Oil Filter ? Small 2.2 Oil filter on small block. #141531
10/26/08 06:35 AM
10/26/08 06:35 AM
Q
qkRick Offline OP
qkRick  Offline OP
Q
Hi People,
Have any of you ever used a small oil filter designed for 2.2 litre engines on a small block to deal with space constraints. A friend of mine used to use them quite often in different applications including race cars and states he had no issues. What about filtration, flow etc.? Any input appreciated.
Thanks MoParts!
Re: Oil Filter ? Small 2.2 Oil filter on small block. [Re: qkRick] #141532
10/26/08 07:45 AM
10/26/08 07:45 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
Been doing it for 15 years with no problems. Make good for tight clearances. It even fits my garden tractor.
Re: Oil Filter ? Small 2.2 Oil filter on small block. [Re: qkRick] #141533
10/26/08 08:25 AM
10/26/08 08:25 AM
Mass
dgc333 Offline
dgc333  Offline
Mass
I have been doing just the opposite going with the PH8A size filter on the engines that spec that tiny PH3614 size filter since my first 2.2 back in 85.
IMHO, you want as much filter surface area as possible. More surface area you have the less likely the filter bypass is to open an circulate non filtered oil.
Plus the bigger filter holds more oil and will dissipate more heat.
My recommendation if you can't fit at least the PH43 size filter you should go to a remote filter.
Dave Clement Pembroke, MA 03 PT Cruiser GT Turbo 99 Dakota SLT+ CC 4x4 68 Barracuda sport coupe http://home.comcast.net/~dgc333/
Re: Oil Filter ? Small 2.2 Oil filter on small block. [Re: dgc333] #141534
10/26/08 08:36 AM
10/26/08 08:36 AM
N. of 8mile, S. of heaven
Spike Offline
Go Blue!!
Spike  Offline
Go Blue!!
The by-pass valve pressure is the same for the small filter and the larger one, 7-9 PSID. This info is on Amsoil oil filters, I do not know the by-pass valve pressure ratings for Fram filters.
Re: Oil Filter ? Small 2.2 Oil filter on small block. [Re: dgc333] #141535
10/26/08 10:31 AM
10/26/08 10:31 AM
Q
qkRick Offline OP
qkRick  Offline OP
Q
I agree and have always used the bigger is better approach with oil filters. In this case there isn't room for access. I'm hoping that with the limited use this car will see and my way over the top oil change schedule that the small filter may work. I already have the remote filter set up for the car and was all set to install when my friend advised me of the small filter possibility. Stupid as it sounds, on this car I just don't like the looks of the remote filter. My buddy says that the remote units are also susceptible to leakage.
Thanks for the help people and any more input greatly appreciated.
Re: Oil Filter ? Small 2.2 Oil filter on small block. [Re: qkRick] #141536
10/26/08 10:36 AM
10/26/08 10:36 AM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
I all ways run the smaller filter. IMO for a car that will likely only see 200 miles or so a year and probably gets its oil changed more then needed there should be no problem.
Re: Oil Filter ? Small 2.2 Oil filter on small block. [Re: Spike] #141537
10/26/08 06:09 PM
10/26/08 06:09 PM
Mass
dgc333 Offline
dgc333  Offline
Mass
But with less filter media the pressure drop across the media will be higher than for a filter with more media so the potential for the filter to be bypassing is higher with the small filter even if both have the same rating.
Other than clearance a larger filter has no down side and a smaller filter potentially does.
Re: Oil Filter ? Small 2.2 Oil filter on small block. [Re: dgc333] #141538
10/26/08 06:46 PM
10/26/08 06:46 PM
Upper Midwest
Upper Midwest
Don't be cheap and change your oil at the 2500-3000 area if you are really worried about it and you will never have a problem.
Re: Oil Filter ? Small 2.2 Oil filter on small block. [Re: MoparforLife] #141539
10/27/08 07:06 AM
10/27/08 07:06 AM
Q
qkRick Offline OP
qkRick  Offline OP
Q
Thanks Folks,
This car will never see 2K mi. between oil changes so I think I'll be o.k.
Thanks Again
Re: Oil Filter ? Small 2.2 Oil filter on small block. [Re: MoparforLife] #141540
10/27/08 08:34 AM
10/27/08 08:34 AM
Mass
dgc333 Offline
dgc333  Offline
Mass
Even changing it at 2000 mile intervals is not going to gaurentee the filter is not by-passing especially if you have an HV oil pump.
Its just plane good engineering to use the biggest filter possible.
Re: Oil Filter ? Small 2.2 Oil filter on small block. [Re: dgc333] #141541
10/27/08 12:52 PM
10/27/08 12:52 PM
Fort Worth, TX
Clair_Davis Offline
Clair_Davis  Offline
Fort Worth, TX
IIRC, the GLHS cars used a larger DIA filter that was still low-profile. I remember seeing that the application also fit Renault Alpine cars, which I thought was interesting because I really liked those cars at the time. That filter might be somewhat of an improvement, but I can only vouch for the OD of the filter can... the guts might be the same for all I know.
Running a standard volume oil pump and thin oil would tend to reduce the tendency of a filter to bypass, but those are bandaid fixes at best. I run 10W-30 oil and the short version of the OEM small block filter, but I'll be upgrading to a remote filter when I plumb in my Accusump. That combo should let me run at least one LARGE filter (maybe two), plus another 2+ quarts capacity in the Accusump. That'll be somewhere between 7 and 9 quarts in a 5-quart pan.
Clair
Re: Oil Filter ? Small 2.2 Oil filter on small block. [Re: qkRick] #141542
10/27/08 02:10 PM
10/27/08 02:10 PM
S.E.Ohio
Magnumguy Offline
Magnumguy  Offline
S.E.Ohio
Hey, I use PH43's (usually something else, so you'll knoiw the size, etc) on my 2.5's and up. Fits the 4 cyl's., 3.0, 3.3, 3.9V6 ,etc.
I look at it as more capacity!!
"Multiple Magnum owner since 1978!!"
https://www.facebook.com/groups/146952895354657/
Re: Oil Filter ? Small 2.2 Oil filter on small block. [Re: Magnumguy] #141543
10/27/08 05:16 PM
10/27/08 05:16 PM
Slantytown
DUFFMAN Offline
Ask And Ye Shall Receive
DUFFMAN  Offline
Slantytown
As far as Fram goes;
PH8A full quart
PH43 3/4 quart
PH16 1/2 quart (same as Mopar 5281090)
PH3614 1/4 quart
All have the same base thread and gasket just a different capacity.
No longer taking $h!t from anyone!
Re: Oil Filter ? Small 2.2 Oil filter on small block. [Re: DUFFMAN] #141544
10/27/08 07:34 PM
10/27/08 07:34 PM
Mass
dgc333 Offline
dgc333  Offline
Mass
I used to use the PH8A size filter on m 2.2 turbo cars in place of the specified PH3614.
My Dakota gets the PH43 size filter in place of the PH16 that is specified.
My PT gets a PH3600 which is the same diameter as the specified PH3614 but is almost as long as the PH8A.
On the Barracuda the headers prevent anything longer than the PH43 but there is plenty of room for a larger diameter if I run across one. One of my winter projects is for a remote filter just so I am not dribbling oil onto the headers any more.
Re: Oil Filter ? Small 2.2 Oil filter on small block. [Re: dgc333] #141545
10/27/08 11:47 PM
10/27/08 11:47 PM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
We need to translate those Fram numbers into ABF numbers for some of the folks here.
I have been running Pure1 PH8A sized filters on my 360 van. Mechanic buddy said the big one is too close tho the stock exahust. I have 6 1/2qts.
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
