Will C body HP manifolds fit my 68 Charger? #1417585
04/09/13 11:29 PM
04/09/13 11:29 PM
California
shamefulcuda Offline OP
California
I have a pair of a 69 and a pair of 71 C body HP manifolds that I want to use on my 68 charger. Will they work on my car? I know the passenger is the same as the others so specifically the driver side manifold. Thanks guys!
Re: Will C body HP manifolds fit my 68 Charger? [Re: shamefulcuda] #1417586
04/09/13 11:38 PM
04/09/13 11:38 PM
SC
V194 Offline
V194  Offline
SC
I would have to ask why? It would look out of place? Why not use the correct B body pieces since the c-body pieces are much more rare. Plus I think the B-Body stuff flows better?
Re: Will C body HP manifolds fit my 68 Charger? [Re: V194] #1417587
04/10/13 12:12 AM
04/10/13 12:12 AM
California
California
Ok since you asked. Because I have them and I dont want to pay the 300-400 for b body ones?? Why not use what I have? I doubt they flow any better or worse as they are very similar looking just the flange looks tilted up a bit more which is why I am wondering if I will have clearance issues with the exhaust?
Re: Will C body HP manifolds fit my 68 Charger? [Re: shamefulcuda] #1417588
04/10/13 12:57 AM
04/10/13 12:57 AM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
The pass side is the same between B and C HP. The C drivers side has the flange kicked out towards the side so that is the area that might cause some problems.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: Will C body HP manifolds fit my 68 Charger? [Re: moparmarks] #1417589
04/10/13 11:12 AM
04/10/13 11:12 AM
Alabama
BigMoneyLewis Offline
Alabama
You can find loose B body driver side HP manifolds at swap meets, ebay etc. for $ 100 or so if you look .
Greg
gregward@mchsi.com phone 256-852-0955
Re: Will C body HP manifolds fit my 68 Charger? [Re: BigMoneyLewis] #1417590
04/10/13 11:54 AM
04/10/13 11:54 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
not sure the DS will work. I'd sell those and buy the right ones, even better get a set of headers. C-body guys go goffy over those hi-po logs
Coming soon!!!!
Re: Will C body HP manifolds fit my 68 Charger? [Re: Mr.Yuck] #1417591
04/10/13 12:15 PM
04/10/13 12:15 PM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
What's everyones opinions got to do with the OP's question anyway?
Ya, the C body exhaust manifols will work in your car.
You will just have to bend the exhaust pipe the right way, to fit the flange, and around the steering column shaft.
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: Will C body HP manifolds fit my 68 Charger? [Re: hemi71x] #1417592
04/10/13 01:07 PM
04/10/13 01:07 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I don't know how you are going to bend up a drivers side pipe that would clear the column with something like this.
Re: Will C body HP manifolds fit my 68 Charger? [Re: shamefulcuda] #1417593
04/10/13 01:13 PM
04/10/13 01:13 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Seen too many guys try to use the C body manifolds in B and E swaps when engine swapping, never works out, they eventualy go headers or the correct manifolds, do yourself a favor, pony up the and go with headers or the correct manifolds,...only common sense
Re: Will C body HP manifolds fit my 68 Charger? [Re: shamefulcuda] #1417594
04/10/13 01:23 PM
04/10/13 01:23 PM
Austin, Texas
65Sat440 Offline
65Sat440  Offline
Austin, Texas
I beg to differ slightly... As has been stated, the C body HP manifold flange's more horizontal kick out will put it close to steering rod/knuckle. Like you, I had the C body manifolds so I used them. On my car it was the head pipe flange, not the manifold per se, that was close to interfering. I just trimmed back the head pipe flange a bit for clearance and it works. This is a '69 HP 2863409 in a '65 Satellite. YMMV
Re: Will C body HP manifolds fit my 68 Charger? [Re: Mr.Yuck] #1417595
04/11/13 11:51 AM
04/11/13 11:51 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
That's why you do the job you do and don't work in a custom exhaust shop
I put that exact manifold in my dart on a 383 and it will work with a custom bent headpipe, maybe make it up from mandrel bends .
If the flange isn't pointing right at the steering column there is more romm in a 68 b body engine compartment than a 69 a body .
Re: Will C body HP manifolds fit my 68 Charger? [Re: JohnRR] #1417596
04/11/13 12:08 PM
04/11/13 12:08 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
you got that right, that's why my car is sitting right now. Because I put the 2" hookers on and I have to cut and weld some pipe.. and I'm not too good at that.
Re: Will C body HP manifolds fit my 68 Charger? [Re: BigMoneyLewis] #1417597
04/11/13 12:10 PM
04/11/13 12:10 PM
moparmarks Offline
moparmarks  Offline
Greg
Bingo.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
