AIR CLEANER ASSEMBLY HEMI #1414758
04/05/13 03:29 AM
04/05/13 03:29 AM
chicago,il
jaque Offline OP
jaque  Offline OP
chicago,il
HELLO I HAVE A 426 CRATE MOTOR ALMOST READY TO START FOR FIRST TIME AND IAM IN NEED OF A AIR CLEANER ASSEMBLY FOR A FOUR BARRELL DEMON CARB, HAVING A HARD TIME FINDING BASEPLATE AND LID? CHROME WOULD BE AWESOME AS I CAN ONLY FING ORANGE POWDER COATED ANY IDEAS OR PRODUCTS IM OVER LOOKING?
REGARDS
WOLF
you come here with nothing and leave here with nothing!! enjoy life while on this planet, cuz when youre dead youre dead!!!
Re: AIR CLEANER ASSEMBLY HEMI [Re: jaque] #1414759
04/05/13 04:55 PM
04/05/13 04:55 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
REGARDS
WOLF
Oval type air cleaner or round ?
One thing you are overlooking is your caps lock button appears to be dEfEcTiVe ...
Re: AIR CLEANER ASSEMBLY HEMI [Re: jaque] #1414760
04/05/13 07:29 PM
04/05/13 07:29 PM
central P.A.
HEMIDOG 70 Offline
HEMIDOG 70  Offline
central P.A.
If you are looking for an oval air cleaner try a single 4bbl 440 base and lid from Mike at BE&A restoration. You may need an adapter ring on the carb opening to fit your holley sized air horn.
Re: AIR CLEANER ASSEMBLY HEMI [Re: HEMIDOG 70] #1414761
04/07/13 03:49 AM
04/07/13 03:49 AM
chicago,il
jaque Offline OP
jaque  Offline OP
chicago,il
DUDE I KN0W HIM GONNA GIVE HIM A CALL,, THANKS..
Re: AIR CLEANER ASSEMBLY HEMI [Re: jaque] #1414762
04/07/13 11:07 AM
04/07/13 11:07 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Re: AIR CLEANER ASSEMBLY HEMI [Re: ScottSmith_Harms] #1414763
04/07/13 04:37 PM
04/07/13 04:37 PM
central P.A.
HEMIDOG 70 Offline
HEMIDOG 70  Offline
central P.A.
Re: AIR CLEANER ASSEMBLY HEMI [Re: HEMIDOG 70] #1414764
04/19/13 06:10 AM
04/19/13 06:10 AM
Houston Texas
PAINT IT BLACK Offline
Got a CHIP on my shoulder
Houston Texas
Try my base. It is a cut to fit - one szie fits all type base. I've equipped many single 4bbl Hemis.
Price is $175 + ship and accessories. Machined aluminum bridge is $75 and is used to hold assembly down. The lid studs thread directly into my base in the front and rear- there are provisions for 4bbl AND 6bbl lids... your choice (there's a chrome 6 pack lid out there for sale). The nuts glassed in to the left and right of the opening is where you will mount the bridge and that helps it clear if you need to drop the base quite a bit as it doesn't interfere with a choke horn. PM me, they are in stock and I have everything else to complete the assembly (except the 6 pack lid studs for the moment - you can always simply use threaded rod cut to size to save a few bucks).
Re: AIR CLEANER ASSEMBLY HEMI [Re: PAINT IT BLACK] #1414765
04/19/13 06:13 AM
04/19/13 06:13 AM
Houston Texas
Houston Texas
Here's the bridge.
