Partial harden block on the street? #1417285
04/09/13 12:57 PM
04/09/13 12:57 PM
Fairfield Maine
hemi4speed Offline OP
Fairfield Maine
I have recently aquired a 512 stroker, Its filled about 4 inches down from the Deck. Race only or can I keep this Block cool on the street?
Re: Partial harden block on the street? [Re: hemi4speed] #1417286
04/09/13 12:59 PM
04/09/13 12:59 PM
dogdays Offline
dogdays  Offline
The consensus here in the past was it'd be fine. Can't wait to see what the new comment s are.
R.
Re: Partial harden block on the street? [Re: dogdays] #1417287
04/09/13 01:04 PM
04/09/13 01:04 PM
MICHIGAN
BB65Barracuda Offline
MICHIGAN
My 426 Hemi is filled up to the top of the freeze plugs and its a street car.4" from the deck isn't that much of a fill.
I haven't taken a long trip yet but with an oil cooler, I'm not going to worry about it. Watch your oil temp.
All the heat is in the top end anyways.
1957 Power wagon wm300 original 10.000 mile truck, 1964 dodge Polara Convertible numbers matching
Re: Partial harden block on the street? [Re: BB65Barracuda] #1417288
04/09/13 01:09 PM
04/09/13 01:09 PM
Fairfield Maine
Fairfield Maine
sounds great.. I really want to build it for street and strip (50/50) around 10.5:1 comp.
Re: Partial harden block on the street? [Re: hemi4speed] #1417289
04/09/13 02:33 PM
04/09/13 02:33 PM
MICHIGAN
MICHIGAN
You should be good to go!
Re: Partial harden block on the street? [Re: BB65Barracuda] #1417290
04/09/13 02:42 PM
04/09/13 02:42 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Someone else made mention of using an oil cooler, which is what I'd been told might be required when asking about a partial fill used on the street, too.
Re: Partial harden block on the street? [Re: hemi4speed] #1417291
04/09/13 02:49 PM
04/09/13 02:49 PM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
SHOULD be fine for a streeter .... as long as the top-ring has water across from it ... but it is BESTer if #2 has it tooo.
Re: Partial harden block on the street? [Re: dOoC] #1417292
04/09/13 02:54 PM
04/09/13 02:54 PM
Toronto
mshred Offline
mshred  Offline
Toronto
Here is my two cents on this, after doing alot of asking about this here and other places.
I have filled my block to a little above the freeze plugs (SB). I decided against the oil cooler from the get go since I have a street car and unless the coolers are thermostatically controlled, it can take quite a while to heat that oil up. So I am putting a temperature gauge in the pan, and will watch my oil temps, then decide from there if I need to add a cooler to the system.
Consensus is a half fill should be fine...and remember what you need to watch is oil temps, not water...if anything, your water temps should be better than before since there is now less area for the water to cool...so don't be tricked that cooler water means cooler oil, because it doesn't
Thats my ...good luck!
Re: Partial harden block on the street? [Re: hemi4speed] #1417293
04/09/13 03:21 PM
04/09/13 03:21 PM
Lowes
steve660 Offline
steve660  Offline
Lowes
Fill to bottom of freeze plugs. Ive ran it this way 10 years in a low 10 sec. street car,no problems. Most of the heats in the top of the cylinder anyway.
PSO headed 632 from MM. Cracked cylinder, loose valve seats, low oil pressure, low cylinder pressure.
..... Now its a door stop....
