline
Warren, MI
I'd go with one of Andy's stands. That's what I have. I'm not that good at carpentry
http://arengineering.com/products/big-block-2/
www.DetroitMuscleTechnologies.com Mopar body and heater box restoration gaskets
Re: Engine Dolly/Cart Needed for Big Block [Re: 71TA] #1420903
04/16/13 07:23 PM
04/16/13 07:23 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
My numbers 383 resides in the corner of the garage on one of these:
http://www.harborfreight.com/movers-dolly-93888.html
Threw a piece of cardboard down & it fits on there just fine. $12 at HFT.... Cant beat it.
Re: Engine Dolly/Cart Needed for Big Block [Re: vinnyd76] #1420904
04/16/13 09:39 PM
04/16/13 09:39 PM
tucson az
frank Offline
frank  Offline
tucson az
I use the one from AR Engineering. Its a good quality part. I think I purchased from Mancini. Nothing wrong with a sturdy wood cart though.
Re: Engine Dolly/Cart Needed for Big Block [Re: 70Duster440] #1420905
04/16/13 11:05 PM
04/16/13 11:05 PM
St. Charles, MO
wingman Offline
Uncreative Title
wingman  Offline
Uncreative Title
St. Charles, MO
Yep I made one similar to this. That's the beauty of the flat pan rail on a big block! Sets right on the wood--all 4 sides.
1969 Dodge Coronet Super Bee 383 A4
1970 Plymouth Road Runner 440 FC7 (sold)
Re: Engine Dolly/Cart Needed for Big Block [Re: 70Duster440] #1420906
02/28/14 12:30 PM
02/28/14 12:30 PM
North Carolina
Mikeymopar68 Offline
North Carolina
I am in the process of taking my 360 to be rebuilt and was looking for an easy/quick design for an engine cradle and yours fits the bill. Is there anything other than 2x6, screws, casters and carriage bolts that I need? Looks like the engine oil pan rim sits down nicely into the box. How stable is this design since I have to transport my 360 about two hours away. Thanks Mikeymopar68 at aol dot com Thanks Mike.
Re: Engine Dolly/Cart Needed for Big Block [Re: Mikeymopar68] #1420907
02/28/14 12:57 PM
02/28/14 12:57 PM
california
Mr D21 Offline
Mr D21  Offline
california
this is mine,,,
Re: Engine Dolly/Cart Needed for Big Block [Re: vinnyd76] #1420908
02/28/14 07:28 PM
02/28/14 07:28 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
Harbor Freight furniture dolly.I put 2 2x4's across it and then 2 4x4's lengthwise as it gets the engine high enough so the deep oil pan clears.
Nautilus Racing-
