Post your Budget Motor Builds... #1419222
04/13/13 07:16 PM
04/13/13 07:16 PM
Plant city fl
70Dart499 Offline OP
Plant city fl
Just curious to hear some of the low budget motor builds that some of you guys are running, and what they run. Now I know this probably isn't the first thread on this, but I figured a new one cant hurt. I don't care if its a big block, small block or anything else.
1970 Dart Drag Car
Re: Post your Budget Motor Builds... [Re: 70Dart499] #1419223
04/13/13 09:47 PM
04/13/13 09:47 PM
Rescue CA.
joes68340s Offline
joes68340s  Offline
Rescue CA.
1977 440 stock bore deglaze hone. Forged pistons hand polished cast crank. stock rods with arp bolts. balanced lower assembly.Deep pan enlarged oil passage. Dc 284-484 hyd cam. Stock rebuild 452 heads. Holley Street Dominator intake 750 vac holley. Adjustable pushrods. After tuning it ran in the 11.80-11.90 at 115 mph range with 3.91 gears and 28 inch slicks in a 71 Challenger. Wish I still had that car. Only draw back was a little piston knock when cold. Ran pump gas to.
Re: Post your Budget Motor Builds... [Re: 70Dart499] #1419224
04/14/13 08:46 AM
04/14/13 08:46 AM
tboomer Online work
tboomer  Online Work
Your sig says you have a 499..I am curious why you don't work with what you have..
Re: Post your Budget Motor Builds... [Re: tboomer] #1419225
04/14/13 09:24 AM
04/14/13 09:24 AM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
I had built a turbo motor for under $1k. I took an old 383 short block that had been lying around and reringed and new bearings installed, .040 felpro head gaskets, old iron open chamber heads with large valves, bartered tm6 intake, unwanted holley 600dp, pair of cxracing t3t4 turbos, blow off valves, wastegates, ebay blowthrough hat, boost reference a holley mechanical pump, stock replacement hydraulic cam.
Went 7.30 @ 94mph in my full interior 1970 Cutlass S with stock 2.56 gear (lazy 2.0 60ft and ran out of fuel from pump around the 1/8 coasted to 13.54et)
Re: Post your Budget Motor Builds... [Re: 70Dart499] #1419226
04/14/13 10:37 AM
04/14/13 10:37 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
What's your definition of budget?
I know that there are some relatively basic engine combinations that I've run in the past that I could probably duplicate for less $$$ today, or get better results today from the same budget as a result of improved selection of parts.
Re: Post your Budget Motor Builds... [Re: 70Dart499] #1419227
04/14/13 11:05 AM
04/14/13 11:05 AM
MR_P_BODY Offline
MR_P_BODY  Offline
The engine I have in my Rampage is a budget engine..
all the parts I had in the shop except the pistons..
I didnt have any low compression ones... is it a proper
match of parts... no way but it did make 550hp and 520tq..
its a 416, 340 block, 4" stroke, roller cam(260/270
.640/.640 105lsa, W-5 heads, M-1 large port intake,
TD rockers, Diamond pistons for 10.7:1, home made headers
with a 518 trans behind it.... I should change out my
valve springs since they are on the light side for
what I'm doing... maybe in the next year I will change
it over to a hyd roller or a FT cam... but it sure sounds
good now.... like I said.. all the parts were laying
around the shop except the pistons so I think thats
a budget build
Re: Post your Budget Motor Builds... [Re: MR_P_BODY] #1419228
04/14/13 01:19 PM
04/14/13 01:19 PM
Howell,MI
Moparpoor Offline
Moparpoor  Offline
Howell,MI
440 with Kb pistons 0 deck height,stock recon rods,stock steel crank lightened,stock caps with girdle.Indy ez heads and solid roller are the only real ex spence . This a pump gas motor that pushes my 64 dodge to a best so far of 10.77@126mph Not to bad for a free block and $200 pistons and rods.Hell the whole car was pieced together with left over parts.
Re: Post your Budget Motor Builds... [Re: Moparpoor] #1419229
04/14/13 02:41 PM
04/14/13 02:41 PM
Washington
skrews Offline
skrews  Offline
Washington
Budget motor is a relative term
Re: Post your Budget Motor Builds... [Re: skrews] #1419230
04/14/13 03:15 PM
04/14/13 03:15 PM
Washington
skrews Offline
skrews  Offline
Washington
72 360 block, banged around so hard the front of the crank broke off.
Magnum crank polished. Free
Magnum rods with balance pads ground off, beams polished, ARP bolts out of one time used rods. Free
Used OE LA 360 harmonic damper from scrap pile Free
.040 over SealedPower 4 valve relief hypers .047 down the hole bought off Ebay with Mahle moly rings. $130
Ebay stock replacement oil pan with baffle welded in. $50
596 heads from scrap pile Free
1.88 MP valves, left overs from a 340 of mine from years ago
1.6 Milodon valves off Craigs List $35
Comp 926 springs and mystery retainers more left overs from engines past
MP HD stamped rockers and replacement pushrods out of my buddies blown up 360 Free
MP .484 PurpleShaft left over from engines past
Iron 360 intake from scrap pile, port matched, carb pad matched to spacer/adapter, EGR crap plugged and blocked Free
M/T valve covers from swap meet swapped something for 'em
Did all my own machining and porting Free
tested @ 28" S/F 1020 bench
.........int.........exh
.100...61...........48
.150...113.........84
.200...150.........114
.250...172.........134
.300...197.........148
.350...212.........159
.400...225.........165
.450...234.........169
.500...231.........172
.550...231.........173
.600...228.........175
exh tested with 1.75 pipe
MP 1.88 stainless 33* back cut to within .010 of seat
MP 1.6 stainless tulip no back cut
Probably in the whole thing $500
On to the dyno with 1.75 headers and a 750 doublepumper on a 2" tapered spacer
428 HP @ 5700
449 TQ @ 4300
With an Edelbrock RPM Air Gap everything else the same
442 HP @ 6000
460 TQ @ 4700
video in link below
http://www.youtube.com/watch?v=Zl2jA6zHDb4
Re: Post your Budget Motor Builds... [Re: skrews] #1419231
04/14/13 03:19 PM
04/14/13 03:19 PM
pa
572charger Offline
572charger  Offline
pa
30 over 440 trw pistons 590 cam street port heads stock 6 pack and carbs 727 cheeta valve body turbo action convertor pump gas 410 gears 3900lbs 11.31 at 116mph back in 1984 !!!!!
606 hemi pump gas best 9.60 at 142mph on motor
05 hemi daytona 1500 go-mango 4wd quadcab
2007 hotrod mag pump gas drags runner up, roadkill nights dodge big tire winner 2018 2019 back to back
Re: Post your Budget Motor Builds... [Re: tboomer] #1419232
04/14/13 03:27 PM
04/14/13 03:27 PM
Plant city fl
Plant city fl
Oh I am, just like to hear what others are doing.
1970 Dart Drag Car
Re: Post your Budget Motor Builds... [Re: MR_P_BODY] #1419233
04/14/13 10:09 PM
04/14/13 10:09 PM
st.cloud fl
d-150 Offline
Smarter than a 5th grader?
d-150  Offline
st.cloud fl
that engine bay is awesome
Re: Post your Budget Motor Builds... [Re: d-150] #1419234
04/14/13 10:15 PM
04/14/13 10:15 PM
Florida STAYcation
dOc ! Online penguin-006
The village idiot's idiot
dOc !  Online Penguin-006
Florida STAYcation
Re: Post your Budget Motor Builds... [Re: d-150] #1419235
04/14/13 10:41 PM
04/14/13 10:41 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Its different... thanks.... I dont like having what
everyone else has
